Carbon build up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Zero, Aug 27, 2014.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Is the Prius more or less prone to carbon build up compared to a normal car?
    My work has a fleet of Prii used for security patrol and they never see any thing other than parking lot speeds. They are 2012s and have about 50K miles on them and they all ping when the ICE fires up.
    Considering the low compression ratio on this motor I am thinking there is some serious carbon build up. Of course these being Prii and company cars no one gives a crap except for me.
  2. Former Member 68813
    3,524
    981
    US
    What low compression ratio?
  3. ETC(SS)
    6,496
    Build up carbon where?
    From what?
    Monitor your fuel efficiency.
    Check your oil consumption rate.
    If both remain constant, then you have no issues with 'carbon build-up.'
    Good Luck!
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    I am thinking carbon build up in the combustion chambers. These are company cars and I have no access to monitor anything except for the ungodly noises they make when they drive by.
    My understanding is that the Atkinson engines on the Prii have an effective compression ratio of 8:1 and expansion ratio of 13:1.
  5. Former Member 68813
    3,524
    981
    US
    Most toyota engines have compression near 10:1.
  6. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    What gasoline do you guys fill-up with? TopTierGas.com brands would have adequate additives to control junk build-up.
    Also I assume you are aware some Gen3's had a tendency for knocking typically when a homeowner made a tiny trip (like from driveway to street for parking etc) and then turned the car off, this tended to cause knocking upon cool-off and re-start.
  7. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Is it possible they all fill up at the same company source? Possibly as fuel quality issue?
    #7 frodoz737, Aug 27, 2014
  8. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    I think they fuel up at the Shell down the street, which is TopTier.
  9. qdllc
    qdllc Senior Member
    1,358
    396
    Use a product like Seafoam or B-12 Chemtool to clean the fuel system and combustion chambers. Simple maintenance if you are concerned about carbon build up.
  10. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    Consider a compression check and / or boroscope analysis from a trained mechanic? Not sure how easy/hard it is to do a compression check on a Prius (a little help , more experienced Priuschatters?), but a boroscope analysis can be done with the engine off and thus should be feasible .
    How many Prii in the fleet?
    Is brake wear a problem at 50k?
  11. Mendel Leisk
    38,260
    Bear in mind to get the spark plugs out (for compression check or whatever) requires taking off the wipers, the wiper motors, and a fair bit of trim around the bottom the windshield.
  12. Mr.Electric
    Mr.Electric Member
    287
    101
    San Francisco
    I think the Prius is just a noisy car. The engine noise on start up and at lie speed is normal.
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    The answer to the question I think is "Maybe".
    But I also think the majority of Prius see a wide range of operational speeds, including freeway and highway speeds.
    Even before I owned a Prius, I've always thought it good to have a vehicle get X amount of time at higher speeds. If for any reason I went a couple of weeks at all urban low speed driving, I would actually plan a trip on the freeway.
    I also occasionally run a bottle of Techron through the fuel system.
    A fleet of Prius, that never see anything but parking lot speeds? Is a pretty rare consistent and continual driving scenario. I'd think any vehicle used in that manner would be prone to carbon build up.
    mertechperformance likes this.
  14. Mendel Leisk
    38,260
    My wife, with one of our sons as an accomplice, pretty much forces me to drive up a local ski hill at least once a year. I'm guessing that would blow out the carbon.
  15. Robert Holt
    1,313
    888
    Yes , yes, floor the sucker to "blow the gunk out" as Bill Cosby once said in his "200 mph" skit! Where to do this? "Oh any side street." Of course, the one gentleman who deprogrammed the Prius's 112mph speed limiter chip and got it up to 125 mph, IIRC, also went airborne off the road, crashed, and rolled the car at the end.
    Maybe adding some Techron once in a while would be a safer option?
    Still kind of wish I could borrow a boroscope and take a look inside those engines.
  16. qdllc
    qdllc Senior Member
    1,358
    396
    B-12 Chemtool does the trick with regular driving. :p
  17. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    My person experience is that my Prius did gum up with carbon. So much so that I needed a new EGR value just short of 80,000 miles. It wasn't able to be cleaned as it was almost solid.
    I did use cheap petrol though and now use Shell.
    Robert Holt likes this.
  18. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Interesting, thanks for the data point.
    I wonder if the throttle plate and MAF are decent surrogate markers for a carbon rich exhaust, or if you can point to any reason your car would tend to run a fuel rich mixture.
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    60k miles of very short trips, often broken up with 30-50 minute gaps? Cabs in the UK have to either return to the rank OR park up waiting for the next dispatch via the computer. Obviously with the Prius the engine is off but it would fire up again when it cooled down and/or when floored. A UK taxi environment isn't good for any car. My diesels would get choked up too.
  20. Robert Holt
    1,313
    888
    May I ask what were the critical symptoms of the carbon accumulating?
    Did you also see any sooty-looking deposits on your spark plugs? Any change in compression ratio, higher amounts of pinging, or carbon accumulation on valves, piston , or combustion chamber?
    I appreciate the info as I think many of us will experience what happened to you, only at higher mileage because our pattern of use is more a mix of urban and highway driving.
    Replacing EGR valve has been easy on my previous cars at least, but disassembling to scrape off carbon is a LOT of work.
