calculation details of Volt's 230mpg city estimate
Discussion in 'Chevrolet Volt' started by john1701a, Aug 18, 2009.
  1. Politburo
    Politburo Active Member
    971
    208
    You pay $0.0004 per kW-hr? [​IMG]
  2. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
  3. daniel
    14,487
    1,518
    Spokane, WA
    When the Volt concept was first announced, I thought that was the way to go: EV for in-town trips, gas for road trips (until the electric highway becomes a reality). But I've changed my mind. A PHEV or RE-EV is carrying the dead weight of the engine when in EV mode, limiting the amount of batteries the car can carry, and is carrying the dead weight of the batteries on road trips, reducing fuel efficiency. It's the worst of both worlds, a lose-lose situation. I now believe a much better solution (especially considering that most American families have more than one car!) is to have a pure EV for shorter trips (which can be longer because a pure EV can have more batteries) and a hybrid like the (non-plug-in) Prius for road trips, which can be optimized for fuel efficiency without the dead weight of additional unnecessary batteries.
  4. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    For MY needs, I think daniel is right: EV + Hybrid, 2 car household, done.
    For some possibly including me, I think the PHEV Prius will add appreciable fuel economy at a modest weight increase with local miles largely from the plug. Some of us just have trouble un-cutting the cord, so to speak. We just cannot all get to perfect at the same pace. Needs change through life, and changing cars is an expensive and unpleasant event (negotiation, taxes, etc).
    The Volt could work for some, but we need an actual car to see. Trust is low there.
  5. hampdenwireless
    1,104
    86
    Baltimore MD
    The weight of the Volt's battery is around 375lbs. The Prius battery is around 110lbs. The difference is what is important not the entire weight as you are getting the hybrid advantage out of the battery especially in the city. When in the city after the battery is not providing power 260lbs of dead weight does reduce the mpg but if you are 90% on electric only power it really won't matter that much.
  6. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    Actually, the battery weight only part of the story. There's other stuff that adds to the overall.
    Turn outs, Volt is 850 pounds heavier than Prius!
    Interesting, eh?
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Interesting... yet the Volt is smaller than Prius. It is about the size of the Insight. So the Volt is more than half a ton heavier than the Insight II.
  8. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yes that is interesting. So the battery is about 265 lbs heavier but the overall vehice is 850 heavier. So that's nearly 600 lbs of "other stuff".
    This would make sense. The ICE in the prius and the volt would probably be similar in weight but the electric motor in the volt would have to be heavier, given that it has to power the car single handedly even under the most demanding conditions. I think it's something like 110 kW for the Volt versus about 50 kW for the Prius. That's where I'd bet the majority of the extra weight is coming from.
  9. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    [/QUOTE]The Volt goes 40 miles on battery, then operates on a mode just like this prius, so why is it so hard to believe it can get 50mpg after the battery depletes?
    I can't wait until it comes out, it's going to make the prius look like a gas hog and setsthe bar for what cars should be.[/QUOTE]
    Pretty long on expectations, but short on facts. The Volt is "just like the Prius." Wrong! The Volt's ICE is not cnnected to the wheels ... only to the generator.
    But that is not my issue with the Volt. I suspect the Volt will be sensational for 40 miles. But how many "real world" drivers have only a 40 mile range (commute)? How many can afford a very $$ car that only has one function (commuting)? Everyone I know that has only one car uses it to commute, go to church, to the store, the library, go visit Grandma, and to take vacations. Here in the West, many non-work related trips are longer than 40 miles (round trip).
    Inasmuch as we all own GM, I want the Volt to be a success. It just does not fit into my life style. Hopefullt the day will come that charging stations will be available at work, the market, and along the highway.
    I read a very enlightning article about driving a Tesla on the German Autobon ... at excessively high speed. The range was deminished down to a few miles, and the author had to be careful just to get back home. I suspect all the power hungary devices on teh Volt, plus speed, will deminish the 40 mile range. We shall see.
  10. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    But when you are 90% on electric only, you are carrying around an ICE and generator you don't need. How much does that weigh?
  11. daniel
    14,487
    1,518
    Spokane, WA
    Here's the really sick part: We "own" GM but "we"ve allowed the same old criminals to continue running it. Since those criminals get to decide how available revenues are distributed, you can bet that they will declare huge salaries and benefits for themselves, and no dividends for us stockholders.
    We should have either let GM go under, and sold the assets to other automakers, or done as Michael Moore suggested, and taken control of it and converted it to the manufacture of infrastructure for a sustainable energy economy.
    Exactly! The Prius is designed for maximum efficiency. The ingenious PSD functions to channel most of the power directly from the engine to the wheels at high speeds, where that is most efficient, and most of the power to MG1 acting as a generator at low speeds, where that is most efficient.
    The Prius utilizes all its components all the time (except for the very brief periods when the ICE is off).
    The Volt carries the dead weight of ICE and generator during EV mode, and the dead weight of the empty battery in CS mode.
    The Volt is always carrying the dead weight of the unused half of its power train. It's the wost of both worlds.
