Bad for Long Term Health of Hybrid Battery?
Discussion in 'Gen 3 Prius Technical Discussion' started by cycledrum, Jan 10, 2012.
  1. stevil
    stevil New Member
    Denver, Colorado
    New owner, new user, so forgive me if I'm out of my league here, but one observation comes to mind - the acceptable envelope for EV mode (temp, SOC, speed, acceleration) use is pretty tight. Wouldn't the reasons for that be as much for protection as performance?
    I mean, Toyota can't predict when you're going to use it, they can only react when you do?
  2. Tande
    Tande Active Member
    503
    302
    Mich.
    We sure think alike! :eek:......
    49,813
    yes!:)
    49,813
    yes!:p
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The problem with this line of reasoning is that during warm up the Prius tries to run the engine without making power. Engine control parameters are shifted to make heat, not torque. This is done for emissions, and is the reason that the Prius draws heavily on the battery for the first minute or so.
    Ideally you want enough charge in the battery to support this mode of operation, and you don't want to accelerate heavily or you force the ICE to provide propulsion, which hurts mileage and emissions. Running down the battery the night before works against this normal mode of operation.
    Tom
