can 2010 Prius run on gas only?
Discussion in 'Gen 3 Prius Main Forum' started by cjboutte, Sep 16, 2014.
  1. GregP507
    GregP507 Senior Member
    3,002
    480
    I don't believe in concealing car problems, just to get it sold.
    It's just a "do unto others" complex I seem to have...
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It was meant in jest and a stab at the previous owner who potentially knew of these issues that the OP has just experienced. Call me cynical, but for these problems to occur just a few thousand miles and a couple of months into new ownership smells to me.
    But I guess you have a similar law of buyer beware in the US?
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    The other thing I've seen is people and used car lots, replacing a single failing cell, then quickly selling the car before the car starts throwing codes again. Sad, really.
    Hopefully karma catches up with these people.
  4. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    With a car with the many miles on it, anything could break at any time can't blame the old owner all the time.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    When I was younger...well young PERIOD. I made some very bad used car purchases.
    Oddly perhaps, I would invest a lot of time and money into fixing whatever problem or problems had revealed themselves. Then because of the problems I had...I would have such a bad taste in my mouth about the vehicle I would THEN sell the vehicle at usually a substantial loss.
    I guess I always felt it was unethical or wrong to NOT reveal a problem with a vehicle.
    However, a lesson I learned pretty early, is that unfortunately there is a lot of the rest of the world that doesn't feel the same way.
  6. GregP507
    3,002
    480
    I hear ya.
    "Do unto others what others have done to you." Pass it on...
  7. seckwielen
    seckwielen Member
    112
    26
    I was stung by the orange battery plug not being seated correctly when I removed it when I first got my vehicle.
    Once seated. You must slide it sideways into place.
  8. cjboutte
    cjboutte Junior Member
    Port Acres Tx
    Code did come back and I decided to remove the battery and test the individual module voltage. All models read between 7.59 - 7.48 volts. The Majority of the moduls are at 7.53 with the ones on both ends of the pack at 7.59 and three module at 7.48 grouped together. Are these good voltages, is the three grouped together with the lower voltage a problem, could the battery cooling fan be the problem (it was fairly dirty)?
  9. bisco
    49,068
    voltage's seem okay, the fan could definitely have been the problem.
  10. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Has the car had the inverter reprogram mod. done? It -could- be the inverter is damaged. It should be warranty on that, even with that many miles, as that's a recall.
  11. cjboutte
    Port Acres Tx
    I called Toyota consumer affairs and was told there are no outstanding recalls on my Prius. The representative did say the Intelligense power module is covered for 15 years unlimited mileage. So either my vin didn't fall in the recall or it was already done.
  12. bisco
    49,068
    perfect.(y)
