Did Prius miss the boat? Stealth operation
Discussion in 'Gen 3 Prius Technical Discussion' started by andyprius, Mar 2, 2011.
  1. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    IF: Stealth operation is such a fantastic and mpg improver, why hasn't Toyota incorporated in not only the Prius but each of thier hybrids??? Electronic stealth would be much easier on the foot and the psyche. :cheer2:
  2. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    Stealth means electric-only propulsion with the engine off (0 RPM).
    It's a fundamental part of the FULL hybrid (power split) design and is automatically engaged.
    You must be thinking of something else, perhaps pulse & glide.
  3. andyprius
    2,212
    188
    You are no doubt correct John, I was thinking of the Energy display when after warm-up and a fair to good charge, with a slight pressure on the pedal, no energy use is displayed, pure electric I believe is another mode which is easily attained when the no energy mode cannot any longer be obtained. SO.... if this mode is pulse and glide wouldn't it be much easier electronically?
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It would be harder on the batteries. The batteries are not there to make the Prius an electric vehicle, they are there to allow the ICE to be tuned for very high efficiency (compared to obsolete engines). About 10% higher. They provide power to move the car when the "Atkinson tuned" engine couldn't (low RPM for example) and to enhance the torque at other times.
    It's the "lunatic fringe" ;) users who use pulse and glide to get much higher MPG than Toyota intended.
    I suspect if Toyota engineers changed the design to utilize pulse and glide automatically it would dramatically change the battery life, and not for the better!
  5. bisco
    48,994
    they have incorporated much of pulse and glide in gen III.
  6. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    In my mind, "stealth" is achieved while coasting down hill, the ICE is off, no electrical power is being consumed, and no regen power is being stored. The HSI display is completely "blank."
    Living in the mountains, I use the technique all the time. I certainly do not want to consume gas with the ICE running on long downhills, I get uncomfortable when the display shows a "full" HV battery. The grades I drive enable me to drive the speed limit climbing the grade, and staying in the "sweet spot" (slightly above the speed limit) for a considerable distance descending. Interestingly, if I take it easy, and do not over accelerate going up the grade,(the displayed mpg does take a "hit") I find that by using the technique described above, the displayed mpg following the descent will be slightly higher than it displayed prior to climbing the mountain.
  7. macman408
    macman408 Electron Guidance Counselor
    1,179
    365
    Actually, I'd disagree. The ideal pulse and glide technique will use almost zero electric power. On the other hand, the "just drive it" technique may find you using quite a bit of electric power, depending on the exact conditions. Indeed, the battery is almost always at exactly 6 bars when I drive, while it fluctuates much more when my fiancée drives.
    Given the lower fluctuations in battery level, that would also lead to more normal battery temperatures, both of which would extend, not shorten, the battery's lifespan.
  8. john1701a
    12,749
    5,243
    57
    No arrows is gliding.
  9. abasile
    abasile Junior Member
    28
    Southern California Mountains, elev. 6130'
    I wonder how long our HV battery is going to last. Living in the mountains, I frequently drive in stealth mode to mostly drain the battery prior to significant descents, on which I then use regen braking to charge the battery to full. When combined with a bit of pulse and glide, this "technique" works wonders for fuel economy; achieving 65+ mpg (displayed) on roundtrips within the mountains is doable. My goal is to keep the gas engine off as much as possible. (The only trouble is, the better I get at this, the weaker my case to add a Nissan LEAF to our stable.)
    I'm not actually worried about the HV battery; even if it weren't under warranty, it should be possible to find a salvage replacement for not too much money (~ $500) if/when necessary. The extra gas savings should be more than enough to compensate for a premature battery replacement.
  10. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    Thank you for your comment .... I am just not sure what you are saying? I suppose you are referring to the fact that the same condition is possible while "gliding" whereas I mentioned only coasting down the mountain. And, I agree.
    As you well know, anytime you are "gliding" it takes a very small pedal pressure to keep from going into regen (in the mountains that is what I seek to avoid). I wish there was a switch/mode/tool or some way to keep it in the "sweet spot" without manually having to keep the foot on the accelerator pedal and applying just a small pressure. But that is a small inconvenience.
  11. bisco
    48,994
    shouldn't affect your battery, prius dumps the extra charging. not into the battery. it is well protected from over/under charging in all conditions.
  12. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Felt - John just means that in a Prius, the semi-official word for no arrows/no energy/whatever on your display is "gliding", and using electric only is a form of "stealth". So what you're doing is considered a glide by most other users.
  13. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    I agree. I always thought of "stealth" as being above 25 mph and not over 41 mph, just bumping the electric motor ever so slightly to maintain speed. Sound right?
  14. mikewithaprius
    656
    103
    Rhode Island
    Any use of pure electric at any speed is considered stealth. Once at and above 42 mph in the Gen II and 46 mph in the Gen III, you enter into the subcategory of warp stealth, still under the stealth umbrella.
    Personally I like to believe that there are ninjas somehow involved in this operation.
  15. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Unfortunately I can't get above 41 mph in "stealth" mode without turning on the engine. I thought all Gen III's were like that?
    LOL! Me to. :D
  16. andyprius
    2,212
    188
    I cannot speak for the Gen 3, but on my 2005, stealth is easy when the SOC is fair to high, at any speed, even 65 Mph. However it is all greatly affected by terain. It is sometimes very difficult to determine whether your going uphill or downhill . I use the 50mpg current energy bar to determine terrain as I believe the car has a levelometer incorporated into the Synergy System. Over 50 is downhill and under 50 is uphill ( a very rough method ). As for P&G, I think that mode is Energy neutral, no ICE/ no HV. I think also that P&G is a misnomer, as it describes a procedure and not the result. Maybe somebody can think of a better terminology......John? And, Bisco, tell us less fortuate souls, deprived of the Gen 3s How the car automatically assumes P&G, AND How succesful is its design? TY All. Great responses. :cheer2::cheer2::cheer2:
  17. andyprius
    2,212
    188
    Well said, that is exactly what I was driving at, any automatic electronic control would save and extend battery life and engine life. I agree, going down the Sierra to Sacto becomes quite a challege to NOT overcharge. Not that HSD will actually overcharge the battery. Full Green Battery = 80% charge and that's it. :D
  18. bisco
    48,994
    this is what i am trying to say. i think part of the reason the III gets better epa mileage is that the computers are now doing some of the things we have to manually do with our foot on the gas pedal in the II.
  19. john1701a
    12,749
    5,243
    57
    They are... at first... and then again when you get new tires.
    I had been getting up to 46 MPH with the engine off (0 RPM) up until 2 weeks ago, when I replaced the tires. Now, it's back down to 41. This is why we didn't notice the speed increase from 2010 upgrade right away.
