1. Offline
    Pelham Bob New Member
    Start a Conversation
    Feb 18, 2008
    Pelham MA
    Your Vehicle Year:
    2006 Prius The asb and red emergency brake warning lights came on a few days ago in very wet road conditions. They are still on but the brakes don't feel any different and the emergency brake is not engaged. I have an appointment with the dealer but wondered if anyone has had this happen, and if so, what the fix was. Thanks
  2. Offline
    ceric New Member
    Oct 30, 2004
    1,114
    52
    Fremont, CA
    Your Vehicle Year:
    I guess you meant "abs", not "asb" light.
    ABS light on usually means a failure in ABS sensors or pump module/assembly. The former is cheaper to repair, the latter costs $$$$$. I hope your Prius is still under warranty. Good luck.
  3. Offline
    Steamboatsig Member
    Jan 3, 2008
    333
    La Canada Flintridge
    Your Vehicle Year:
    If it is truly your emergency brake light, check your brake fluid level.
Share This Page
