Bleeding boards mod help
Discussion in 'Prius PHEV Plug-In Modifications' started by Flying White Dutchman, Jul 2, 2012.
  1. Flying White Dutchman
    4,374
    313
    These bleed at 3.7 volts and up
    I want them to start sooner
    When back on pc i get some more info
    -Htc Tapatalk ( sorry for auto spell correct )
  2. mrbigh
    3,686
    699
    Long Island, NY
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    OK I''ll bite, what is a bleeding board. I will assume it is some sort of voltage regulator set for 3.7v? If you want a lower voltage I would think changing the values of the board resistors maybe the way to accomplish this.
    A schematic sure would be nice!
  4. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    A bleeding board is a BMS for a single LifePo4 cell, in this case it is a A123 20ah pouch cell. It just top balances but it has no voltage protection.
    I guess you can call it a poor man's BMS top balancer.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    This is a break off from FWD's other thread.
    Elcon Charger End voltage and other mods | Page 2 | PriusChat
    He said he would start a separate thread about modifying his bleeding boards.
    Basically the boards bleed off extra energy when charging to prevent a cell from getting charged too high.
    Right now it sound like these do not start their bleeding off process until the cell's voltage reaches 3.7v.
    This is higher than FWD wants.
    Instead he wants to lower it to something like 3.45v, 3.5v or maybe even 3.6v.
  6. Flying White Dutchman
    4,374
    313
    yhea thats right
    these start at 3,7 with 100mAmps and at 3,8 its something like 300mAmps
    i was thinking that a different SMD ( yhea small dammm ) resistor would do the trick but have no clue where to start.
  7. mrbigh
    3,686
    699
    Long Island, NY
    A simple Ohms Law will suffice with the equation to help alleviate that offending voltage.
    - - - Yeah, the schematic will simplify a lot ;)
  8. lopezjm2001
    1,146
    407
    Sydney Australia
    Need better photos. Focus is bad. They need to be taken closer using the macro function. Cannot read SMD resistor values, cannot trace PCB tracking etc.
  9. jaso
    jaso Junior Member
    Hi Dutch,
    It looks like R1/R2 is your voltage divider for U1A shunt regulator.
    To lower yor shunting (bleeding) voltage you need to decrease R1 or increase R2.
    R1 is probably parallel R1A, R1B, R1C, R1D and R2 is parallel R2A, R2B, R2C, R2D.
    I can't give you the exact value as the resolution of your photos is too low.
    BTW: Hope charger upper voltage limit and this bleeding boards are not the only protection
    you have in your system - it's definitely not enogh.
    Jacek.
  10. Flying White Dutchman
    4,374
    313
  11. jaso
    jaso Junior Member
    According to my calculation your bleeding should start at 3.66V. If you just remove R2D (105 = 1MOhm) you will get 3.61V for start bleeding voltage.
    The rule is: whenever voltage at R2 (ABCD) is above 2.5v this circuit start shunting.
    So:
    Vshunt/R1+R2 = 2.5V/R2
    Regards,
    Jacek.
  12. Flying White Dutchman
    4,374
    313
    I have some spare boards i can test by removing it and run it on one cells and one cellharger i have.
    Thx!!!!!
  13. lopezjm2001
    1,146
    407
    Sydney Australia
    Hi Jacek,
    Can it be modified to start bleeding at 2.5v.
    Thanks.
  14. jaso
    jaso Junior Member
    Hi John,
    When you open R2 or short R1 then it in theory should start bleeding at 2.5V. But U1B regulator has some accurracy (lets say 5%) so thats why they provide 4 positions for each of the R1 and R2 - for final tuning.
    Regards,
    Jacek.
  15. Flying White Dutchman
    4,374
    313
    because these boards do around 100mApms at 3,7 volts
    anything lower i can not really control the charger to and its really low is it not.
    you say they start at 3,66 and i see 100mAmps at 3,7 so remove R2d ( remindes me of R2D2 ;-) ) and start at 3,61 would mean 3,65 volts and 100mAmps
    correct?
    3,65 is nice but looking at above something lower is recommend..
    what if i remove R1B instead..
  16. jaso
    jaso Junior Member
    Hi Dutch,
    Removing any of R1 will increase bleeding voltage. I gave you the rule...
    You can replace R1C (475 = 4.7MOhm) with lets say (225 = 2.2MOhm) to go further lower with the voltage.
    Some checking is needed.
    Jacek.
  17. Flying White Dutchman
    4,374
    313
    o sorry i read it wrong and write it the right way
    i was aspecting R2B but its R1B
    so no use removing that one i have to increase when its R1
    i will first do a remove R2d
    there is only one R2 wil this not be a problem when i remove it. so there are no longer any resistors? for R2?
  18. jaso
    jaso Junior Member
    You can not remove R2A - if you remove it you will get about 2.5V bleeding voltage.
    Jacek.
  19. Flying White Dutchman
    4,374
    313
    S8550
    D128
    And
    431
    Thats what you also taken onto account with removing. R2d ?
  20. Flying White Dutchman
    4,374
    313
    I removed one and the bleeding board did not do anything.
    So according to above new pics and info still site about it?
