Cleaning engine compartment
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MikeDee, Aug 14, 2013.
  1. MikeDee
    MikeDee Senior Member
    1,536
    583
    San Francisco Bay Area
    When I wash my car, I like to spray the engine compartment and engine with the hose to keep it clean. This worked fine with my other vehicles, but I hesitate to do this with my Prius because of all the electronics. They do look well sealed though. Thoughts?
    Galaxy Nexus ? 4
    48,995
    i would avoid it, unless you know what to spray and what to wrap tightly in plastic. prius engine compartment stays a lot cleaner than most anyway.
    xpcman likes this.
  3. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    Don't do it!
    Just wiping it down by hand is a far less risky approach.
    Fortunately, quite unlike other vehicles, the engine compartment is sealed. That plastic underneath keeps it remarkably clean. So, there won't be much to do anyway.
  4. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I spray mine down too occasionally, and I mean spray. No great floods of water. I also use compressed air to dry all the exposed wires seal and connectors. I've been happy to do this while new but I will modify that from next summer as the seals do shrink with age.
  5. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Mine is starting to get a little dusty and dirty, I was thinking about a mild damp cloth with degreaser or something.... I had my car serviced for the first time and the dealer (let's just see he was a sloppy tech) oil and grease all over the engine compartment, filthy.. I would like to get it cleaned and maintain a clean engine compartment.
    I normally spray my engines well but when I see all the wires and packs under the hood on the Prius, I'm reluctant to do so.
  6. Mendel Leisk
    38,253
    How's it looking, does it really need hosing down? I ask 'cause our's around 38000 kilometers and still looking pretty clean. I think the engine underpanel has a lot to do with it, maybe coupled with the radiator/ac fans rarely running.
    I've used a wet dry vacuum with brush attachment on it a bit, and set it to blow to knock stuff out of the corners. Also tried a more powerful electric leaf blower. One of those duster wands is good, just feed it through gaps, then vacuum it off. A paint brush is good too.
    I'd rather not be spraying petroleum solvents and caustic soaps in there, then hosing them down the storm drain.
  7. Delta Flyer II
    547
    248
    69
    It gets hot and dusty here so I run the air often, it was fine until my last service where the tech obviously could not get the oil gun in the hole and oil stains were all over everything, not to mention his greasy hands. I scolded the dealer. My car should have been returned in the same if not better condition than when I brought it in. They also curbed a wheel when they brought it to me and the tech damaged two wheels with the socket wrench.
    They wanted to repair the wheels, I demanded a new ones.
    Maybe I will just take a damp cloth and wipe down the engine bay... Previous cars I stay on it so there was never a need to use chemicals as I was merely just rinsing off dust and bugs, etc..
  8. jharwd
    jharwd Junior Member
    Check to see what toyota recommends.
  9. Seanzky
    Seanzky Member
    150
    28
    NY
    Get an air compressor in your garage and wear goggles and mask. That's what I would do if mine ever got that dirty.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    There was another post in G2 I think that a guy recommended high pressure hosing down the engine as all the connectors are waterproof.
    They may start out waterproof but after a while the engine heat attacks the connector's and it tends to shrink and water under high pressure can get in the connector. Nobody I know uses water to clean the engine bay. Pro's use steam. To many electrical connectors.
    Besides raw metal squeaky clean under the hood will accelerate rust.
  11. MikeDee
    1,536
    583
    I sprayed water from the hose to clean the dirt off the engine. The engine missed for about 30 seconds, probably due to the spark plug wires being wet.
  12. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Those aren't sparkplug wires there cop power supply and control wires. Water seeped into the sparkplug well past the cop seal which is not that great of a seal. Far from waterproof.
    But still makes the point water's getting in where it shouldn't. Not to mention everything around the engine is getting wet like the ac compressor, the exhaust manifold, all the electrical connectors below, the steering rack right below etc.
    Last thing you need in this world is a 2013 that's developed a strange engine misfire that comes and goes.
  13. Tande
    Tande Active Member
    498
    301
    Mich.
    Probably not a "Terrific" idea.....(n)
