Correct me if I'm wrong... (new Gen1 owner)
Discussion in 'Generation 1 Prius Discussion' started by S Keith, Sep 11, 2015.
  1. bwilson4web
    16,007
    Excellent!
    BTW, here at the 'tags' if you want to put the table in a post, remove the " symbols used to defeat rendering:
    • "["table=head"]" - signals beginning of a table with first line the column headers
    • "|" or "," - these are field separators and yes, the "," is a pain in the ...
    • 1st line is the headers
    • following lines are the data with a field separator for each
    • "["\table"]" - ends the table
    module id Ahr @1C resistance
    1 1 3.5 0.02 mOhm
    2 2 4.2 0.02 mOhm
    BTW, I record the monthly Dashboard data in an excel spreadsheet and use the "concatenate" function to make the display tables. This gets the data in front of people rapidly without having to 'go to <someplace>' to read it.
    #61 bwilson4web, Sep 29, 2015
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Thanks Bob. I tend to record a lot of data in columns. If I can whittle the results down into something presentable, I'll use the tags.
  3. S Keith
    799
    329
    AZ
    2003 Prius
    Okay, officially in the deep end. Bought a 125Ah deep cycle marine battery so I can have enough capacity to cycle.
    The other pack peaked at 238V and retreated to about 233 over 24 hours. Comfortably warm to the touch.
    Steve
    #63 S Keith, Sep 30, 2015
    strawbrad and bwilson4web like this.
  4. bwilson4web
    16,007
    +++ ROTFMALO
  5. S Keith
    799
    329
    AZ
    2003 Prius
    I hope you're laughing about just the Tinactin... :)
    #65 S Keith, Sep 30, 2015
    bwilson4web likes this.
  6. bwilson4web
    16,007
    Mostly I'm loving your toys! Much nicer than mine.
    I don't see a problem. The Toyota modules have six cells with a common space open at the top. This tends to keep the electrolyte 'level' constant across all cells. The KOH electrolyte is amazing stuff that 'climbs' walls . . . and eats organic material. I have no doubt 'the blob' is externally KOH.
    S Keith likes this.
  7. S Keith
    799
    329
    AZ
    2003 Prius
    Thanks for the feedback.
    #67 S Keith, Sep 30, 2015
  8. bwilson4web
    16,007
    Ordinarily, I would only discharge to 5.8 V and never tried to go lower. I did have self-discharged modules less than 5.8 V that recovered. Just I've never actively mapped that area.
    Let me suggest using one of the older NHW11 modules as a test article. If it goes bad . . . well what is one more bad NHW11 module as there are so many.
  9. S Keith
    799
    329
    AZ
    2003 Prius
    Thank you for the suggestion. I only have 2 NHW11 modules that show any performance whatsoever, and they're "like-new". All of the others were low or EXTREMELY low. AVERAGE voltage of the entire pack was 1.41V.
    Hybrid automotive recommends discharges as low as 0.5V/cell and 0.1V/cell with very low loads.
    Pack sat for at least 2 months. Here are the top 15 as-removed voltages of the Gen1 modules:
    7.26
    6.74
    4.80
    4.50
    4.29
    3.37
    3.15
    2.59
    2.43
    2.25
    2.19
    2.05
    1.73
    1.54
    1.14
    The top two are the only ones that showed ANY sign of recovery, and they are near 100%. With one exception, everything else is at or below any deep discharge voltage I'm interested in, and they didn't recover, so I'm not sure there's anything to be gained testing them.
    As I have 56 Gen2 modules, I'm inclined to use the one that has shown deterioration from cycling. It also exhibited odd discharge behavior. It dropped rapidly below 6V. This suggests to me that a single cell is very weak and likely went flat/reversed below 6V. Here's it's final discharge profile:
    Red = Voltage; Black = mAh, Green = Current
    Capacity to 6V is less than 2500mAh. As you can see at about 6 minutes, there's a blip in the voltage. I believe this was a cell reversal. It drops rapidly to 5.4V, yet it sustains current for some time. Healthy modules slowly drop to 5.4V (well, fairly rapidly from ~6.3V) and immediately start tapering current way faster. Now that I think about it, this may be a bad choice as an already dead cell will disrupt any results. Maybe I'll just keep gnawing through the pack and see what i have left over.
    Here's a more healthy profile from another module:
    #69 S Keith, Sep 30, 2015
  10. strawbrad
    953
    1,002
    Steve this is an awesome thread packed with useful information. You Honda guys are ahead of us Prius guys on battery theory. I have not had the time to respond so a lot of stuff is getting thrown together here.
    The Gen I batteries are just a bit smaller. The terminal bolts do not line up if generations are mixed. I have seen it done with the bus bars just being bent. The Gen I batteries were beat to heck by the stronger Gen II modules. Gen II modules are a tight fit in a Gen I case. The case cover will contact the plastic terminal guards.
