calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. LINKSTER
    LINKSTER LINKSTER
    los Angeles
    I believe I have some valid information to share on MPH Indicated vs Hand Calculation. I have a 2010 (Version 4) built 05/2009, with 49,000 miles. I have calculated each tank of fuel since 6/27/09. This time period represents 134 calculations. Fueling was stopped on the first click. Without exception, the FCD vs hand calculated MPG runs in the range of 3.4%, higher than the hand calculation. I believe this number to be very accurate. I live in LA with fair weather driving 100% of the time. I estimate from my records that I average around 48.5 mph. This is the first time I have posted in a number of years and I hope this adds to your data bank. I have another significant situation to to share with you about what happened after an EFI procedure was performed, but I don't know if this is the correct Forum to present it in. Please let me know.
    Linkster
  2. qdllc
    qdllc Senior Member
    1,358
    396
    Last fill up....
    Trip data on Prius said I got 58.8 mpg. Math from gassing up said 55.6.
  3. fermuscolo
    fermuscolo Member
    53
    38
    Prius C 2012 over 5000 miles and 13 fuel ups , Car says 57MPG Fuelly says 51.4MPG
  4. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    • 58.8MPG(mid)/55.6MPG(tank) = 1.058 ≈ 6% optimistic (high)
    •57.0MPG(car)/51.4MPG(tank) = 1.109 ≈ 11% optimistic (high)
    Those are rather widely varying numbers.
    #1044 70AARCUDA, Aug 28, 2014
  5. Dotmatrixxx
    Dotmatrixxx New Member
    909 southern Cali
    I got the update and noticed ever since then I fill up my tank and says I have about 420 miles until next fill. I do t get how everyone is getting up to 500+ miles. I have a 2013 Toyota Prius 5. I believe it's the gen 3.
  6. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    61.3 on screen but Real Math 59.32
  7. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    Just filled up my first full tank on the new Prius.
    535 miles - Computer = 60 mpg / Calculator = 55.7 mpg
    #1047 Oskar, Aug 30, 2014
    Dotmatrixxx likes this.
  8. Mendel Leisk
    38,260
    I don't think I've ever looked at that gauge. If you want to track your mileage:
    1. Develop a consistent fill-up style. I'd recommend to pump 'till the pump shuts off, then stop.
    2. Note the odometer reading. Regardless of what gauges or showing, whenever you shut off the car this number will persist, for about 30 seconds.
    3. Repeat #1 and #2. This'll give you distance travelled and fuel consumed, the two factors of calculating miles per gallon.
  9. PriusByrds
    PriusByrds Junior Member
    Burlington, NC
    Our early version 2010 Prius IV, purchased in June, 2009, has had 141 fill-ups over 54,373 miles (odometer reading at last fill-up). Lifetime calculated mpg = 46.8; lifetime display mpg = 49.5. Every fill-up ends when the pump auto-stops. Most of our driving consists of short, 5 to 6 mile trips around town, with occasional long, interstate trips of several hundreds of miles a couple of times each year.
  10. 70AARCUDA
    845
    209
    Tucson, AZ
    ALL the above MID-vs.-calculated (tank) MPG numbers simply AMPLIFY my original contention that the MID-calculations performed by the computer in the Toyota Prius are OVER-estimating fuel economy...for whatever reason...and doing so rather consistently.
    Why this is happening, I have no idea, but with the help of a ScanGaugeII™ I was able to determine that the major cause of similiar problems with our 2011 Cruze LTZ was the result of how long the engine was staying in 'open-loop' A/F-operation (during warm-up) before switching to 'closed-loop' A/F-operation (normal engine temp & operation). There was an almost 1-to-1 correlation between the MPG ±error and the length of 'open-loop' operation--the longer the 'open-loop' time, the more the MPG error.
    #1050 70AARCUDA, Sep 1, 2014
  11. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    My last 2 fill ups the computer read approximately 3 mpg more.
    -Computer: 53.8, calculated: 50.82
    -Computer: 52.7, calculated: 49.76
  12. Dotmatrixxx
    909 southern Cali
    Well I just got 320 miles on a tAnk. And it was like33 or 34 mpg!! Which I know something is wrong. I think a Honda civic gets more. Lol and I see people on here saying there driving over 500 miles on a tank of gas. When I first got it and I would fill up the car would tell me I had 520+till next fill up. And I know it could be more or less depending on how u drive and blah blah!! Now I fill up and it says 420 or 405miles till empty tank and it's really getting like 320 or sometimes a little more. This really is annoying. It happened ever since the update. I JUST WANT TO KNOW WHEN PEOPLE FILL UP THERE TANKS HOW MANY MILES DOES IT SAY TILL MEXT FILL UP!!! It's not a hard question . NOBODY SEEMS TO ANSWER IT. !!
  13. kenichols29
    250
    109
    Mckinney, Texas
    Mine says 540 to 550.
  14. PriusRook14
    PriusRook14 Junior Member
    Just fuelled up my Prius for the second time(about 440 miles between fuel ups), 56.0 computer vs 52.8 fuelly, difference of about 6%.
    #1054 PriusRook14, Sep 8, 2014
  15. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    What's amazing about the mpg comparison is that in almost every post there is a difference of approximately 2 to 3 gallons, where the Prius computer is on the higher side. I can understand it if the gap is all over the place but because of the slight, consistent, it seems that the computer put in the Prius is pretty much calibrated the same for all models, and for most years.
  16. 70AARCUDA
    845
    209
    Tucson, AZ
    Which is the basis for my two-word summary: Consistently optimistic.
  17. zebekias
    zebekias Member
    101
    35
    Greece
    For my last tank of gas...
    Computer: 4.0 l/100 km
    Calculated: 4.25 l/100 km
    6% optimistic
  18. kenichols29
    250
    109
    Mckinney, Texas
    Just filled up my tank today.
    Car computer 59.9
    Actual 56.5
    This was with pure gas not that E10 Cr@p.
  19. 70AARCUDA
    845
    209
    Tucson, AZ
    Apparently, nobody (as yet) has felt the need to monitor & record that information; I know that I don't and haven't.
    Why? Because that information is based upon the PAST mpg the engine computer calculated, which is NOT truly applicable to what's GOING to occur in the future...although it *IS* a better "guesstimation" than nothing-at-all.
  20. qdllc
    qdllc Senior Member
    1,358
    396
    IIRC, at a full top off, my rating is just over 600 miles.
