Anyone know how to get to 2010 right front turn signal bulb?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NoMoShocks, Oct 8, 2009.
  1. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    81
    Camas, WA
    I was trying to get to the right front turn signal bulb on my 2010 so I can tap into the circuit for signal mirors. Left side is easy, but right side is tucked in behind the window washer reservour. I removed that, but the bracket is still in the way. Removed wheel well liner and cant reach it there. Started to remove the head lamp assembly, but it looks like the whole bumper cover needs to come off to get to that.
    Any ideas?
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Remove the bottom aero tray at the corner around the bumper, should be able to reach right up.
    Wayne
  3. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    ^^^ i agree, there's a little trap door on the belly pan. 1 - 10mm screw and 2 push clips. it's the same on both sides.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The owners manual has instructions for replacing all exterior bulbs. For the turn signals & fogs, there's a panel under the car on each side that allows access.
