ATF WS - Drain/Fill Question?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by CBarr31, Apr 19, 2016.
  1. axle2152
    axle2152 Active Member
    266
    209
    Atlanta, GA
    2018 Prius Prime
    Which dealership is your normal dealership? You mentioned JBT which is where I bought my '16 Prius. I've been pretty well happy with them but when it comes to time for a flush I'm not forking out $300!
  2. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Does draining the tranny fluid actually empty most if not all of the old oil? I know in some previous slush box "auto trannys" I owned, one would need to drain X % then top up X%, drive around the block, then redo again until fluid was clear.
  3. bwilson4web
    15,438
    Near as I can tell based on contaminants and viscosity changes, there is about a 15-25% that can not be drained. Successive changes:
    • 1st = 15%-25%
    • 2nd = 2.25%-6.25%
    • 3d = 0.34%-1.56%
    It appears the initial, manufacturing debris is the bulk of what we find. After the third change, the oil settles down to a constant rate of viscosity shear-down with a period of ~100k miles.
  4. eric1234
    eric1234 Active Member
    390
    198
    Hamden, CT
    Has anyone performed a DIY change on a 2016 yet? I'm looking for advice/guidance/experience...
