1. Offline
    gambit023 Junior Member
    Start a Conversation
    Jan 3, 2012
    23
    Maryland
    Your Vehicle Year:
    D.I.Y. Hella Supertones Horn Install on 3rd Gen Prius
    Notes: I did not use the included Hella relay. I read the voltage on the factory horn signal wire and found it to be about 14.4 volts when activated. I’m not sure if the Supertones would be louder if I used the relay to a direct +positive source from the fuse box since they both returned the same voltage. If anyone has more info on this, please let me know. The Supertones are significantly louder than stock so I’m happy with the install even without the relay.
    Before getting started, you’ll need a 1” strip of aluminum to make a custom bracket as the stock Supertones bracket was too short to accommodate the larger horn in the factory location. I got a 1”x4’ strip at Lowe’s for $8. The bracket should be cut to 5.25” in length and mounting holes drilled to 5/16”. The original bracket on the Supertones needs to be removed and replaced with this. Use Loctite when attaching the new bracket as the original bolts holding the brackets on the Supertone were extremely tight. I fabbed up these brackets with a basic hand hack saw and a drill. [IMG]
    Installation:
    Step 1: Loosen up the front bumper cover (sides and top only). There are two fasteners in each front wheel well as well as several clips and two 10mm bolts on the top part of the bumper cover. I didn’t remove the whole bumper. I just removed the fasteners from the top and front wheel wells and allowed the front bumper to pivot forward giving me sufficient access to do the install.
    [IMG]
    Step 2: Remove factory horns. I believe each were held on with a 10mm or 12mm bolt.
    [IMG]
    Step 3: Replace the Hella bracket with the custom 5.25” aluminum bracket if you have not already done so (see first picture). Ensure to use Loctite on the 13mm nut that holds the bracket to the horn. *disclaimer: Hella states warranty will be void if bracket is removed.
    Step 4: Install Supertones in the factory location. The factory horn signal wire fit directly onto the Supertones. I connected the factory wire to the copper colored Supertone connecter.
    [IMG]
    [IMG]
    Step 5: Make two ground wires at about 7” in length. Attach a female spade connector on one end and a ring connecter on the other. Connect female spade to Supertone and the ring connecter to the top radiator support bracket. This proved to be a sufficient ground. You can see the two ground wires attached with the yellow ring connectors in the following picture:
    [IMG]
    Step 6: Test horn.
    Step 7: Reinstall bumper cover. Enjoy.
    [IMG]
  2. Offline
    ockevin Active Member
    Nov 24, 2011
    521
    131
    Orange County
    Your Vehicle Year:
    Very nice write up.
  3. Offline
    xliderider Active Member
    Apr 19, 2012
    850
    149
    Honolulu
    Your Vehicle Year:
    Are these horns high/low frequency like the FIAMM upgrade, or are they the same tone? Nice write-up, especially regarding the loosening of the bumper cover, since that particular detail was not covered in the other horn upgrade thread. :)
  4. Offline
    wotcher Member
    Mar 24, 2012
    352
    73
    LA
    Your Vehicle Year:
  5. Offline
    Apr 19, 2012
    850
    149
    Honolulu
    Your Vehicle Year:
    Hmm, the "edit" link doesn't seem to be working. :(
    I did a search on Amazon, and these horns are offered in a High/Low twin horn kit. Costs about 2x the FIAMM horns though and they are rated at 118db. The FIAMM horns are rated at 130db, but the Hella horns are front facing through the grill and the FIAMM horns point down, so who knows? ;)
    SlowTurd likes this.
  6. Online
    Dec 5, 2010
    485
    59
    Baltimore, MD
    Your Vehicle Year:
    I love my Hella Supertones :)
    Good job on the write up! My install was pretty much the same. I painted the bracket black with some plasti dip.
  7. Offline
    xs650 Senior Member
    Jul 2, 2010
    4,417
    1,299
    Northern California
    Your Vehicle Year:
    Some place on the Interwebs a motorcyclist did comparison sound level test of several horns. Any connection between measured sound levels and manufacturers claims were non-existent. IIRC, you made the right choice.
    Edit: I was actually able to find the test, here's the link
    Motorcycle Horn Comparison Review - webBikeWorld
  8. Offline
    Jan 3, 2012
    23
    Maryland
    Your Vehicle Year:
    Thanks for the link. Very interesting.
  9. Offline
    SoCalBPrius Active Member
    Jan 8, 2012
    553
    125
    SoCal
    Your Vehicle Year:
    Wow, those horns look huge seeing through the grill. Nice writeup btw:).
  10. Offline
    sfv41901 Blizzard Brigade #164
    May 5, 2010
    2,279
    632
    Palmdale, Ca
    Your Vehicle Year:
    I like them. Any chance for a sound clip?
  11. Offline
    Prius Envy F U R Y
    May 7, 2011
    So Cali
    Your Vehicle Year:
    Thank you and thumbs up for the great write up.
    The only thing I changed was put the ground behind the mounting bracket that was bolted to the body; that way it's a cleaner install.;)
  12. Offline
    Apr 19, 2012
    850
    149
    Honolulu
    Your Vehicle Year:
    Agree, a cleaner install.
  13. Offline
    Apr 19, 2012
    850
    149
    Honolulu
    Your Vehicle Year:
    This mod could also be included in the Grill Blocking thread as well... it looks to be about a 40% upper grill block. ;) :D
Share This Page
