Cleaning carbon deposits
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JC91006, Apr 20, 2014.
  1. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    I don't care for your confrontational attitude........again. :(
    The point IS that what you are trying to "fix" is the stuck rings......if that is the cause.
    If it is because of worn out rings, none of that will do any good......and might actually make matters worse.
    Trying to "fix" carbon build-up simply be removing the carbon is a fools errand.
    Actually I have no problem with directly treating the rings to SEE if it will help or not.
    I did an "intake feed" with MMO on an old pickup years ago with remarkable results.
    I don't know if it also had "carbon buildup" or not; didn't care.
    What I have a problem with is twofold:
    1) Putting "crap" into your oil hoping for a miracle cure that almost NEVER happens
    2) Treating carbon buildup just for the sake of getting rid of the carbon......when there is no evidence that it is really causing any trouble.
  2. Easy Rider
    982
    210
    N. Central Florida
    Dupe deleted.
  3. Easy Rider
    982
    210
    N. Central Florida
    Dupe deleted
  4. JC91006
    16,470
    8,385
    Thank you both for your feedback and helpful suggestions. I want to say the knocking sound I hear in my engine, either from something broken, worn, or carbon only can be heard when the engine is warmed. When I start the car in the morning, when the RPMs are running higher, the engine sounds completely normal. Only have it has warmed and slowed in RPMs will this knocking sound appear.
    Would that be broken, worn, or carbon related?
  5. Patrick Wong
    18,200
    6,464
    What about when the engine is warmed up and at high RPM: what unusual engine sounds if any do you hear? Does this knocking sound occur only when the engine is warmed up and at idle speed?
  6. JC91006
    16,470
    8,385
    I'll have to get back to you on the specifics at high rpm. I'll have to warm it up later on my drive and rev it up at higher rpm. I just know there are no unusual sounds at start up in the mornings, it warms and the idle slows, like the engine goes into another stage and starts knocking.
  7. Okinawa
    Okinawa Senior Member
    1,333
    317
    I have a question to ask Patrick Wong. I have a 2011 Prius Two that I bought new 3 years ago. About 2 years ago my wife and I departed on a trip. After about 2 1/2 hours into the trip I smelled a very bad odor. I discovered my wife had laid a light jacket on the back seat which blocked the vent for the hybrid batteries. When I removed the jacket the odor from the batteries almost immediately disappeared. I have had no problems as a result of this incident. My question is this. Do you think this overheating of the hybrid batteries might possibly cause the batteries to have a shorter than normal lifespan?
  8. Patrick Wong
    18,200
    6,464
    Since this happened two years ago, was a one-time event, and you have not had any driveability issues since then, I think your traction battery is and will remain fine.
  9. Okinawa
    1,333
    317
    Thanks Patrick. I appreciate your opinion.
  10. Patrick Wong
    18,200
    6,464
    If the knocking sound only occurs at low speed RPM then it is not likely that any mechanical part is actually broken.
    Using Mini VCI, I would suggest you look at the engine ignition timing at the RPM where the engine knocks. Compare to ignition timing at the lowest RPM where the engine sound is normal. Maybe the spark timing is too advanced, causing the knocking.
    The engine has a knock sensor which is monitored by the engine ECU. The ECU is supposed to retard ignition timing as necessary to prevent knocking. DTC P0325, P0327 and P0328 are related to that circuit. I haven't noticed anyone complaining about having problems with those DTC.
    Also you might try refueling with 91 octane premium unleaded fuel when you've used up the current tank. Just add 4 gallons as an experiment, and see if that makes any difference to the knocking issue.
  11. Former Member 68813
    3,524
    981
    US
    Would you mind uploading a recording to youtube?
    A lot of things can sound like engine knock including bad belt, pulley, or tensioner. I had that problem in subaru and corolla.
    Mechanic's stethoscope should be your friend.
    Mechanic's Stethoscope
  12. JC91006
    16,470
    8,385
    This should not be a low octane knock, but good suggestion on trying the higher octane. Did you watch the video of the tank crushing the silver prius? That prius in that video has the exact same knocking sound as my engine
    SM-N900P ?
  13. JC91006
    16,470
    8,385
    Delete duplication
  14. JC91006
    16,470
    8,385
    I'm not much of a YouTube guy, I did make a small video a while back but couldn't upload on here because of the size. I'll make 2 short clips, a morning start up clip and a 2nd warmed up clip. Will do it tomorrow
    SM-N900P ?
  15. Patrick Wong
    18,200
    6,464
    Also, pls remind us of the model year and odometer reading of the car with this problem, since you own too many Prius for us to keep track of... :cool:
  16. JC91006
    16,470
    8,385
    This is the 2006 with 124k miles. The knocking is still there at higher rpm, just faster. I think there's a placebo effect to the new spark plugs, it seems much more responsive tonight (first time taking it out with new plugs)
    SM-N900P ?
  17. JC91006
    16,470
    8,385
    And the too many prius part, I just today bought the 2005 I put the new transaxle in, my friend didn't want it after all. Paid $1000 for it plus whatever I initially put in. Don't need it but couldn't pass it up
    SM-N900P ?
  18. Patrick Wong
    18,200
    6,464
    Congrats on the purchase, you worked hard to make the transaxle swap a success so it is reasonable for you to buy the car and get some value out of it.
    Guess you need to update your signature block... I hope you are keeping battery tenders or battery chargers on all of the 12V batteries in your Prius fleet. :D:rolleyes:
  19. JC91006
    16,470
    8,385
    I'm not going to drive the 05, no room for it. I'm going to give it to my brother. It'll be his first hybrid. The car runs perfectly, it will eventually need a HV battery but I'll cross that bridge when it comes.
  20. JC91006
    16,470
    8,385
    Ok finally figured out how to upload a clip to youtube.
    Here are 3 clips of the engine sounds.
    Startup
    After 1 minute idling
    After 10 minutes of driving, sound at idle. This is where it's knocking loudly
    Although the engine sounds like it's having trouble, it drives really nicely. Not sure what to make of it.
