Braking issue
Discussion in 'Gen 3 Prius Main Forum' started by Air0ne, Aug 30, 2014.
  1. Air0ne
    Air0ne Junior Member
    Montréal
    Hi there,
    It's the first time I post here so please, forgive me if I'm doing things the wrong way...
    I got a braking issue today and I'm not able to drive my car anymore. I have a 2010 Prius with a continuous beeping sound, ABS and warning lights ON. I can hear a small sound (pulsing, cranking, vibrating) in the engine compartment after the hybrid system is started. I guess this is the actuator.
    Could you help me guys?
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Welcome to Prius Chat. You did everything right on your post. Don't have the answer you need, but did want to say "Welcome".
    Ron (dorunron)
    Air0ne likes this.
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    This is an issue that ONLY the Toyota Dealer can resolve. I hope your problem is the result of failing to do the recall (last year). Otherwise, it might be a $2,000 repair.
  4. Air0ne
    Montréal
    So my guess is right? They did 2 recalls. I don't remember what they did for the first one, but the second involved a flash of the computer. 2000$ ??? give me 1 minute. I will suicide myself and come back later...
  5. xpcman
    1,302
    295
    Back in June 2013 they had this recall:
    Toyota says it is recalling about 87,000 2010 Toyota Prius and Lexus HS 250h vehicles because of a brake problem.
    The issue involves a brake pressure accumulator that may develop a fatigue crack on an internal part due to vibration. Toyota doesn't say what the result could be, but it sounds like it would be a loss of braking pressure.Toyota says it has had no reports of any accidents or injuries due to the problem.
    Owners of vehicles subject to this recall will receive a notification by first class mail. The recall remedy will involve inspection of the brake booster pump assembly to see if it is equipped with an involved accumulator. If so, the dealer will replace the brake booster pump assembly with an improved one at no cost to the customer.
  6. Air0ne
    Montréal
    I definitely have a big loss of braking pressure. I can brake but it's obviously longer than before... I just bought that car a year ago...
  7. Air0ne
    Montréal
    Hi there,
    Just an update. Toyota Canada took care of the case more than 2 weeks ago. My car is still being reviewed by Engineers but they will pay the bills (they rented a car for me also)
