Arduino Automatic Coolant Temp Hack for Better MPG's
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TheForce, Feb 23, 2011.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Got the nano, waiting on the pot...might be a few days.
    Meg&Bear likes this.
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Cant wait to hear your results. :D
  3. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Today I had some trouble with it faking the temperature. As I was headed home the engine warmed up to about 110F and the Arduino started faking the temp. Some time later I noticed that the LED was red but the temperature on the scangauge was about 143F. For some reason it thought the real temperature was too hot. I tried resetting several times on the road but it just went back to the red LED indicating it was too hot even though the real temp was well below stop temp setting. When I got home it stopped doing this so I could not hook up my PC to capture the serial output of the Arduino.
    I will continue to monitor this before I put this in a project box.
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I think I may have fixed my problem. After looking at the serial out the average was just not right for the input. After fiddling around with the wires I found that one of my wire taps was the issue or so I think. When I wiggled it the average wondered around a LOT. So instead of using my crappy wire taps I just twisted the wires together and wrapped them in black tape. I tested it again and this time the numbers were as rock solid as before.
    I think the heat may have expanded the plastic and metal in the wire tap just a bit to cause this issue. I will find out if my problem is gone tomorrow after I get off work.
  5. TheForce
    3,461
    537
    Wheelersburg, Ohio
    No problems today.
    I should have this in a project box by the weekend. I tried to make a shield last week but it was a complete failure. I used a radio shack double sided perfboard and when I checked all my connections with a multimeter it looked fine. Nothing was shorted. When I hooked it up to the car there was a small spark near the digital pot and some magic smoke appeared. Aparently there was either a defect in the board or there was a whisker that just did not show up on my multimeter when I did my checks. I think I only damaged the digital pot. The Arduino seemed fine when I ran some tests with it.
    This time instead of making a shield I have compacted everything as best I can onto a generic single sided perfboard. I'm just going to use some wires to go to the perfboard to the Arduino. You'll see when I get it finished. It currently looks pretty good in the CAD software and has a very small footprint. I think if you combine this with a Arduino nano or mini you could stuff it in a very small box or just wrap it up in some electrical tape. I managed to put the LED on but if you left it off you could make it even smaller.
    I might get started on the perfboard tonight if I get time.
    Meg&Bear and dave77 like this.
  6. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Just wanted to give an update.
    I still have my breadboard in the car. I'm having trouble getting the perfboard version to work. Kind of looks like a short somewhere but I cant find it with my multimeter.
    I'm still waiting for warm weather to see how it performs in the heat.
    seilerts how is yours coming along?
  7. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    And here i thought i had a grasp on all this stuff when BAM!!!!!! you guys lost me :)
  8. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I know why. It's because I didn't proof-read properly.
    Change /= to /
    Code:
        ADC_average = ADC_sum /= 8;    // Put the average in to ADC_average.  Could >> 3 if we can guarantee all values are > 0
    Code:
        ADC_average = ADC_sum / 8;    // Put the average in to ADC_average.  Could >> 3 if we can guarantee all values are > 0
    It was dividing the rolling sum by 8 each time CAL_Average was called.
    I don't need credit for this. My code didn't add any functionality. As the open source world says: ideas are easy, it's implementation that's difficult and you're doing the hard work.
  9. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    If you're putting a kit together for sale, please count me in :)
    Meg&Bear and joelevi like this.
  10. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Sorry I'm not putting a kit together. You'll have to source out your own parts.
    Just to give an update.
    Finally had a really hot day today. The temp in the car was well over 100F when I left from work. The circuit failed to fake the temperature so There still must be some component that is affected by the heat. I'll bring my mini laptop with me tomorrow to see if I can tell whats going on. Thats if its hot again.
    I'm going to get one of ccdisce ECT spoofers since he is offering it cheap but I still want to get this Arduino version working just so there is another option out there for those of us that want to play around a bit. I will continue to work on the Arduino version but its not really a high priority at the moment.
    Thanks ItsNotAboutTheMoney. I make mistakes like that all the time. I'll try it out again when I get time.
  11. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I took a look at the serial output today and I'm just wondering if the Arduino's ADC reference voltage is being affected by the ambient temperature? Its acting like what its seeing is a different voltage than what it actually is. So it thinks its seeing the correct numbers when actually its not if that makes sense.
    I will try to bring some canned air with me next time to see if cooling down the Arduino changes anything. If not I will move on to the transistor then the digital pot.
  12. Daox
    Daox Member
    196
    58
    US, Wisconsin
    I got my parts the other night and decided to build my version of TheForce's arduino temp hack. I'm using a RBBB (really bare bones board) from moderndevice.com, and a shield of my own making. Its a nice very small unit. I love the RBBBs (and they're cheap)!
    Anyway, here are the pics. I still don't have the switch or LEDs mounted yet. I'm going to scrounge those parts off something I have laying around.
    Arduino on the left, temp hack shield on the right.
    Here is the other side of the shield.
    And here it is assembled.
    Meg&Bear, joelevi and dave77 like this.
  13. Daox
    Daox Member
    196
    58
    US, Wisconsin
    I finished up the hack shield this morning. I did make a small change to the schematic. To reduce the amount of resistors needed I put just one 560 ohm resistor before all of the resistors.
    I also changed the code a tiny bit. I swapped some pins on the arduino to digital pot so it would be easier to wire up the shield.
    Here is the finished board on the arduino.
  14. mrbigh
    3,686
    699
    Long Island, NY
    looking good and simple.........
  15. relliMmoT
    relliMmoT New Member
    Shreveport, LA
    2002 Prius
    Hey I've got a Gen 1 w/ a 4KWh Enginer kit. I was wondering if you know of anyone who has attempted this on a Gen 1? Details?
  16. TheForce
    3,461
    537
    Wheelersburg, Ohio
  17. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    Are you using this and how much does it help?
    ...just got an Arduino so now I know what you are talking about.
  18. TheForce
    3,461
    537
    Wheelersburg, Ohio
    2 people like this.
  19. Flying White Dutchman
    4,374
    313
    any idear about price?
  20. usnavystgc
    3,159
    989
    Tucson, AZ
    Hey Force,
    I would really like to get ccdisce's version. I have tried to get ahold of him by sending him a pmail with no luck. I don't know if I'm doing something wrong or not. I don't see any sent items in my account so maybe I don't have access to send a pmail but I really want this hack. I've ordered a PIS 4kw kit and feel like this is a necessary add on to maximize my investment. I've attempted the analog version but couldn't get it set right (consistently). I hate to bug you with this but any help you could give me would be appreciated. My email is [email protected] if you want to email me. I would build it myself but I don't know how to do the programming.
