Anyone Installed Philips LED Daytime Running Lights on a Gen III?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by randalla, May 2, 2012.
  1. randalla
    randalla Member
    370
    Lexington, SC
    Has anyone done an installation of the Philips 12820WLEDX1 DayLight 4 High Powered Luxeon LED daytime running lights on their Gen III car? If so, what sort of problems, if any did you encounter with the install? Which 12v power point source did you tie into under the hood or did you have to run wiring all the way back to the 12v battery? Any helpful suggestions are welcomed!
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    There is a power tap in the fuse box under the hood that is energized when the car is in ACC/Ready mode. Follow the Fog Light link in my signature. Piece of cake.
  3. randalla
    randalla Member
    370
    Lexington, SC
    Sweet! thanks for the info, Spiderman!
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Hmm, actually you have a V so that tap might be occupied. Take a photo of your fuse box and post.
