Cabin Heater in EV Mode
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by pauerbach, May 29, 2014.
  1. pauerbach
    pauerbach Member
    101
    34
    I don't own a plug-in, but I'm curious:
    If you turn the heater on while in EV mode, does the gas engine have to start? Is there an electric cabin heater?
  2. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    The only heat source is the engine.
  3. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    True, but it's not that horrible as it sounds:
    1. The engine (ICE) heats up ridiculously quick then it shuts back off.
    2. The amount of fuel burned is little. Furthermore, nothing gets wasted: the kinetic energy of ICE is used for additional locomotion and/or battery charging.
    3. The front seats are heated, so you can opt to heat yourself alone, instead of entire cabin.
    Will Stewart likes this.
  4. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Also, additional heat is captured from hot exhaust once the engine is at running temperature. As Rozi points out, the seat heaters are an option and the high setting goes a long way toward providing comfort.
  5. Mendel Leisk
    38,260
    How much do the seat heaters reduce EV range?
  6. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Don't seem to affect it much at all, not enough to have a clear idea of it. The main problem is demisting the windscreen; if the PiP had that electrically heated like my old Ford did, I'd be very happy to do without the heat a lot of the time.
  7. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    Cabin heat is provided by engine coolant, just like traditional cars.
    However, once that coolant is warmed, the engine will shut off and stay off until it drops below a minimum temperature.
    In the meantime, you'll be able to drive along in EV without disruption to the heat being provided by the heater.
  8. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I use the bun warmers. Unless it's ridiculously cold. Rarely gets that way in SoCal
  9. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Each seat heater (driver/pass) has a 10A fuse.. so probably somewhere in the neighborhood of 100 watts per side.. so it'd be hardly noticeable
    Pluggo and Mendel Leisk like this.
  10. 13Plug
    13Plug Active Member
    581
    104
    2013 Prius Plug-in
    The seat heaters do not detract from EV range any noticeable amount, and they are the fastest, hottest seat heaters I've experienced.
  11. El Dobro
    El Dobro A Member
    6,973
    3,209
    On very cold days, for a quick run to a local store, I used the seat heater, for a long run, I turned the HVAC on.
  12. GregP507
    GregP507 Senior Member
    3,002
    480
    The ICE warms up the engine coolant very quickly by routing it through the exhaust system (similar to some airplanes). We had a few days of -20C weather here shortly after I bought my PiP, and I was amazed that the heat began coming out of the vents after only about 3 minutes of running time.
