Characteristics Jetta vs Prius people
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, May 10, 2013.
  1. bwilson4web
    16,049
    Source?
    Do you have some user reported mileage numbers at say fuelly.com or Fuel Economy showing this is the case?
  2. Hell's Guardian
    Hell's Guardian New Member
    Brazil
    Personal experience.
    A Prius owner in my hometown once told me it could get 50MPG constantly, while I've already managed to get the very same mileage with a Corolla powered by the archaic 2C engine in a trip to Uruguay (sure, had to do some EOC and shut the engine off at traffic lights), and the Corolla didn't have an electric water pump, electric power steering or an all-electric air-conditioneer, having still to take more power from the engine to move the power steering pump and the air-conditioneer compressor, not to get into its aerodynamic disadvantage over the Prius.
  3. bwilson4web
    16,049
    Too bad you don't have any personal metrics nor Society of Automotive Engineers (SAE) sources like these:
    SAE:
    Also,
    Both charts come from SAE papers about the Prius:
    • Development of the Hybrid Vehicle and its Future Expecation, Shinichi Abe, Toyota Motor Corp. 2000-01-C042., October 16-17, 1999
    • Developmet of New-Generation Hybrid System THS II - Drastic Improvement of Power Performance and Fuel Economy, Koichiro Muta, Makoto Yamazaki and Junji Tokieda, Toyota Motor Corp., 2004-01-0064, March 8-11, 2004
    So do you have any SAE or peer reviewed papers?
    Personal:
    So I decided to take some field measurements, actual quantitative numbers, from my own Prius:
    In this chart, I plotted the energy, the Joules needed per kilowatt on a trip. This is the type of engine efficiency map similar to engine operating line that helps us find peak efficiency RPMs. Do you have a similar chart for your TDI?
    Here is a similar chart where the Y-axis was converted to gm/kW:
    What I found were some real world numbers to drive-by.
    So where is your data?
    Anecdotal:
    Now if you just want to get some tall tale swapping:
    This was on a flat, perimeter around a shopping center parking lot.
    Then another day, in the same, flat parking lot, I did this:
    I shared this with an auto magazine staff and one of them used it to pull the leg of one of their Prius-skeptics.
    I don't care for anecdotal tales because it is nearly impossible to gather useful driving techniques. Although I try to quantify their effects, often I find the results are unreliable or have different quantitative numbers:
    This doesn't mean the anecdotal tale is wrong, just incomplete. Other factors were at play and these can often elude the claimant. It was real enough for them and without better metrics, I can enjoy but not get suckered in.
    3PriusMike likes this.
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Some Diesel Hybrid talking points (I do not know that these are facts, but I think they are, feel free to enlighten me)
    The pseudo Atkinson cycle engine trades raw power per displacement for near Diesel efficiency.
    Peak Thermal Efficiency
    Diesel 40%
    Atkinson 37%
    Otto 25%
    However, like the Otto cycle, efficiency falls off at low loads and idle as you need to maintain the stoichiometric ratio, and so need to close the throttle introducing pumping losses. Since the Diesel does not need to maintain any given fuel/air ratio, its low load efficiency is greater. A potential Diesel Hybrid would not need to switch to battery only propulsion to hide poor efficiency.
    Once warm, both the Otto and Atkinson Cycle engine are easy to start, while a Diesel is much harder to start. A Diesel Hybrid will need a much larger M/G1 and a larger HV Battery to power it, if it did Start/Stop like a Prius.
    This combination of being hard to start and having little gain from not running the Diesel at low loads will mean that just slapping a diesel engine into an existing hybrid HSD is ill advised, you need to think of what 'weaknesses' a Diesel has and how to use electric motors to hide those 'flaws'.
    Due to low speed inefficiencies, the M/G2 in a Prius is geared to add torque at low speeds, one diesel 'weakness' is a reluctance to change RPM, potentially the M/G2 of a Diesel would be geared to allow the diesel engine to maintain a given RPM and provide momentary power increases electrically. A Diesel engine is already strong at low speed torque so the existing Prius M/G2 has would have no weakness to hide.
    When stressed a turbocharger builds up a lot of heat, so a cool down period is advised before turning off the coolant supply (most often engine oil, sometimes aided by engine coolant) Very few Turbocharged engine use Start/Stop technology of any sort. A turbocharged Hybrid, Gas or Diesel, should have a high voltage electric cooling system to prevent coking.
    I am sure there are other design issues awaiting some poor engineer whose boss thinks it would be easy to make a Diesel Hybrid.
    bedrock8x likes this.
