Checked Cooling fan yesterday
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shaneprius2005, May 5, 2012.
  1. shaneprius2005
    shaneprius2005
    Expand Collapse
    New Member
    Williamsport, Pa
    So yesterday I decided to check the cooling fan in the back hatch. Disassembling was easy and took less than a half hour. Once every thing was removed I took the upper most duct work off, and then I was able to see the fan. Mine was very clean with only a small about of dust on the blades. I removed the dust using the vacuum cleaner. My Prius is a 2005 with 116,000 on it. A very clean car that I purchased a few weeks ago. After the fan inspection I feel more confident the battery pack has lived a good life so far. I expect to get many more miles and years out of the pack under normal driving conditions.
  2. hep1966
    hep1966
    Expand Collapse
    Junior Member
    28
    PA
    I checked my fan a couple days ago. It had a small amount of dust on the blades. I couldn't find a small vacuum tip so I used a narrow paintbrush to loosen the dust, then compressed air to blow the dust away.
  3. cnschult
    cnschult
    Expand Collapse
    Active Member
    772
    85
    Michigan
    is the vent on the passenger side of the rear sent the intake or the outtake?
    the reason I'm asking is i'm wondering how hard it would be to create some sort of air filter for the HV battery fan. I don't drive much on the expressway and prefer to use windows down in the city as it doesn't get too hot here so I probably need this mod more than a person who runs a/c most of the time.
  4. JimboPalmer
    JimboPalmer
    Expand Collapse
    Friend to those who want no friends
    8,861
    2,810
    Greenwood MS USA
    3 people like this.
