better MPG with seats up?
Discussion in 'Prius c Fuel Economy' started by GeoZoo, Dec 15, 2014.
  1. Dimitrij
    Dimitrij Active Member
    405
    202
    Virginia
    None of my business, but why do you usually drive with the seats down? If this is to haul a few hundred pounds of your work gear, that might explain the difference .. I am just being facetious :giggle:
    It has now occurred to me that passenger-less cars are always loaded more on one side, and in the case of a small car a 220 lb driver contributes 7-8% of the total vehicle weight. Is this known to affect the mpg and the tread wear in any measurable way?
    49,131
    how do you measure it against a driverless car?
    Tony D likes this.
  3. orenji
    orenji Senior Member
    5,884
    3,486
    Google cars are used
    49,131
    there you go.
  5. Dimitrij
    405
    202
    Virginia
    Not driverless, but with the same load in the driver's and front passenger's seat (e.g. a petite driver, accompanied by five friendly Norske Skogkatter)
  6. wjtracy
    wjtracy Senior Member
    11,317
    3,588
    Northern VA (NoVA)
    I have previosuly posted GM's approximation equation for MPG impact of weight.
    Suffice it so say if my wife gets 50 MPG alone, it could be closer to 48 with me and my wife.
    Brings up a question, we ought to normalize Fuelly MPG for passenger wieghts, but nobody want to go there I guess.
  7. bisco
    49,131
    it would be an interesting study. i would think most vehicles put the majority of mileage on with one driver. and we know must green car drivers are lightweights.:cool:
  8. OldNo7
    OldNo7 Member
    72
    26
    CT
    2014 Prius c
    This thread was a riot to read. I have nothing to add but the sound of me LOL as i read post after post!
    Sorry to the OP, he was serious. I am inclined to believe his observation of mpg vs seat position has to do with some correlation vs cause and effect. Kind of like I've noticed I tend to get more drunk sitting on a bar stool than any other chair style.
    Tony D, ftl, orenji and 2 others like this.
  9. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    i noticed that when i drive with the bonnet (hood) up that my mpg goes right down. also, the twice ive done it, I've crashed as I couldn't see where I was going!
    My question is, should I drive with the bonnet open due tot he effect it has on my mpg?
  10. Dimitrij
    405
    202
    Virginia
    I don't know about the mpg, but someone called Tony would sure look rather cute in a bonnet :)
  11. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    Try reverse maybe???
    OldNo7 likes this.
  12. orenji
    5,884
    3,486
    Remove the bonnet, problem solved!
  13. Tony D
    468
    132
    Dublin, Ireland
    Cheers lads. I will try reversing everywhere first as removing the hood/bonnet might be a bit drastic. Maybe I should remove the boot/trunk door to improve visibility? The lengths we go to improve our mpgs!
  14. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    And if you turned your seat to face rearward, then it would be like you're going forward!!!
  15. Tony D
    468
    132
    Dublin, Ireland
  16. NDcowPoke
    NDcowPoke Junior Member
    Where the the West begins
  17. NDcowPoke
    Indeed he is
  18. wjtracy
    11,317
    3,588
    Northern VA (NoVA)
    ...put the seats down and now you got a pick-up truck