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I am not positive that having heard someone make a claim is actually experiencing that claim. In the legal profession it is called hearsay and is frowned upon. What I suspect he said that you did not hear is that he could average 50 MPG, not that it was his peak MPG. (my theorizing is even less approved legally)
    If your car got 50 MPG for the life of the car, not one trip, then indeed you had a winner of a car! I frequently get 50 MPG at a constant 60 MPH in my fully loaded Prius station wagon, but as you can see below, my lifetime average is just over 40 MPG. Prius Liftback owners may average 50 MPG, Prius PHV owners over 60 MPG average.
  6. bwilson4web
    16,049
    Hi Jim,
    This is just a few quick thoughts to share. The backing engineering data will take a little longer:
    To be accurate, we would call our Prius engine a reduced compression stroke engine as the intake valve close is delayed. This significantly reduces the 'pumping losses' associated with throttling an engine. The compression stroke ratio is roughly 8-to-1. Meanwhile the expansion ratio remains 1-to-13, an extended power stroke. The ultimate would an engine with a completely, variable intake valve timing allowing even lower compression stroke ratios. In effect, the throttle-body, butterfly valve goes away. It is easier to just call it Atkinson and not get lost in semantics.
    At peak efficiency, the Otto and our Atkinson will have similar efficiency. However, the Otto will have the throttle plate wide open and a narrow range of output torque. Where our Prius engine excels is the wider power range at high efficiency. Think of the Otto as efficient in a very narrow rpm-torque range and the Prius engine has a broad plateau.
    The other thing is the ratio of engine mechanical overhead to power output. Identical sized Otto, Diesel, and Atkinson engines at idle:
    • diesel has higher compression stroke energy losses and piston-ring to cylinder friction due to higher pressures
    • otto had to waste energy trying to draw a charge through a mostly closed throttle
    • atkinson has lowest compression stroke energy loss and lowest throttle body loss
    Regardless, all three engines turning at 1,000 rpm are going to have similar, mechanical friction losses in the valve train and all moving part bearings. Yet they are delivering no useful work to get the car from point A to B. Turning off the engine rather than having it idle is always a winner but not a game changer. The idling energy loss is ordinarily not a game changer.
    We haven't discussed the problem of exhaust gas treatments. The otto and atkinson are easy because they can alternate rich and lean to make the catalytic converter work. The diesel is alway lean which makes treatment difficult or breathing difficult.
  7. austingreen
    austingreen Senior Member
    13,642
    4,184
    Austin, TX, USA
    When we are talking peak efficiency
    vw tdi - 42%
    best turbo diesel (much bigger) 50%
    toyota atkinson (Lexus ISh) 38.5%
    Toyota claims 42% in the lab for atkinson. Otto is no longer otto with variable lift an otto engine like skyativ can run in the atkinson cycle when it wants too, so theoretically the same peak efficiency.
    A diesel ice car is heavier, more expensive, and requires more maintenance if you comply with euro 6 or EPA regulations. In a car the size of a camry or smaller that is a bad trade off. What you gain in highway efficiency, you lose in city efficiency because of the weight. In larger vehicles diesel hybrids may make sense. When you get to 18 wheel trucks, the tradeoff is clearly in favor of diesel, and the battery is much bigger, but plug-in diesel medium and heavy trucks make a great deal of sense in polluted cities like LA, Houston, Pittsburgh as they can be made to pollute much less. On those trucks going across the country the battery doesn't do that much good.
  8. Hell's Guardian
    Brazil
    Altough the thermal management of a Diesel engine in-between idle shut-offs, turbocharger bearings being a critical point, and the exhaust aftertreatment being more difficult and expensive, technology is improving.
    I see there's still a mutual hatred among dieselheads and the hybrid users, but apart from some douchebags in both sides we're all basically on the same boat. I'm into Diesels because of their higher adaptability to the usage of vegetable oils as fuel, which I can get at lower costs than gasoline or regular Diesel fuel, and also due to their resilience in severe environmental conditions (altough I must admit it applies better to old-school Diesels), and I'm against those posers who get those smoke-switches to annoy other drivers or pedestrians. Bashing each other because of the different technical features of the cars like a bunch of juveniles is ridiculous.
    He told me his Prius was getting 50MPG constantly, not just inner-city but also in highway. And he was not a hypermiler.
    austingreen likes this.
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    If you have some data that supports your view that your main priority is not a tiny minority of Prius owners, let's see them.