    I just got one of these chargers. I have been using old Integy 16X7 Pros. They can discharge internally at up to 30 amps.
    I use a rock tumbler with Dawn dish soap, Citric Acid, and stainless steel shot. Citric Acid can be found in the canning supplies in grocery stores. They come out nice and shiny in just a hour. If the bus bars sit for any length of time they tarnish and will need a quick brushing before assembly. I find a fine nylon rotary brush works well.
    Do not let Kiwi know that high rate dischargers with logging exist.:cool: I think these will become the gold standard of chargers.
    I think that all battery tests are comparative. The best you can do is be very consistent in your testing. Then your results will mean something. I have found IR very difficult to measure. It is just too dependent on timing. The automated measurement of your charger should at least be consistent.
    That is the million dollar question. Please retest your two good Gen I modules in a month and let us know if they retained their capacity.
    I have always discarded modules that self discharge below 7 volts. I might raise that threshold to 7.2 volts. I tested one module that had discharged to 6.74 volts. Sheet metal screws were inserted through the top of the module to contact the cell interconnects. Five of cells measured 1.2 volts and the sixth was at .74 volts. The low voltage cell also had minimal capacity. In the re-hydrating thread I cut the top off a Gen I module. Five of the cells had 6 Ahr capacity and the sixth was dead.
    Currently I discharge modules at 20 amps to 5.4 volts. The next day I record the voltage they recover to, typically 7.3X to 7.4X volts. I let them sit at this low SOC until needed, at least a couple of weeks. Starting at a low SOC exaggerates the effects of self discharge. The modules either stay close to where they started or drop to 6.5 to 7.0 volts.
    Gen II and Gen III do not fit well into a Gen I case Toyota would never smash modules into a case they were not desinged to fit.
    If done honestly and not manipulated resting voltage is a good indicator of module health.
    Bob, do you believe cycle charging, deep discharge, or any other tricks can improve the performance of modules?
    I use an Electrophoresis power supply to grid charge a whole pack. At a 500 mAhr rate a pack will peak at 241 volts and then drop to 230 volts. The pack will start to heat only after the peak is reached. I let the modules sit overnight before discharge testing
    I have tried deep discharges on a few modules. It does not seem to hurt or help.
    Huh? I have cut modules apart and seen several that have blown there tops off. The electrolyte is a black goo the consistency of toothpaste. It is confined to the space between the plates. The open space at the top of the modules will evenly distribute oxygen and hydrogen gas. Bob, you have also seen the insides of modules. Why are we seeing this differently?
    What I have found is that the Toyota batteries also fail by cell.
    I think you will find just as many weak Toyota cells as Honda cells. The data logging of you chargers should show individual cells dropping off.
    Let them sit for a month and retest to see if they retained their like new performance. The 7.24 volt module has a chance. I think the 6.74 volt module will return to its old ways.
    Keep up the good work!
    Brad
  11. bwilson4web
    16,007
    I have seen no evidence of this in my testing with the 989. My thinking is the cycle charging is more likely addressing cell imbalance in traditional, individual cells wired in series. So it gives the illusion of 'better' to RC hobbist. If the Honda packs are isolated cells, cycling to balance the pack makes sense.
    Our NHW11 modules have a common passage way so the electrolyte should even out. It is only when the electrolyte is reaching too low of water content that the weakest cell (the most dry one) limits the module capacity. Add water, and cycling rebuilds that cell and thus the whole module.
    My current thinking is the cell capacity is more of a surface, not a volume effect and driven by the:
    Ni(OH){2} to/from NiO(OH) # charge and discharge effect​
    When I disassembled my module, the 'charged' compound was a redish surface on the Ni electrode. The other was ordinary, metalic color:
    • left terminal closest to non-functional pressure relief valve is redish
    • right terminal is nickel colored
    Now I'm going 'off the reservation.' I suspect the energy storage come from the OH+H to H{2}O exchange and the electrodes simply provide the physical storage of the OH and H reactants. I've just seen multiple modules reclaim slightly higher than 6.5 AHr capacity after adding water and cycling to reform the surfaces.
    When I disassembled the module, I tried to cut above the electrodes, through the top:
    Not shown, I dumped the parts in a 5 gal bucket of water as it self discharged. Once everything evened out, I was able to recover the smaller parts that were not 'chewed up' by the saw:
    and
    Half of the nickel electrodes are these perforated nickel plates embedded in the metal hydride paste with the plastic mesh separator from the other half of the nickel electrodes. I did not see how these electrodes were buss connected because my interest was in how to seal the water hydration holes.
    SPECULATION: increasing the surface area of the nickel relative to the volume will increase NiMH capacity substantially. A nickel wire, 'cloth', using fine wire weave would maximize the surface area relative to the volume of nickel. The edges would be melted (this is a very high temperature metal!) to form the current buss.
    Using a nickel wire 'cloth' would make NiMH energy and power density compatible with LiON but without the formation of non-reactive compounds of current generation LiON. Best of all, nothing is water reactive.