    People who can only afford one car will be better off with a Prius or a used Civic or Corolla if they need a long-range car at all, or a pure EV if they don't. People with two cars will be better off with a pure EV and a Prius or Civic or Corolla.
    Most families in cities like Spokane could cut their gasoline usage in half by trading off one of their gasoline cars for a Zap Xebra.
    The big folly of the Volt is that it assumes you need one car that is an EV for short trips and a gasoline car for longer trips, and then it prices it out of reach of people who can only afford to own one car. But of course GM wants the Volt to fail just as it wanted the EV1 to fail, so pricing it at $40,000 makes sense to them. Again, we own GM but we are allowing it to be run by criminals who are acting against the interests of the country!!!
  12. hill
    8,071
    But Daniel, the good news is Lutz is gone . . . again!
    Hopefully this is just a first of many good signs.
  13. hampdenwireless
    1,104
    86
    Baltimore MD
    Actually in CS mode the battery is acting as part of its hybrid drive train soaking up power during braking, it is not dead weight.
    GM's engineers have gone under the theory that doubling the battery size (as the Leaf does) would weigh more then the ICE and limit its range to 100 or so miles like the Leaf. Having a gas generator as a back up is not such as bad idea while charging stations are for the most part hard to find.
    Why is it so hard for people to understand? The Prius has its market. The Leaf has its market and the Volt will have its as well.
    Prius - All around efficiency but for the most part entirely dependent on gas. Best price of the 3, most trusted and a known quantity. Works great in a one car family.
    Leaf - Ultimate efficiency for people who do not need more then 100 miles range, perfect for a two car family or others who will rent for long trips. Totally eliminates need for oil/gas and plays to the people who do not want to support big oil AT ALL.
    Volt - One car family that can plug in and has a 20 or so mile commute. This is a whole lot of people. Costs more and an unknown quantity (like the Prius was 10 years ago). Can nearly eliminate need for gas (95% reduction for ideal user). Also plays well for people who want to eliminate support for big oil.
    More choices rock! :rockon:
  14. john1701a
    12,749
    5,243
    57
    Reality check...
    The price of gas is going up as the economy recovers. Toyota & Ford both really want to push hybrid growth. Consumer priorities are shifting over to efficiency. Price continues to be a major purchase decision factor.
    GM hasn't strived to meet requirements of the market. Volt is poorly configered to address those realities. It's the classic want verses need problem.
    Unfortunately, history has taught us that with clever marketing we can be convinced to buy something we don't actually need.
    Time is working against them. Those of us with years of market observation know that pressure is building and the hype is going to be instense. Studying their wild claims now is how we prepare to deal with that inevitable upcoming greenwashing storm.
  15. john1701a
    12,749
    5,243
    57
    No choice is the problem.
    Shopping for a GM your efficiency choice won't include a high-efficiency midsize, midprice vehicle. There won't be anything between Cruze and Volt.
    Hybrids like Prius & Fusion fulfill that middle-market need nicely. What will GM customers buy?
  16. ljbad4life
    ljbad4life New Member
    365
    24
    what about the ford customers and toyota customers that want high efficiency, small size, low priced vehicles? the corolla that gets 1 mpg better than a camry? Ford looks to improve the current focus and will be approach 40mpg while the corolla is sitting at 34. Toyota doesn't have any smaller or less expensive hybrids than the prius and Ford doesn't have anything smaller than the Fusion Hybrid.
    Where's the choice?
    Each company choose to ignore specifc markets. If GM is heading for a specific market then thats fine. 40k may be a to expensive for some, but it won't for others (take a look at how many expensive cars are on the road).
    Each car will have it's market, no matter what a person's negative feelings are.
  17. vegasjetskier
    269
    29
    The Focus is currently at 35. 1 mpg will not make me buy a Ford product. Don't you think Toyota is striving to improve it's fuel economy as well?
  18. hampdenwireless
    1,104
    86
    Baltimore MD
    2010 Chevrolet Malibu 1LT - Yahoo! Autos
    The Chevy Malibu of course. Its 33mpg highway is the same as the Camry gas model and gets good reviews, good quality and lower real world price. Let me set this straight... I would not buy it but its not a bad car and all of those things: midsize, midprice and high efficiency.
    Now back to topic!
  19. ljbad4life
    365
    24
    Toyota is sending mixed signals about increasing fuel economy. why is the camry hybrid still at the same mpg as it was introduced? Why is the HSD in the Highlander hybrid still mated to the v6 instead of the i-4? why doesn't toyota have any class leading mpg in anything that isnt a prius?
  20. john1701a
    12,749
    5,243
    57
    Let's try again: In 2012, what will people buy?
    Camry is due for a new model upgrade and a hybrid RAV4 is on the way. Choices are on the way.
    You have around $25k to spend and you want a midsize 40 to 50 MPG vehicle. Why? Because you are among the largest market, the business-sustaining group that provides a bulk of the profit. What will GM be selling to these consumers?
    Think about the price of gas then and how deeply entrenched into the market hybrids will be. What percentage of production will they be for each automaker?
