Did Lockheed Martin Solve Nuclear Fusion?
Discussion in 'Fred's House of Pancakes' started by Onager, Oct 17, 2014.
  1. Onager
    Onager Junior Member
    Holding my breath! :D
    Lockheed Martin's Compact Fusion technology has the potential to revolutionize life as we know it. Maybe. If it works.
    After years of development at the company's legendary Skunkworks facility, Lockheed is coming forward now to find partners in the public and private sector. The main breakthrough is having shrunk the size of the reactor into something about the size of a shipping container.
    Here's the deal, and why it could be really cool.
    Unlike nuclear fission (the splitting of atoms, like current nuclear reactors), fusion does as its name suggests, it fuses atoms together. This is what our sun does to create sunburns and life and stuff.
    Fission is messy, and leaves all sorts of nastiness behind (that is, radioactive waste that's untouchable for, well let's just say effectively forever). Fusion power, on the other hand, is much cleaner. In the case of the current version of Lockheed's Compact Fusion tech, they're using deuterium (found in seawater), and tritium (found in lithium, found in the ground). This fuel mix can result in "10 million times more energy than the same amount of fossil fuels." Future versions could use different fuel.
    locheed nuclear fusion - Google Search
  2. ETC(SS)
    6,495
    Holding MY breath!
    Substitute "reactor" with "bomb" and you get...........
    Fusion Bombs (reactors)
    Fission bombs worked, but they weren't very efficient. It didn't take scientists long to wonder if the opposite nuclear process -- fusion -- might work better. Fusion occurs when the nuclei of two atoms combine to form a single heavier atom. At extremely high temperatures, the nuclei of hydrogen isotopes deuterium and tritium can readily fuse, releasing enormous amounts of energy in the process. Weapons that take advantage of this process are known as fusion bombs, thermonuclear bombs or hydrogen bombs. Fusion bombs have higher kiloton yields and greater efficiencies than fission bombs, but they present some problems that must be solved:
    • Deuterium and tritium, the fuels for fusion, are both gases, which are hard to store.
    • Tritium is in short supply and has a short half-life.
    • Fuel in the bomb has to be continuously replenished.
    • Deuterium or tritium has to be highly compressed at high temperature to initiate the fusion reaction.
    Scientists overcome the first problem by using lithium-deuterate, a solid compound that doesn't undergo radioactive decay at normal temperature, as the principal thermonuclear material. To overcome the tritium problem, bomb designers rely on a fission reaction to produce tritium from lithium. The fission reaction also solves the final problem. The majority of radiation given off in a fission reaction is X-rays, and these X-rays provide the high temperatures and pressures necessary to initiate fusion. So, a fusion bomb has a two-stage design -- a primary fission or boosted-fission component and a secondary fusion component.........
    It's all fun and games until it gets weaponized. ;)
  3. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,546
    Scaling this down to being portable will change the face of the planet.
  4. Onager
    Well after reading ETC's comments, a punch in the gut I might add, I suppose a terrorist would love to have an Electric Ford Fusion powered by a miniaturize fusion reactor. Park within three miles of your target and hit the self-destruct button.
    Hey, I suppose the "Green" crowd would love this too. At the end of its life just hit the self-destruct button, PooF!!! all gone.
  5. Trollbait
    11,328
    A fusion reactor is less weaponizable than a fission one. They are even less a threat in case of an accident. Any loss of contaiment in a fusion reactor means the reaction stops. There is no bang, but a fizzle.
    If it wasn't clear from ETC(SS)'s post, in order to get the sudden burst of fusion reaction in a hydrogen bomb, as opposed to the slow and steady one of a reactor, you need to use a nuclear bomb as a blasting cap.
    Onager likes this.
  6. Onager
    I knew that! :rolleyes: Wasn't a bit worried.
  7. fuzzy1
    10,048
    That is just investor relations claptrap.
    I refuse to call it a 'breakthrough' when contained human-controlled fusion still doesn't work in any size container.
  8. ETC(SS)
    6,495
    That's absolutely correct.....they're "less" weaponizable.
    Actually?
