considering trading my PiP for a Volt
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fortytwok, Jul 18, 2014.
  1. silverone
    silverone Member
    84
    34
    Ohio
    2014 Chevy Volt
    Out of the 2014's 16.5KWh, there is only approximately 10.7KWh usable. In the 2015 (and supposedly late 2014) the 17 KWh battery changes this to slightly over 11 KWh usable. If you have a May build date on your 2014, you may have the larger battery. Mine matches the date, but I haven't discharged fully to see if I go over 11 KWh to a full battery. It was rumored that if you got the Chargepoint cards in your Manual package that you have the larger battery... I consistently get to 10.8 or 10.9 with a few miles of electric range left.
    I'm looking forward to seeing how low temperature operation works. It's programmable to not start the engine until 14*, although I've seen some modify the temp sensor to spoof it similar to the Prius ECT spoof. Going from memory of something I haven't experienced yet, I think it runs the engine until the coolant is 150* and lets it cool to 105*ish before restarting.
    I didn't want to wait for the next gen Volt because of the rumors that they'd be de-contenting one model to hit the 30K MSRP price point, as well as creating a higher price point with greater range ala Tesla.
    #81 silverone, Jul 25, 2014
  2. retired4999
    2,652
    625
    Eau Claire, Wi.
    Thanks! for the response. Good info.(y)
    silverone likes this.
  3. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    that's great, useful info thank you Silverone!
    Yes I got a pair of Chargepoint cards so maybe...
    and as mentioned - I'm a major newbie. This indicates the Volt is cheaper to drive than I previously estimated.
    If I'm getting nearly 60 miles on a full charge and a full charge is 11kWh then at 16 cents per - I'm looking at $1.76
    for those 60 miles. That's before figuring in all the free juice I get which is at least 25% off...
    The extra range has allowed me to skip some home charging when I know I'll be at a freebie
    markabele and silverone like this.
  4. silverone
    silverone Member
    84
    34
    Ohio
    2014 Chevy Volt
    You do have some charging losses of about 18-20 percent, but even then you're using 12-14 max kWh per session.
    I agree that the green ball is pretty useless. I assume you've found the instantaneous power display on the center dash like this one... http://www.girr.org/random_stuff/130114_volt_battery_only_mode_dsc00559.jpg
    It's way more useful.
    So far I agree on the Volt threads being fairly quiet. I guess that's the difference between a community with 60k potential members to several million...
  5. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    I've had my Volt for a year.
    This was a cold winter. I have a 38 mile round trip commute with no charging available at work. On days that were below 15 degrees for both directions I burned about .45 gallons of gasoline (and about 90% of my battery range).
    Often things would get up above 20 in the afternoon and I'd get away with about .25 gallons and the full battery charge.
    The engine isn't used very efficiently in "running due to temperature" mode. If my commute were farther (or uphill in the morning) I would have been better served using Hold mode for heat and propulsion.
    Overall I was very pleased with how the car handled the cold.
    Minor correction here--you're paying for the kWh out of the wall socket which is probably closer to 13 kWh with the inefficiencies.
    [Note: The little blue link in my reply was nothing that I did].
  6. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :eek: Who's not tired of waiting? What's wrong with "instant gratification?" Samsung promotes, "the next big thing is already here." All things considered, you're decision makes sense.
    #86 -1-, Jul 26, 2014
  7. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    NYRob, Silverone, Jeff, anyone ?
    for ages now I insisted my PiP was charging faster than my friends Volt - then mine!
    So with too much time on my hands I tested this out today and came up with what I suspected :
    I was too close to full before so the Volt was adding just about 3 miles every 20 minutes.
    Today I intentionally held off charging until roughly half empty and charging from the same Chargepoint the Volt was adding 3 miles every 10 minutes.
    The thing I still don't understand is I monitored the Chargepoint readings and they showed the same energy usage per 10 minutes whether I was charging fast or slow (near full)
    Can anyone confirm this ?
    If true I would hold off charging at home if at 80% or more given I have free charging not far away
    ps up to 59 EV est now
  8. retired4999
    2,652
    625
    Eau Claire, Wi.
    59EV !!!! Coooooool, :D:whistle:
  9. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Congrats on the 59 EV estimate!
    You are measuring charging speed in two different ways that are not equivalent.
