Backup Beep reset itself
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Beel, Feb 22, 2013.
  1. Beel
    Beel Junior Member
    So I bought an elm327 interface and doped out what I had to do to stop the backup beep. Worked like a charm a month ago. So happy! Then this morning I got in, moved the shifter to R and suddenly the beep is back. Anyone else had this or have any idea why it happened?
  2. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    Nope, did it once and it's been good since. :)
    You didn't disconnect the battery of anything?
  3. Beel
    Beel Junior Member
    Nope. Had the situation with the gen II and it turned out to be loose battery connection, but this is a one month old car -- also it didn't reset the clock or anything else. Seat belt warning settings remained as I set them at the same time as the backup beep. Oh well.