    In surveys I have seen, the main reasons for picking a Prius (in no particular order) have been:
    • Tech toy
    • Environment
    OTOH, a distinct "cut_oil_imports" crowd seems to exist within the GM Volt universe. Still a tiny group, but they make a fair amount of noise.
  10. El Dobro
    El Dobro A Member
    7,075
    3,258
    This is a quote from Fred's TDI where a member asked if it would be better to buy a TDI or a hybrid.
    "One last item to consider, if "Greeness" has any bearing on the thought processes. Hybrid does not equal green. Diesels are far "greener" than any hybrid, since the entire car can be recycled at the end of its useful life. Hybrid vehicles cannot, due to the batteries and how they are made. The batteries must be taken apart and the non recyclables disposed of properly. Just food for thought."
  11. RAL
    RAL Member
    66
    34
    Actually that has not proven to be true.
    Replacing Prius batteries can be good for the environment... and sales
    RAL
  12. bwilson4web
    16,049
    If some TDI advocates want think 'green' is the primary Prius determinant and spout nonsense about recycling, let 'em. They pay the 'stupid' tax every time they visit the pump.
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    I don't doubt it is for some people. It certainly was a leading reason for me.
    The TDI people, however, do not seem to be able to calculate any half-accurate result and instead just spout FUD. About as stupid a group overall as the Volt advocates.
  14. bwilson4web
    16,049
    Each has their own 'blind spots' but we don't have to go looking to 'convert the heathen.' They have volunteers who come here on their own. The sensible ones, get an education, and the others also get an education. For example:
    That's nice but the Prius does not have a turbo. So why would Prius owners care?
    You do realize this is 'the house of Prius' and we did not seek your company to come call us 'douchebags.' Is that some sort of diesel courtesy, to insult folks in their house? Is that how you expect to earn respect and admiration?
    I've run full tanks of E85, ethanol, and I understand Toyota will be selling Prius in Brazil with a higher E-rating, E25(?), than the E10 we have here. Ethanol is a bio-fuel too.
    BTW, my E85 testing revealed a Prius will run on E50 without modification. I can switch to E50 if E85 were priced by energy density.
    Such as? I know there is a Prius in Alaska and many in colder regions of North America. We also have a bunch in Florida, Texas, Arizona, and California. Is there some specific environmental region where only diesels work and not gas powered vehicles like . . . the Prius?
    Guess I don't care as many of the ordinary diesels in our area continue to be louder and black-smoke is common enough to find.
    So are we in 'the house of diesel'? No, you are in the 'house of Prius' and making a claim based upon coming here with false claims about us . . . We have ready access to objective, measurements about diesels and hybrids. It is not bashing to deal with the facts and data.
    Well now you're really going to be unhappy. My annual mileage for our two Prius:
    • 52 MPG - 2003 Prius, 100,000 of my miles, total 150,000 miles
    • 52 MPG - 2010 Prius, 40,000 miles, bought new
    It falls off in the winter but comes back in the Spring, Summer, and Fall. In fact, when temperatures are around 85F (30C) I start seeing mileages of 60MPG. But this is the house of Prius and we're not visiting a diesel forum to rub their noses in the facts and data.
    It is not malice or mean to speak and post the truth. You might not like the truth but then you are visiting 'the house of Prius.' After all, who came here with 'douchbag?'
    RAL likes this.
  15. Trollbait
    12,380
    Bob, he was calling the pious, FUD spouting, vocal minority of both camps 'douchebags'. A video of such a hybrid one accosting a diesel truck driver, who also owned a Prius, at a gas station was posted here not so long ago. There are those that believe a new Jetta TDI driven off the lot will spew clouds of smoke. If not do to a misunderstanding, your post would be borderline.
    This doesn't mean that something won't fail down the line with long term ethanol use. The 1.4L in the Sonic is actually a flex fuel engine. Doesn't have the E85 trim maps or a alcohol sensor. And 12 inches of fuel line isn't compatible. It's possible to go flex fuel with a tune and a sensor pulled from a Buick. It is highly recommended to replace that line. The person that went through the effort had the shop refuse to install the sensor without replacing that line. A line GM oks for E15.
    Toyota has to offer a Prius that can run higher ethanol content in Brazil. IIRC, most cars there are E20 to E100 flexible. E20 might be the closest to pure gasoline you can get in some areas. And Toyota will use parts compatible with the ethanol content there. Would you use a gas/ethanol blend in your plane? If not, why do you think its safe to exceed Toyota's E10 limit for the Prius?
