1. Offline
    niteryder Junior Member
    Start a Conversation
    Feb 9, 2012
    34
    Earth
    Your Vehicle Year:
    Well, I picked up my Prius about a month ago now and it was finally warm enough for me to install the sub amp. Honestly, this was the easiest amp install I think I have done to date.
    I currently run the stock JBL setup for now because I think it is decent for what it is. For the sub amp I run an alpine that does about 200Watts RMS @4ohms. I had an oldschool sub box (one of the many I made back in the day) with a 15" and 12" MTX in it, which completely drowned out everything. Even with the gains all the way down. It was fun, and it hit seriously hard. However, I am a long since retired bass head. For now, I have a pair of 6" woofers adding some low end, which will not last long because they are low wattage.
    I was thinking of taking the 12" out and just using that.
    Anyway, I was wondering what people were using for a nice well rounded sub that sounds good. Since this is my first "hatch back", any insight would be good.
  2. Offline
    frodoz737 Mechanic
    Aug 26, 2010
    850
    184
    TX
    Your Vehicle Year:
    10" rear facing.
  3. Offline
    Aug 14, 2006
    18,156
    3,452
    Sacramento, CA.
    Your Vehicle Year:
    A single high powered 8" can work but with your wattage a single 10" works. I really liked my Orion XTR 12". It was very smooth compared to the last few JL subs I used in the same system.
  4. Offline
    Kutanks Junior Member
    Jun 23, 2008
    95
    MA
    Your Vehicle Year:
    right now im runnning 2 12' kickers in a ported box of an Alpine 500w monoblock
  5. Offline
    Vinnyvalentine New Member
    May 3, 2012
    Maryland
    Your Vehicle Year:
    I have 3 twelves and 1500 watt amp and lights dont even dim when it hits badass
  6. Offline
    bandogg Junior Member
    Mar 18, 2012
    San Diego,CA
    Your Vehicle Year:
    I went with the JL audio CP 108LG W3v3, its max 250 rms and its thin enough to fit in the cargo area. Well all most thin enough, about 1/2 in over, and it sounds great.
    Sent from my EVO 4g LTE using Tapatalk 2
  7. Offline
    phatcat New Member
    Feb 5, 2011
    Washington
    Your Vehicle Year:
    I put in 2x 12" JL W3v2 powered by an 800watt Phoenix Gold amp along with a capacitor
  8. Offline
    eyecannon New Member
    Mar 29, 2012
    LA
    Your Vehicle Year:
  9. Offline
    Daze Prius C Owner
    Mar 14, 2012
    91
    17
    Utah
    Your Vehicle Year:
  10. Offline
    maestro8 Nouveau Member
    Feb 19, 2012
    474
    84
    nor cal
    Your Vehicle Year:
    I've got a 10" alpine sub in a tuned sealed box, just over 1 cu. ft. Paired with a 300 watt amp (I forget the make), it's more than plenty for a small enclosed cabin such as the Prius.
    It's amazing how much better a single speaker sounds when it's in a properly tuned enclosure! You don't lose response at certain frequencies like you do in a generic enclosure.
    Find the factory spec. sheet for your subwoofer; it should tell you the optimum enclosure volume. If you don't know how to do this, find a local independent shop (not a chain!) to do it for you. It's worth the $100 or so they'll charge for a custom enclosure!
  11. Offline
    C25A1guy New Member
    Jun 29, 2012
    Sun Valley, CA
    Your Vehicle Year:
    Although it is not in my Prius, I've been using Image Dynamics IDQ subs for YEARS and is probably the best sub I've ever used (even got me placed at the regional IASCA finals a few years back with my Ridgeline). It runs fine on 200w RMS (heck, you can probably even run lower, it's such an efficient sub), doesn't require a whole lot of air (on the small side, I think you can get away with as little as .75 cu ft w/ polyfill).
  12. Offline
    johnnyP13 New Member
    Apr 11, 2013
    Your Vehicle Year:
    Did you add a second battery? or what cuz im about to put a 1300w rms system in my 08 prius please help
Share This Page
