changing sparkplugs 1.8 engine
Discussion in 'Gen 3 Prius Technical Discussion' started by Cees Berkhof, Oct 21, 2012.
  1. Cees Berkhof
    Cees Berkhof Junior Member
    want to change sparkplug, took connector of sparkunit and took bolt M6 out, lifted sparkunit but not enough clearence to remove the unit in order to use wrench for unscrewing sparkplug. Anybody can give me advice how it works?
  2. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    See if this helps...
    telmo744 and Mendel Leisk like this.
  3. Cees Berkhof
    Thank you, never realized this was the solution, will try it tomorrow. Engine done 96.000 km now and regarding manual plugs should be changed.
    Best regards from the Netherlands!
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Is it really necessary to remove the wiper motor?
  5. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Sounds like a job for the dealer. :)
  6. Mendel Leisk
    38,253
    I had a similar issue with previous civic hybrid: to replace sparkplugs (or adjust the valves) the bottom of windshield cowl had to be removed. Then there was a wiring harness running across the top of the valve cover, with no easy disconnects: you just unclipped what you could and wrestled it out of the way.
    Car's are getting less friendly: just changing headlight bulbs can get pretty involved on some. Compactness and aerodynamics are factors.
  7. The Critic
    The Critic Resident Critic
    3,193
    2,319
    CA
    There is plenty of room for access once the cowl is removed. Cowl removal is easy.
  8. Mendel Leisk
    38,253
    Yeah, everything's easy enough, especially the second time around, when you're more familiar with it. I'm just grumbling: used to be: open hood, pull off cable, remove plug.
  9. Cees Berkhof
    finally replaced plugs, is not difficult, be sure you have the right tool to remove sparkplug, it is 14 mm!
  10. The Critic
    3,193
    2,319
    CA
    Thx. What's the torque spec for the plugs?
    iPhone ?
  11. Cees Berkhof
    According packing sparkplug: first hand tight, then with tool 180 degree more tight ..... First little scaring but then it gave the right and tight feeling
  12. Den49
    Den49 Member
    498
    267
    Maryland
    Torque and tightening angle for Denso Plugs:
    DENSO SPARK PLUGS
    I don't see a specific listing for the SC20HR11 above, nor could I find a torque specification in either the service or owner's manual. It is probably an M14 thread size with a 20 to 30 nm torque and a 1/2 turn tightening angle as stated by Cees above. If you have a SC20HR11 plug, you can simply measure the thread diameter with a metric ruler or caliper.
  13. Mendel Leisk
    38,253
    Kinda weird, the Repair Manual doesn't seem to say anything. Looked through my most recent Honda Shop manual (paper manual for an '06 Civic Hybrid), and it says:
  14. RRxing
    2,518
    1,790
    NEPA
    Torque Spec per Repair Manual - 15 ft-lbf
    See attached...
    The Critic, Mendel Leisk and Den49 like this.
  15. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    It's still easier than getting to my #8 plug on the Camaro.