    When it comes to biofuels and diesels vs. ethanol and gassers, the diesels are at an advantage. The engines themselves don't need modification. As long as fuel could flow, the engine would run. Plenty of people still dump old motor oil and transmission fluid into their old diesels. Vegetable oils only have a flow issue. The tank might need to be heated, and most use duel fuel systems to start on diesel until the engine is warm and flush out the VO before shut off.
    Biodiesel is corrosive, but B100 resistant fuel lines have been used since the mid '90s. The issue with today's diesels isn't the engine, it's the emission controls, namely the DPF. The cheap, and thus common, way to regenerate the DPF is to inject some fuel into the cylinder on the exhaust stroke. The problem arises because biodiesel is less volatile than diesel, and some gets left behind in the cylinder. Where it collects on the walls, possibly gunking things up, and works it way into the oil, thinning it out. This is why the European diesels here are limited to B5.
    Ford and GM allow B25 in theirs. I'm not positive, but they likely inject the fuel for a regen cycle directly into the exhaust. The B25 is mostly do to the fact that it is quite easy to make biodiesel at home. Which means it is quite easy for some lazy homebrewer to be dumping glycerol, soap, or water into their fuel tank.
    Note I specified ethanol before. Butanol can be made renewably, and depending on the source usable up to 85% or higher in an unmodified gasoline car.
  16. CaptainStarbuck
    CaptainStarbuck New Member
    Just sticking 2 useless cents in here - I'm just looking for a new car, spending a lot of time to research Prius at the momnet. I've been referred by friends to Jetta and other TDI's, but now coming to understand their views are based on some amount of FUD as seen here.
    And RE the "eco-unfriendly" battery creation/disposal concepts, I'm also hearing a Lot of that FUD from all over. People really believe that stuff. The Toyota videos are good as are confirming independent sources, but more of this info (and solid evidence) needs to get out there into the public or it's going to be a constant thorn in the side of Toyota and their supporters.
    Video on Toyota plant in Japan and complete life cycle
    Video on Toyota recycling system
    Autoblog short article - confirmation that batteries aren't scrapped, they're recycled
  17. El Dobro
    El Dobro A Member
    7,075
    3,258
    Don't forget the $10,000 batteries. :p
  18. bwilson4web
    16,049
    We'll have to agree to disagree on this point. I've posted questions in a TDI forum and I don't start with "well there are some assholes around but here is my opinion." In fact, I gone to a TDI forum to ask if anyone has mph vs MPG data and shared my equivalent data as an example of what I'm looking for. I was there for 'technology exchange,' not re-education. But that was neither the style nor attitude of the OP especially in his second thread posting.
    We're on the same page about bio-fuels as being a reasonable and even likely future source for transportation fuels. These fuel and vehicle technologies are improving. As for the visiting diesel 'missionaries,' well it reminds me of something my wife and I were planning many years ago when we moved to Huntsville.
    Apparently the moving companies or agents have agreements to let the local churches know when new people arrive. So we kept getting door visits from various churches. Well my wife is Catholic and I'm Unitarian so I suggested we get a plastic Jesus on a cross with LEDs and some Catholic tracts and I would bring home some Unitarian tracts. We would then become the 'Venus Flytrap' for visiting missionaries and try to convert them!
    The Brazilian Prius are supposed to show up sometime this year. So perhaps the OP might visit a Toyota dealership and try one. But if he doesn't, no problem for me.
    We've shared the technical facts and data and whether or not the OP ever comes back or even understands what has been shared, doesn't really matter. I'm not out to 'chase him down' as his ignorance does not harm any of us. If he has questions, I and others are more than willing to answer Prius hybrid technology questions but that was not evident in his second post.
  19. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    You may not start out with that but some people do.
  20. bwilson4web
    16,049
    I know. When I was in college, I remember first coming in contact with people from the New York and New Jersey. They would say things to each other that in Southern families would mean 'hide the knives because someone's goin' to get hurt.' I learned it was just their style of talking but 'trash talk' is not how engineers conduct business.
    There are a lot of folks here more than willing to explain how our hybrids work. Our rides are not trivial and there are subtle aspects still not fully understood. Heck, we see them frequently in the NHW11 forum, new owners of used and broken Prius. So we, and I do mean the Prius Friends who hang there, patiently cover what they need to diagnose and repair their rides. We've gotten pretty skillful in helping.
    Even when someone comes to the House of Prius with attitude . . . well they'll always get one good data dump. If that leads to a dialog, good deal, we'll all learn something. Just continued babbling about diesels without credible, engineering data combined with back-handed, personal comments . . . not the best way to start a dialog.
    jgilliam1955 likes this.
