Damage due to low height
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jane Voelkel, Nov 17, 2014.
  1. Jane Voelkel
    Jane Voelkel Junior Member
    My 2012 Prius is in the body shop for two days due to significant damage I have done to the bottom of the front bumper, and the general front end, including the tie bar, from pulling too far forward in parking spaces. I have rubbed the bottom of the car on the concrete parking barrier. I am used to being able to pull forward quite far, but the low height of the Prius makes this impossible. Has anyone else had this issue? Thanks.
  2. Okinawa
    Okinawa Senior Member
    1,333
    317
    I have not had that issue but it is very hard to keep from having it. You just can not judge how close you are getting to the concrete barrier. I had a Prius and I could not judge it. I have a new Avalon and I can not judge it either. I have just been lucky. Other people with different makes of cars have the same problem. Rest assured it is not just you. Other makes of cars will not clear some of the barriers. I try to stop a little far back then I take a look and pull up a little if I need to. That works pretty well for me.
    #2 Okinawa, Nov 17, 2014
  3. mracko
    mracko Junior Member
    31
    Bayfield, WI
    Ground clearance and how far the front of the Prius sticks out are the only big issues I have with the car. I wish the car had more clearance to drive through the snow rather than being a plow. The plastic under engine cover didn't last too long in the winters we get up here. I stopped counting how many times I have touched the front bumper to the curb when parking.
  4. StarCaller
    StarCaller Senior Member
    1,240
    692
    Cedar Crest, NM, USA
    yeah, that makes my day & gives me hope - living in a rural area with no snow plow ever showing up...../
    (& being lowered around 1")
  5. bisco
    49,078
    take comfort, your in a very large majority. try pumping your tyres unto 42 psi, sometimes a few centimeters can make all the difference.
  6. 2010 prius in PA
    2010 prius in PA Junior Member
    22
    pennsylvania
    Wife mostly drives ours, and has scraped it big time on several occasions, including on parking markers. Already had to replace front bumper once, and it's showing wear already. Worst part about driving the Prius...
  7. FuelMiser
    FuelMiser Senior Member
    1,273
    866
    Monument, CO
    This car is so short, there's no need to pull "all the way in" to a parking space--until the tires hit the stop. Just plan on leaving the car well away from the front stop! Geez.
    Okinawa likes this.
  8. BruceN
    BruceN Junior Member
    Winter Springs FL
    I have this problem as well. I hate the low clearance of the front bumper.
    I have learned to pull into the spot short, shift into reverse, and check to see if the rear of the car has gone by the parking stripes. If so, I stay there.
    Okinawa likes this.
  9. ETC(SS)
    6,502
    One of the only reasons that I've had to leave my (work) Prius in the barn and take my truck is the Prius' diminutive ground clearance.
    As long as it takes fuel to push air out of the way, then that's just part of the price of doing business in 'being green.'
    Still....it's not been much of an issue so far in my 76,000 miles in type. I have to occasionally visit sites in some pretty rural areas involving non-paved roads and I've been pleasantly surprised by my car's ruggedness.
    No.....it's not Rubicon rated and running up on a parking lot divider can ruin your day....but I've seen people trash their vehicles on those before Priuses came out.
    You have to swerve to avoid some road debris that you can just center up in other vehicles, and some incidents will send Priuses to the fender and body shop more quickly because of its glass jaw.
    BUT
    This isn't a Prius-only problem.
    Look on the bright side....
    If you would have center punched the lower cowling in a low slung muscle car, then the repair would have been more expensive......
    .....just like the Purchase Price, Insurance, and Operating costs. ;)
  10. BruceN
    Winter Springs FL
    <I have learned to pull into the spot short, shift into reverse, and check to see if the rear of the car has gone by the parking stripes. If so, I stay there.>
    Forgot to say, using the back up camera.
  11. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    It's a common problem, I've had it often
  12. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    My wife has done this too, twice, cracking the black air dam in two! I told her it's a short car, there's really no reason to pull up all the way to a parking bumper.
    We sort of jerry-rigged the air dam back together the 1st time. The 2nd time, I just unscrewed the broken pieces of the air dam from the bottom of the front bumper. Not sure the air dam is worth replacing. It was also always scraping when I exited my alleyway, just because of a very slight dip where it meets the street.
    #12 ggood, Jan 22, 2015
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Well at least you know you're not alone.
    Yes, it happens. Especially if you are coming to Prius, from a vehicle in which you could pull all the way in.
    Just a learning curve. Hear that scraping sound a few times and you start to learn NOT to pull too far in.
  14. Former Member 68813
    3,524
    981
    US
    My wife and daughter do it every time they drive the prius. Always in hurry and fail to learn too. I just shut up now for the sake of the marriage.
    Patrick Wong and frodoz737 like this.
  15. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    I stopped curbing the front tires 34 years ago when I discovered that the oil pan in my VW Rabbit would hit before the tires did.
  16. Jim Shannon
    Jim Shannon Junior Member
    78
    34
    Janesville, Wisconsin
    For those with a back up camera, how many folks back into parking spaces? I always have as a habit (makes getting out much easier) and with this technology, the issue is resolved. I understand there are exceptions, i.e. angled spaces.....
  17. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    I occasionally do it if it makes the car easier to load.
    Most people I've seen do a terrible job in terms of centering and angle.
  18. prinut
    prinut Pri Nut
    102
    23
    SouthFlorida
    Suggested solutions:
    1. If you have a steep driveway or a deep gutter before your driveway, approaching at a angle may give you a bit more clearance.
    2. Yep, backing in rather than heading in usually works. One of the main problems I've seen is when the iron bar sticks above the concrete, even if it is 1/2". It can really do a number on your front. Suggestion #1 will always solve that problem.
    3. Friendly_jacek and others with a similar situation, if your wife and daughter keep scraping or damaging the air dam, get them to pay for the repair. Paying by $ always expedite the learning process!
  19. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    I back in 100% of the time (where possible). I do not us the back-up camera to back up (camera only to judge distance) - I use the outside mirrors. Using the mirrors I can easily position the vehicle wherever I want, centered, or offset to compensate for others parking. When I am alone I look for a space where I can back in close to the curb on the pass. side. This gives me extra room on the drivers side to exit & the next parking space is that much further away. Also, I don't mind walking an extra 50-100' to get away from the high-traffic areas.
  20. Tande
    Tande Active Member
    498
    301
    Mich.
    Just be glad you don't have a "Volt"! .......3" min. G/C, (From what I've read).....:rolleyes:
