1. Offline
    priusCpilot Member
    Start a Conversation
    Mar 6, 2012
    242
    42
    LA
    Your Vehicle Year:
    Here is the report. Looks good with almost no wear metal so changing the oil before 10k miles is not needed it seems. TBN was 8 so this Toyota oil should look good even up to 10k miles. At 10k I will send for another sample.
    6 people like this.
  2. Offline
    strongbad Member
    Oct 19, 2011
    128
    28
    Arroyo Grande, CA
    Your Vehicle Year:
    Thanks for posting this. The 10kmi sample will be more meaningful and it will take several changes for the silicon levels to stabilize, no doubt. How did you draw the sample and is your car burning oil?
  3. Offline
    priusCpilot Member
    Mar 6, 2012
    242
    42
    LA
    Your Vehicle Year:
    I used Blackstone pump from the dipstick. The oil level was exactly on the F line before so no oil consumption. I then added the small amount back using Toyota 0-20w oil.
    I was wanted to see just how well the assembly process was for this test. They do a great job cleaning and machine everything during assembly with out a doubt. Ill post the 10k once I am ready for it and also the 20k after that.
  4. Offline
    actiondonkey Junior Member
    Mar 9, 2012
    81
    Your Vehicle Year:
    Great info, I've been nervous about this.
    I've always changed the oil at 1-2k miles on a new engine and was hesitant when Toyota said first change is at 10k. Now if I can just get them to use the royal purple instead of mobile 1:D
  5. Offline
    kkim Active Member
    Jan 27, 2007
    381
    120
    kauai, hawaii
    Your Vehicle Year:
    Is the oil that comes from the factory synthetic or conventional motor oil?
  6. Offline
    vinnie97 Whatever Works
    Mar 20, 2010
    856
    67
    Somewhere out there
    Your Vehicle Year:
    It had better be synthetic!
  7. Offline
    priusCpilot Member
    Mar 6, 2012
    242
    42
    LA
    Your Vehicle Year:
    Yes it is. The Toyota 0/20w is Synthetic and that is the only oil I would use.
    1 people like this.
  8. Offline
    wick1ert Senior Member
    Dec 3, 2009
    1,301
    173
    Delawhere
    Your Vehicle Year:
    If you do a lot of shorter trips, you should probably re-sample at 5k as well. It'll give you a good middle reading also. I'm going to switch back to 5k changes, because most of my drives are 5 miles or so each way, which puts me in the "severe use" category.
  9. Offline
    priusCpilot Member
    Mar 6, 2012
    242
    42
    LA
    Your Vehicle Year:
    Hmm I would say maybe 10% are short like 3-4 miles. It might not be a bad idea. Maybe I might just do it to see at 5k how it all looks. Im at 2k now so won't be long.
  10. Offline
    rioe Junior Member
    Apr 17, 2012
    73
    LA, CA
    Your Vehicle Year:
    Just wondering if you did do the test again at 5K miles or 10K? Assuming you have reached those miles.
    Im very interested to see the results.
  11. Offline
    priusCpilot Member
    Mar 6, 2012
    242
    42
    LA
    Your Vehicle Year:
    Oh check under the tech section for it.
Share This Page
