1. Offline
    jenkinra New Member
    Start a Conversation
    Jan 29, 2006
    The Villages, in central Florida
    I'm thinking of making an extended center console to fill in the space between the dash and the existing unit. Has anyone done this or modified one from another model to work? The space in front of the existing center armrest/console is just wasted and not useable as is.
  2. Offline
    • Moderator
    27,763
    1,327
    Your Vehicle Year:
    Just note that the cupholder and hidden drawer will need space. I'm not sure how you'd access the drawer unless you make the extension shallow.
    Besides, it's meant so that you can access (and exit) any side of the vehicle. It's carried over from the first generation design.
  3. Offline
    HeidiRN1 New Member
    May 29, 2006
    <div class='quotetop'>QUOTE(jenkinra @ Jan 24 2007, 10:57 PM) [snapback]380443[/snapback]</div>
    There is a drawer under the front cupholders that fills in that space nicely. I didn't know it was there until after I'd had my Prius for a year!
  4. Offline
    jukeboy New Member
    Mar 14, 2005
    132
    SGV, SoCal
    Your Vehicle Year:
    maybe you can get an extended box to replace the existing drawer, make it fixed but add a sliding lid to protect your stuff from prying eyes
  5. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    5,047
    442
    Flushing, NY
    Your Vehicle Year:
    That spot in front of the center console is a handy spot for a removable litter basket which doesn't interfere with the cupholder, and because it's removable, will not permanently block the full opening of the secret drawer. Check out my and topkick's posts/pictures here:
    http://priuschat.com/forums/prius-main-forum/37201-need-center-console-thing.html
    Note that I eventually used velcro hooks on the bottom of the litter basket to stabilize it on the center hump carpeting ... the stick on velcro tapes I originally used on the back of the smooth plastic litter basket and front of the embossed plastic center column undereneath the dash, ended up not adhering to the embossed plastic center column.
  6. Offline
    cnschult Active Member
    Jan 9, 2008
    738
    64
    Michigan
    Your Vehicle Year:
    in the past on ebay (may still be there) i've seen a plastic thing that sticks to the carpet (its removable) and helps women keep their purses there w/o it sliding left or right.
    but aren't there enough nooks and crannies in the prius to hide all our nick nacks?
  7. Offline
    jukeboy New Member
    Mar 14, 2005
    132
    SGV, SoCal
    Your Vehicle Year:
    it's still available...
Share This Page
