1. Offline
    tedjohnson Member
    Start a Conversation
    May 21, 2010
    282
    45
    Greenfield MA
    Your Vehicle Year:
    Anyone else unable to get the latest scanguage to get a reading for BT2f to work. Is it my unit ? I get no reading at all. Entered it 3 times and nothing. Thanks. Ted
  2. Offline
    jdcollins5 Senior Member
    Aug 30, 2009
    3,272
    648
    Wilmington, NC
    Your Vehicle Year:
    From BT2f I take this to be the No. 2 HV battery temp. It works for me as I use this as the main battery temp since it is located in the center of the battery and is usually the hottest. What SG do you have and what firmware revision? What configuration parameters are you using? Also, can you get the other battery temps to read?
  3. Offline
    tedjohnson Member
    May 21, 2010
    282
    45
    Greenfield MA
    Your Vehicle Year:
    Found the problem Adrian Blacks spreadsheet is wrong . The scanguage site has the correct settings. Works now.
    jdcollins5 likes this.
  4. Offline
    tedjohnson Member
    May 21, 2010
    282
    45
    Greenfield MA
    Your Vehicle Year:
    I used Adrian's spreadsheet for the codes but after 4 tries at entering it . I went to the Scangage site and used the BtT (or was it BTt) codes and it worked properly....Latest scangage hardware and software....
Share This Page
