Auto-unlock (keyless entry) stopped working
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by rorystewart, Apr 27, 2015.
  1. rorystewart
    rorystewart Junior Member
    48
    2014 Prius Plug-in
    The auto-unlock (keyless entry) stopped working on my car. Neither the two front doors nor the trunk unlock when the key is in my pocket. It was working just the day before and now it seems to have randomly stopped working.
    Any ideas?
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Key fob out of battery?
  3. JC91006
    16,470
    8,383
    Your car should be under warranty.
  4. rorystewart
    48
    2014 Prius Plug-in
    It's definitely not out of battery because I can use the key to lock and unlock the car if I press the buttons. I suppose it could be in a low state of battery where the buttons work but keyless entry doesn't? But I don't think that makes much sense. They key fob is also only 16 months old. They don't run out of battery that quickly, do they?
    Yes the car is still under warranty and I will take it in unless I hear of any easy solution from someone here. Just wondering if anyone has encountered this before and what the problem was. One thing I thought of is whether there is a keyless entry setting I accidentally turned off?
  5. bisco
    48,999
    sometimes a low fob battery will cause the sks not to work, but the buttons will still work. a bad 12 volt can cause the same issue. have you tried the second fob?
  6. bisco
    48,999
    i think you can shut off the sks in the settings menu, but it would be hard to do accidentally. it's not a switch like the gen II.
  7. mrbigh
    3,686
    699
    Long Island, NY
    Check for a switch to disable the SKS system, this one could be located above the footwell adjacent to the OBDII connector
  8. bisco
    48,999
    oh, i sit corrected. maybe you bumped it with your knee?
  9. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    If you have the a key fob IN the car, then the keyless entry wouldnt work. But the buttons to lock and unlock would still work.
    This happens to me sometimes when my wife leaves her purse in the car with her car keys. I'm not able to lock or unlock the car without hitting the buttons on MY key fob.
  10. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Happened to me as well. But then, I think, the car will beep warning on you: "Key In Car" when you leave and shut the door (which really means "purse left inside":p).
    #11 giora, Apr 27, 2015
  11. mmmodem
    2,732
    1,703
    Bay Area, CA
    My second key fob is doing just that. Proximity sensor goes out first before the buttons go out. Then you have to hold the fob against the start button to start the car. I replaced my the key fob battery a little over a year after I got the car. I thought it was kinda strange too that it didn't even last two years. That my second fob is going out a year after I started using it, (I rotated keys so I can keep the batteries fresh.) tells me the dealer gave me old fobs or installed old batteries.
  12. bisco
    48,999
    mine last 4-5 years. have on all 5 of our hybrids. some say it's where you park them, others say it's something in the environment, and still others, bad circuit board or buttons.
  13. rorystewart
    48
    2014 Prius Plug-in
    SOLVED! Turns out my issue was the exact same as Tracksyde's. Thanks everyone. Glad I asked you before calling the dealer.
    Tracksyde likes this.
  14. Mendel Leisk
    38,260
    I don't think 3rd gen has this.
  15. Mendel Leisk
    38,260
    Funny, if (for example) my wife's left her keys in the car, and I attempt to lock it it, the car let's me know with a long (obnoxious) beep.
    roflwaffle likes this.
  16. bisco
    48,999
    what happen, the second fob was in the car, or your wifes purse?:p
