check engine light, P0301 Cylinder Misfire code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Suzazoom, Apr 12, 2015.
  1. bisco
    49,075
    boatbehis!:p
  2. Fishcrab
    Fishcrab Member
    152
    29
    Any news about your car today?
  3. Suzazoom
    Suzazoom Junior Member
    40
    Utica MI (north of Detroit)
    Steve Woodruff replaced the engine harness, repaired the vacuum line, replaced the water pump pulley, replaced the intake manifold but the missing cylinder problem continues. He said he would try replacing the fuel injectors next. Maybe the guy who recommended I give up on the car was right. I really thought replacing the engine harness would take care of the problem.
    49,075
    oh boy. has he topped $1,000. yet?
  5. Suzazoom
    40
    no, the engine harness he said he would charge $600 for, but he also had mentioned he does not charge for "wrong answers" , He said he would not charge for the intake manifold. I am going to ask if he will charge for the engine harness.
    Fishcrab likes this.
  6. bisco
    49,075
    keep in mind he's making a boat payment.:p
    Fishcrab and Suzazoom like this.
  7. Suzazoom
    40
    even above the cost of the attempted repairs to my car is a rental car at $50 a day, motel $50, gas about $50 each way, and missing work $250 so far, another $250 if i have to pick it up next week during the week. I wrote steve if it is not the fuel injectors maybe he would let me come pick up the car sunday so I don't have to miss more work and let my clients (who I see as a therapist for their mental problems) down by canceling them again.
  8. Suzazoom
    40
    that would add up wouldn't it?
  9. bisco
    49,075
    i'm just kidding, steve has a great rep. sometimes these older cars are difficult to diagnose. but please don't take any more time off, we don't need anymore people going off the rails.;)
  10. Fishcrab
    Fishcrab Member
    152
    29
    hopefully you will be able to stay above water.....
  11. Fishcrab
    Fishcrab Member
    152
    29
    Hopefully noOne will read you the right act at this point. I think you are a real trooper.
  12. Patrick Wong
    18,200
    6,464
    Owning a car like that could easily induce severe mental problems...good luck with the fuel injector replacement, there aren't that many more things to try.
  13. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    seems like the harness did need replacing since some hack cut it.
    I have seen a bad ecu cause misfires, but on other brands of cars. I hope it gets fixed soon.
  14. Patrick Wong
    18,200
    6,464
    Good point, I am sure that Steve has no shortage of engine ECUs to try if he gets to that point.
    If the OP's car did not have such a low odometer reading, I would suggest verifying engine compression to see whether cylinder 1 has a problem.
  15. JC91006
    16,470
    8,384
    In the OPs post #1, she already had the compression checked. The specialist listed 3 options that could be the problem.
    I take the car to a mechanic reputed for repairing hybrids (Curt’s Service, Oak Park, MI). He tests the car for several hours. He notes the problem starts at the beginning of drives then goes away but is intermittent. He spends 45 min explaining the problem could be in the wiring harness (cost $300 to check), could be in the computer control unit (cost $1400 to replace) or could need engine repair.( cost $3300) (local mechanic does not think engine is the problem due to good compression).
    Also the fuel injectors and coils have been swapped numerous times.....but really no mention of changing spark plugs again.
  16. Suzazoom
    40
    I am very happy to report that my car is most probably fixed!!!! Drove it 420 miles the last 2 days with 4 successful cold starts. I will know FOR SURE later this week when it has passed the test of more time. Steve Woodruff said he believed each of the problems he fixed: engine harness, water pump pulley, intake manifold and fuel injectors may have contributed to the cylinder misfiring.
    I also noticed that where as before Steve worked on the car, the HV battery charge was usually about 6 bars high and blue (only green about 5 % of the time). Since his repairs the battery charge is mostly green (90%) and right up to the top, 9 bars.
    I want to heartily thank everyone who took part in this post's thread. Without it I am convinced my car may have been sold for parts.
  17. bisco
    49,075
    congrats!(y)
  18. Suzazoom
    40
    Just wanted to let you know I think my car is fixed. cost $935 and well worth it
  19. Suzazoom
    40
    thank you, I do feel greatly relieved and a sense of victory
  20. bisco
    49,075
    and more importantly, you can get back to the people who need you.:)