    I don't have a problem with fusion power except of course that it's not currently feasible....and won't be for a while.
    As long as they can tinker with it without reducing the planet count in our Solar System....I say more power to them.....pun almost unintended.
  9. Trollbait
    11,328
    Fusion is a long term solution. Like fuel cells, we should invest in them because they have potential down the road. Fuel cells, while still expensive, are being comercially used now. We need to keep that in mind when it comes to funding fusion research. It took a hit in the US with cheap oil a couple decades back.
    Likewise, we shouldn't pass over interm solutions because they aren't ideal. Fission power can be done cleaner and safer. Even, ugh, 'clean' coal can help. I think most here would prefer natural gas for a base plant, but does mean supporting fracking.
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Is fusion just beyond us? Is it like the Victorians trying to master radar or nuclear power? Do we keep investing hoping we'll suddenly work it out or do we just advance as normal and let it happen when the time's right? Nuclear fusion has been 'nearly there' for as long as I've been alive. It still hasn't happened.
    #10 GrumpyCabbie, Oct 18, 2014
  11. Trollbait
    11,328
    Fuel cells was 'nearly there' for some time too. While I don't think they are ideal for cars, they have made great strides in making them affordable. It might take some time to get working fusion, or even never, but we have to keep plugging at it until then.
  12. fuzzy1
    10,048
    Fission has been here longer than I have been alive.
    I think you meant fusion, which was never 'nearly here'. It has been '20 years away' for 50 to 60 years.
    GrumpyCabbie likes this.
  13. Zythryn
    Zythryn Senior Member
    6,174
    4,170
    I wouldn't suggest it. 5 years to a prototype and 20 years to production is what they are saying.
    That is a long time to hold your breath:)
    Breakthroughs are great, however I won't be holding my breath until we are close to production.
  14. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Yeah I did :unsure:
    Corrected (y)
  15. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    The one compound referred (Lithium Deuteride) I believe is a fairly fabulous H2 adsorbent for storage.
  16. Onager
    That must be nice. :confused:
  17. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Interesting post. Thank you.
    The first I heard about this was in The Guardian. The article was full of scientists rubbishing the claims, and saying there was no evidence.
    Lockheed announces breakthrough on nuclear fusion energy | Environment | theguardian.com
    I think that's pretty questionable. They criticise LM for not releasing enough detail, and that as scientists they need evidence. And then they make their own assumptions, saying it's almost certainly not true, based on.... no evidence.
    I think a lot of it is (a) The Guardian's hostility to America, (b) The Guardian's hostility to big corporations, (c) The Guardian's hostility to the defence industry, and (d) the scientists who've been quoted being unhappy about the possibility of a corporation cracking the problem when they haven't managed it themselves.
    I would assume that, if the claims are true, LM has many, many good commercial reasons for not releasing all the information. There's an absolute s--tload of money to be made here after all.
    But I can also see that, in the absence of evidence, and on the assumption that LM can make financial gains purely out of making the announcement, there's every reason to think it isn't true.
    So I don't know what to believe.
    But I hope fusion is on its way reasonably soon.
    #17 hkmb, Oct 19, 2014
  18. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    My understanding is that the key problem is how to contain the 300,000,000°C heat that the fusion reaction generates. You need to be able to create some sort of casing that can maintain the reacting particles in a steady position at that temperature, and at the same time stop the energy from leaking out so that the reaction doesn't fizzle out.
    I can see why this is important. And I know they're looking at various methods, including extremely strong magnetic fields, to do this.
    What I don't understand is why they haven't looked at the obvious containment solution.
    On the outside, it's cool to the touch. On the inside, it's at least 300,000,000°C. Maybe more.
  19. fuzzy1
    10,048
    I don't see anything in there claiming that they have yet succeeded in making fusion work. All the good sounding stuff is written in the future tense.
    So this is still vaporware. As they say on PriusChat, "pics or it didn't happen".
  20. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Do people buy those more than once? Once being the time they totally scalded the roof of their mouth, where they were unable to eat solids for a week and then swore blindly never to touch one again? Or was that just me? (n)
    hkmb likes this.
