Crasher parts to convert to pip
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Mr.Electric, Jan 21, 2014.
  1. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    I think it would be the Project From Hell. Maybe you could settle for pulling the pip battery and wiring it up in parallel with your own?
  2. xliderider
    xliderider Senior Member
    8,125
    3,265
    Honolulu, HI
    I'd like to get my hands on the PiP's tail lights. :D
  3. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    I think it would be a fascinating project. If you start to really think about it I would spend some serious time with the techinfo website:
    https://techinfo.toyota.com/
    Its something like $15 for 2 days, $75 for a month of full access to all the toyota service manuals. I would think you could figure out a lot from there by looking at part numbers and notes between the standard prius and pip manuals / diagrams. Once you have the real scoop on whats unique, you could assess whether all those parts seem to be intact on the donor. Of course, unless the donor is really cheap (assuming they are giving him a buy out option?) I wouldn't think it would make any financial sense, but maybe that's not the point ;)
  4. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    They are not the same, MG2 is bigger on the PIP.
  5. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Is MG2 in the PIP the same as in the Lexus HS250h? The larger 2.4l in the HS might be an interesting swap into a PIP.
  6. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Have no idea.
  7. miscrms
    2,079
    526
    Phoenix, AZ
  8. miscrms
    2,079
    526
    Phoenix, AZ
  9. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    I read on Prius chat in another thread that the non plugin had a 50kw m2, i did not research it at all. Anyway just me but I would not dream of doing what you are tinking of doing, as there are so many things that may be different that aren't documented well and could wind up being a problem down the road. Juat my 2 cents worth. Buy a new base 2014 plug in and forget it. Dont forget the $2500 tax credit if you do buy a new one.
  10. miscrms
    2,079
    526
    Phoenix, AZ
    Ok, I think the 50kW vs. 60kW refers to the Gen2/Gen3 difference, vs. the Gen 3 vs. PIP. I wonder if this is another case where the discussions related to the "pre-production" PIP in 2009/2010 have confused the issue. As I recall the pre-prod PIP did use the 60kW MG2 that would become standard on the Gen 3, whereas the 2009s that were still considered the "standard" prius at that time were Gen 2s and still had the 50kW.
  11. drash
    drash Senior Member
    2,553
    1,297
    Upstate NY
    Probably not since the HS250h mg2 is 107kW and the PiP's is only 60kW.
    iPad ? HD
  12. markabele
    5,084
    1,782
    Nebraska
    As it looks like you found out above...yes, they are the same.
  13. Bill the Engineer
    1,048
    2,278
    467
    Sounds more and more like my convertible project need the Lexus powertrain. The finished conversion will be heavier than a Prius.
  14. drash
    drash Senior Member
    2,553
    1,297
    Upstate NY
    Sounds awesome if you can fit it in. Physically the 107kW motor probably isn't much larger but the connections might require you to put in the entire ECVT unit as well.
    iPad ? HD
  15. miscrms
    2,079
    526
    Phoenix, AZ
    I think the Camry Hybrid one is the same specs as the HS250h? Might be easier/cheaper to come up with one of those than the Lexus version?