    I would also look for high temperature separators including ceramic mesh or even asbesdos. What kills the cell is current concentrations that causes spot melting of the plastic mesh separator.
    Finally, I would make the pressure relief valve do double-duty as a hydration port. Hydrogen gas is generated under pressure and will always find a way to 'escape.' We can slow it down but not stop it. The metal hydride is a hydrogen sponge but the case and terminals remain a hydrogen gas loss mechanism.
    #71 bwilson4web, Oct 1, 2015
  12. S Keith
    799
    329
    AZ
    2003 Prius
    Brad,
    Too lazy to quote and paste. Will just free-form it.
    Concerning Gen2/3 into Gen1, I see now. The module is longer, and the terminal heights are different relative to the case.
    Most of the Honda stuff was out of necessity. 6 - 12 isolated "D" cells that can't exchange electrolyte are far more prone to single cell failure within a subpack (module). Mike Dabrowski of Insight Central pioneered it about six years ago. He developed the basic design that has evolved into the Hybrid Automotive grid charger and his cadillac version, the Genesis One, which is now owned and sold by Hybrid ReVolt here in AZ. The guy is a tinkerer and very capable. Devised a lot of experiments and demonstrated the great benefit of deep discharging subpacks and whole battery packs. He even devised a MIMA (Manual IMA) system to give the driver near total control of the IMA charge and discharge system. You can read his stuff on 99mpg.com.
    My contributions have been primarily towards developing a refurb method that works for me and testing various theories.
    Thanks again. I'm still in the process of testing and collecting data. It will all end up in a Google sheet for all to see.
    Steve
    #72 S Keith, Oct 2, 2015
  13. jgrinz
    jgrinz New Member
    MA
    2003 Prius
    I have a no document grid charger I want to connect to my 2003 ( Sorry to hijack)
    Gen 1 - Can someone take a picture of one that is connected OR inform me of which terminals it connects to in the casing.
    Battery just sat too long and is good just very low and will not start the car. I would assume this is my best avenue to bring it back to life,
    Any help would be appreciated.
    Thanks
  14. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Contact me directly and I can help you out.
    I have not heard of other Gen1 Prius chargers.
    It would have to be higher voltage than a Gen 2 Prius charger.
    Alternately you may need to split the pack when charging.
  15. S Keith
    799
    329
    AZ
    2003 Prius
  16. S Keith
    799
    329
    AZ
    2003 Prius
    In case anyone was wondering...
    I'm almost there. Modules installed in pack. Need to pre-charge the modules for the target balance point, re-install all the electronics and attach the bus bars. My oldest son will be here tomorrow to help with the install (this bastard is heavy!)... Hopefully, I'll have a running Gen1 by tomorrow.
  17. S Keith
    799
    329
    AZ
    2003 Prius
    Finally. The pack is in, though the installation is only partly complete, all connections are made, and data was collected.
    0.14V Max-Min Delta at rest. I'm happy with that.
    Load test:
    It took a little trial and error, but I made it work. Heavy load delta V looks pretty good - almost as good as the Gen2 I tested. Aside from the transients early and one near the end of the test, the delta V is very good. I'm happy with that too.
    The measured capacity was 1,453mAh assuming that the "IB Main Battery" field is reporting the load current. If it's not, then I'm full of hooey.
    The extrapolated SoH is bunk due to the fact that I only used 22.5% of the total range, and I gave the car NO opportunity to establish an SoH range. Also, I know the capacity of each and every module in the pack, and NONE are anywhere near that.
    Module capacity ranged from 4200 to 5300mAh. I didn't have any better options. I compensated by pre-charging so that they will all have the same SoC at about 65%. I also sorted the modules weakest outside, strongest inside with the capacities in each block matched typically within less than 100mAh.
    Originally, I had an arrangement where strongest was paired with weakest, but I became concerned that the stronger module compensating for the weaker module would drive the weaker module harder and hasten its demise. As it is, the pack should be limited by the capacity of the end blocks, which is around 4200mAh.
    I'm very pleased with the results. This has been a long time coming, and I couldn't be happier with these initial results.
    Thanks,
    Steve
    #77 S Keith, Dec 20, 2015
  18. DRACO
    DRACO Member
    362
    77
    Rancho Palos Verdes, California
    2002 Prius
    Whoa! Holy Poop Batman, that is some awesome initial readings.
    Purty Please update us after 30+ days. Would love to see field use readings :D
  19. S Keith
    799
    329
    AZ
    2003 Prius
    Emissions testing, registration and insurance first... :)
    Now I have to see what the ICE may need... :)
  20. S Keith
    799
    329
    AZ
    2003 Prius
    So far, so good. Emissions passed. Car tagged and titled. No additional codes and ICE systems appear to be fully operational.
    Dog hair and interior smells are the worst things to deal with atm.. :)
    Steve
    usnavystgc likes this.