    One way is a measure of how fast energy is being supplied to the car and therefore the battery. The Volt is faster at this than the PiP at 240v. You are seeing consistent numbers from ChargePoint, as expected.
    The other way you are measuring charging speed is in miles of estimated range added per unit of time -- 10 minute intervals, in your example. This way is dependent upon both how fast energy is being supplied and also how efficiently you are driving. Since your full EV range is now estimated at 59 miles you will see more miles of range added every 10 minutes than you would if your estimated range were a mere 40 miles shortly after you started driving the car with the same amount of energy in a full battery. Since 40 is about 2/3 of 59, if you are now getting 3 miles of range for every 10 minutes you would have previously gotten 2 miles of range every 10 minutes.
    So, when comparing between a PiP and a Volt you could easily see the PiP adding more miles of EV range every 10 minutes if it is being driven noticeably more efficiently than the Volt is even if the underlying rate of energy going into the battery from the ChargePoint station is actually faster on the Volt.
    At 3 miles of range every 10 minutes you are adding 18 miles every hour which is about the same as a mildly spirited Model S driver charging more than twice as fast in terms of energy at the same ChargePoint station (7.2 kW vs 3.3 kW) but who is only getting 400 Wh per mile or 2.5 miles per kWh.
    #89 Jeff N, Jul 28, 2014
    fortytwok likes this.
  10. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    thanks Jeff, I mostly understand this - but my big question is why was the Volt adding so much less in terms of EV miles in the last 1/3 of charging ? Do you think there's an automatic trigger like 40 miles EV range where the Volt puts on the brakes in terms of charge speed ?
    An expert from another forum spoke of the Leaf charging faster in the middle...
    btw I'm not driving the Volt measurably less efficiently than the PiP. After the first day its been the same speed same routes...
    Getting the EV est to 59 should back that up. Hard to get data from the Volt site to compare but I think that 59 is up there
  11. Bill Norton
    Bill Norton Senior Member
    1,823
    598
    MONW, Ks.
    forty,
    You can set the 'Delayed charge' to a time after you actually take off for work, that way you will consistently stop the charge at whatever % you are shooting for.
    That way you arrive at work mostly depleted and can get a full charge at work.
    But that's gaming the system. A good employee would not do that and charge only the amount it took to get them there, right?!?
    Why, that would be like getting an extra 20-40 cents a day at their commercial rate.
    That's as bad as someone who drinks company coffee all day. Way more than 40 cents, compared to the non-coffee drinker.
    Also charging starting in the early morning hours requires less energy going the advanced Thermal Management System to keep the battery cool and happy. The battery cools naturally from the commute home and charging later uses less energy in the long run.
  12. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Good stuff Bill !
    Shoot, I'm so close to free charging I don't need to charge at home period. Ya its summer but currently 59 miles minus 5 to get to multiple free chargers... minus another 5 to get home = garaged at 54 !
    For what its worth the chargers are on the MA taxpayers so we won't pollute the air. State of MA actually added them to Logan Airport too !
  13. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I guess I misunderstood your question. I'm less familiar with the detailed charging behavior of the LEAF but it would surprise me if it charges faster in middle. As far as I know, the LEAF, Volt, PiP and all other plugins will quickly ramp up how fast they are putting energy into the battery and will reach their peak rate within a minute or two. Under extreme cold temperatures (below 32F) it may take longer to reach peak charging since the battery may have to be warmed up first.
    At the lower 240v rates of 15-30A on a ChargePoint station these cars should maintain a steady rate of charging until the battery gets above around 80% full at which point the rate will slow down until the charging completes.
    The Volt slowly ramps down from a peak of 3-3.3 kW down to around 1.2 kW when it stops. This slowdown takes about 5-10 minutes. The Volt battery stops charging when it is 87% full.
    The PiP is roughly similar but instead of slowly ramping down it suddenly drops the charging rate from around 2.3 kW down to around 1 kW (I forget the exact rate) until it stops when the battery is around 85% full.
    I'm not sure exactly how the LEAF handles things when the battery gets above 80% but I'm guessing it ramps down like the Volt.
    At faster DC charging rates like CHAdeMO at 50 kW or the Tesla Supercharger at 120 kW the charging rate ramps down slowly during most of the entire charging time. It might quickly jump to 50 kW or 120 kW when the battery is empty but within a few minutes it begins to slowly ramp down because they battery can take less charge as it gets full and they are stuffing in the energy as quickly as they can.
