Beeping with no indicator lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by siouxscout, Dec 15, 2014.
  1. siouxscout
    siouxscout New Member
    knoxville, tn
    I've been having an on going issue where my Pirus will start beeping but there is no indicator light I can see showing any kind of issue. It will start beeping during startup and after driving for a while, no exact time something like after 25~30 mins. It sounds like the seatbelt beep but louder and both will beep when my wife does not have hers on.
    I replaced the Aux battery(was old needed to anyway) with a yellowtop but that didn't fix it. And again there is no indicator on the dash or display showing issues no red or orange triangles. Checked the prius's diagnostics but no codes appear under the diagnosis check I or II, sycheck mode or LAN monitor.
    If you've managed to read through all this does anyone know what could be causing this? Might be nothing, but its on every startup. Not sure what else I could check really. I disabled the backup and seatbeat beeps thinking it might be related idk.
    49,089
    just a wag, but how about your fob battery?
  3. siouxscout
    knoxville, tn
    Yea forgot to mention that. I replaced the fob battery and the Aux battery but no change.
    #3 siouxscout, Dec 15, 2014
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
  5. Patrick Wong
    18,200
    6,464
    Check all engine compartment fluids, especially engine oil level.
  6. siouxscout
    knoxville, tn
    Checked the oil and brake fluid, they're fine. Haven't checked the transmission oil of course but might end up getting that changed here soon. Still no lights on the dash. Last night it actually didn't come on one of the starts while I was out(1 out of 5 it did beep), first time in a long time. But its back to beeping on every start.
  7. bisco
    49,089
    sounds like a call or trip to the dealer. do you have an aftermarket alarm or anything? how long have you owned the car?
  8. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    Are you the original owner? Is it the same sound as the normal beeps?
    I had one that did that and it was a GPS tracking device that had been installed inside the dash. Sometimes buy here-pay here dealers do that to find cars when they are delinquent. The beeping is to alert the customer that the car could be shut down.
  9. Jimmy219
    Jimmy219 New Member
    Houston
    This exact thing just happened to me. It took me a moment to realize that although nothing was blinking on the dashboard in front of me, the passenger seat belt light over on the right side was blinking. I had a heavy bag sitting in the passenger seat, and I had just taken a right turn rather hard. I reached over and buckled the passenger seat belt and the beeping stopped. The seatbelt beep is disabled, but it still beeps when the passenger weight sensor is tripped and the belt isn't buckled.
    #9 Jimmy219, Sep 21, 2016
