Custom Polycarpet Dashboard Cover for 2010 - 2011 Toyota Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bagwell, Jan 5, 2011.
  1. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    49,798
    looks interesting, but i would want to see and touch one before buying. i've seen some that look cheesy.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Can't imagine that one would be any easier to keep clean.
  4. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    How would you clean dust off of it? Vacumn? I currently just use my Swifter. I don't think it will cut down noise - to do that you need to insulate under the floor carpet and around the wheel wells.
  5. bagwell
    592
    49
    the woodlands, tx
    I figured it would absorb more sound than the plastic dash.
    as far as cleaning it.....remove and use compressed air.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    So it is not permanent. That would be interesting then. Please let us know how it works out for you. ;)
  7. dctalk523
    dctalk523 Member
    The OC
  8. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I have never noticed any noise reduction from a dash cover. I'm sure there is some reduction but think you would need some good instrumentation to measure the difference.
    There are other good reasons for a dash cover though, so if you get one please post some installed pictures.
  9. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    I got the one that Costco offers, chose the fuzzy version, rather than the matte. Well made, and the people are nice to deal with -- called me up to make sure about the vent locations, etc. But it actually made glare worse -- the "fuzz" consists of near-microscopic whiskers, all parallel, and with smooth surfaces, that reflect in the windsheld when they catch the sun. If these give you the option of a felt-like finish, I recommend you try that, rather than the plush.
  10. reloader775
    reloader775 Compression Ignition Addict
    Orange County
    Any update? Did you purchase that one or a similar one? I'd like to see pictures!
  11. wstevensiv
    wstevensiv New Member
    84
    Little Rock
    i wouldnt buy it as it seems to cover up the front speakers