  14. markabele
    5,084
    1,782
    Nebraska
    You know you are from California when...
    You call the teens or 20's "extreme cold." ;)
    Just giving you a hard time, Jeff. :)
    Holy moly, that is a lot of energy.
  15. silverone
    silverone Member
    84
    34
    Ohio
    2014 Chevy Volt
    Can't add much other than the fact you won't hear half the Volt crowd crowing about estimates greater than 50 AER, since they've stated the estimate calculation maxed out there for the 2011-12 model years. Congrats on 59 miles! I can't force myself to drive that conservatively :D
  16. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I've walked to school in January in Montana so I have a personal appreciation of cold temperatures. :)
    Let's put it this way, when icicles are growing on your eyelashes your battery may need to warm up before it can recharge at its peak rate.
    markabele likes this.
  17. CharlesH
    2,785
    1,152
    Roseville, CA
    The charging pattern is pretty much dictated by the LiIon chemistry. The chargers in cell phones follow a similar pattern, falling off quite a bit as the charge cycle approached completion.
  18. Bill Norton
    1,823
    598
    MONW, Ks.
    forty,
    I'm sure you heard this by now, but, that 'miles' number is just a guess-0-meter. It uses how you drove the day before to guess what today might bring.
    When showing 59 miles it does not know you are about to drive up the Rockies at 80 MPH, with the heater blasting, with all your fat budds in the back. You'd get way less than 25 miles on a trip like that.
    The bars on the battery icon are the only real indication of what is in the battery.
    Do you know about the 'killawatt' Kwh meter for L1 charging?
    I have at home a EMW juice box L2 at home. Cost me $285 total to have L2 at home. I have the components to add a Kwh meter to it, but haven't installed the extra (?) $35 in parts and a new SW load.
    But it sounds like you can almost not care about home charging ! What a progressive state you live in !!
    L2 is nice on the weekends especially. Multiple trips are not a problem.
  19. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I understand the EV est - but keep in mind my daily drives are boring consistent, rarely above 40mph with very few lights.
    After a week once the Volt understood me its been "full" at 58/59. So until cold temps come or I need to drive into Boston that "guess-o-meter" is pretty good !
    I do know about the killawatt meter and may look into it - was really tossing my findings out there to see what owners were seeing.
    Even more interesting are the answers I got on the Volt forum - and some from very smart, experienced owners - but conflicting !
    Slows down last 10%, slows down last hour, slows down last 5-10 min, slow when first plugged over 60 degrees, doesn't slow down at all...
    Most common answer was essentially - "why worry, plug in and full in 4 hrs"
    geez... just trying to figure out how this new animal works !
  20. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I skimmed the answers you got on the Volt forum. They were roughly consistent with each other but various small mistakes crept in.
    Several of them said it slows in the last 5-15 minutes or so which is correct.
    The business about "slow when first plugged in above 60 degrees" was a bit confused. The ambient temperature doesn't matter. The active cooling using the A/C compressor etc. kicks in when the battery itself is above 86F during charging. That obviously will take away some of the energy when the compressor cycles on for a few minutes. At other times, some energy efficient pumps may just circulate the coolant through the radiator without much of a negative impact. Doing that keeps the cells at an even temperature and also dissipates some heat.
    The charge does indeed slowly ramp down. You said it didn't seem to show that when you checked ChargePoint. I think you should try again and check more diligently.... The stations show the slowdown in charging rate and I know the iPhone smartphone app will show it as well. I rarely look this up using the website but my memory is that it also will show the rate ramping down. Make sure you are getting updated data every minute or so during the last 15 minutes of charging.
    There is also some confusion about the usable amount of the battery. It varies depending upon model year. In 2011 and 2012 the battery is 16 kWh and 65% is usable. In 2013 the battery went up to 16.5 kWh. In 2014 the usable range went up to 69%. In 2015 the battery will go up to 17.1 and the range will presumably stay at 69% although that detail has not been confirmed. Many 2014 Volt owners have not heard about the 2014 change to using 69% instead of 65% of their battery so they may mistakenly assume that their greater usable capacity is due to getting one of the new 2015 batteries.
    #100 Jeff N, Jul 29, 2014
