Cost of electricity with plug-in Prius
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by laplante236, Sep 4, 2011.
  1. laplante236
    laplante236 Junior Member
    Electricity is pretty expensive here in CA if you go over your alloted basic service kilowatt hours. I had a friend who had an electric golf cart who complained about how high his elec. bill was due to charging his golf cart. I wonder how much more people are paying per KW for the plug-in feature on the new Prius models and other brand plug-ins? Will the utility companies give a reduced KW hour rate? Anyone know?
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    Kwh, NOT kw.
    Would you like to know my local utility kwh cost, or are you more interested in yours ?
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    It's depends on how close you are to the next higher tier rate. If you are on the bottom rate with room to spare then it's not big deal. The Prius plug-in has a rather small battery so your electricity use should be low compared to a Leaf or Volt. If you are at the highest rate or close to it then an electric vehicle may be more expensive to operate than a non- plugin Prius.
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Some of them have a specific EV rate. Some of them have time-of-use rates. GIYF.
    But, remember that if the PHV battery has 3.5kWh usable then charging once per day the Prius PHV would only use at most 118kWh per month. It would be less of an issue than a longer range EV.
    It won't matter though. For many Californians expensive electricity will mean they'll not plug in at home and consider the extra cost of the car worth it for the HOV lane sticker.
  5. SageBrush
    11,627
    2,531
    Southwest Colorado
    ^^ cynical, but probably true. Hopefully some will be persuaded to install PV
  6. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Cost of Kwh per state. Hawaii pays 31.04 cents/kwh, but gas is also much more expensive!
    Electric Power Monthly - Average Retail Price of Electricity to Ultimate Customers by End-Use Sector, by State
  7. SageBrush
    11,627
    2,531
    Southwest Colorado
    ^^ lots of variation within states, and tiers, too.
  8. drash
    drash Senior Member
    2,487
    1,258
    Upstate NY
    Would this be different if, say they charged it between 3:00AM and 6:00AM? In other words, put the charger on a timer.
  9. Sergiospl
    3,938
    1,351
    28
    In Central Florida, work is 12.2 miles roundtrip from home. One charge per day: 3.5kwh x 30 days at $0.11182 per kwh = $11.74 dollars per month.
  10. Sergiospl
    3,938
    1,351
    28
  11. drash
    drash Senior Member
    2,487
    1,258
    Upstate NY
  12. Sergiospl
    3,938
    1,351
    28
    Correct me if I am wrong, I think the Leaf can be programmed inside the vehicle to begin charging at a designated time, will the Prius PHV has such a program?
  13. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    A few things to realize here. First, if you're on regular plan and have CARE discount, DON'T SWITCH YOUR PLAN!!!!!. With CARE program you only pay $.085/KWH for Tier1 and $.095/KWH for Tier 2,3,4,5. E9A plan places your whole house on discounted rate for EV owners while E9B requires PG&E to add a second meter for your electric car. I made the mistake of switching to E9A and lost the CARE discount. To PG&E, CARE is still on my account but CARE does not apply the discount. I switched at the end of January. When I got my bill, I found out that there's no CARE discount for E9 rates. After calling PG&E many many times to switch back to my regular plan they finally did because they failed to inform me that CARE does not apply to E9 rates and once you switched, you're locked to that plan for 12 billing cycles. Give you an idea what the difference in cost was, My August bill (July usage) was $320 for 1600kwh.
    They finally switched me back to my old plan on July28th (my billing cycle ends) after 6 months of E9A rate and rebilled Jan 28th to July 28th. I had about $130 credit as oppose to $320 bill that I had to pay for August bill.
    Second, my 4KW Enginer takes about 140-150kwh per month to charge. It's not Enough to make the switch.
    Third, Toyota's 3.5kw of usable electricity is not enough to last you the whole day. If you think you can wait til 12AM to charge you're sadly mistaken. I thought I could too but once that SOC hits 20% and it's only 11AM, you'll want to plug it in and charge regardless what time it is.
  14. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The PG&E CARE program is only for low income households. $31,800 per year for a household size of 1 or 2.
  15. cproaudio
    2,401
    760
    CA
    I live by myself and make just below their cutoff line.
  16. drash
    drash Senior Member
    2,487
    1,258
    Upstate NY
    Don't know. Maybe we'll find out September 12th, 15th, or maybe we'll have more questions. We are a whiny group here but that doesn't seem like a huge problem to me since timing outlets are fairly common with pools and hot tubs as well.
  17. Sergiospl
    3,938
    1,351
    28
    Hope something new about the Prius plug-in will pleasantly surprised those of us waiting. We are almost there, about 10 days.
  18. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    I live in North Texas and pay 9.5 cents/kWh. So, it will cost me 9.5 x 3.5 = 33.25 cents to charge a 3.5kWh battery.
    The reveal of the Production Prius Plug-In is on Sept 13, at Media Day, two days before the Frankfurt Auto Show opens. -- Just nine days away.
  19. hill
    8,276
    I got news for you ... a cheesy little golf cart charger doesn't use 1/3 the juice of a typical central AC unit. If your friend has central AC, a 15 year old SEER 6 unit can easily run you $7/day during California summers ... whereas that little 36 volt (probably) 12 amp golf cart charger may run you $2/day if you charge for 10 - 12 hours. It's the same low powered charger we have for our electric boat. No - it's more likely your friend's electric bill got expensive because he left a refrigerator door open, or the AC was set too low. Have your friend WALK the golf course one month ... and use no AC one month. Then come back and tell us which cost more.
    2 people like this.
  20. drash
    drash Senior Member
    2,487
    1,258
    Upstate NY
    Using no AC or pool heaters or pool pumps for a month is rather huge. Of course running an old freezer/fridge that's losing refrigerant can also put a huge dent in your pocket.
