disable battery regeneration
Discussion in 'Gen 3 Prius Technical Discussion' started by djs, Oct 28, 2012.
  1. djs
    djs Junior Member
    NW WASHINGTON
    New member, but have been perusing this outstanding site for 3 yrs. 2010 gen III bought Aug 2009.
    Would it be possible to disable HV battery charging or regeneration (with torque pro regen coop)? This way I could use battery and ICE power when going up a long mountainous area, and end up with 30% charge at the top instead of 60%. Then on the way down I could use regen to build back up the battery. Thanks
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I am unclear what you are attempting. Regeneration happens when braking, if you do not hit the brakes, no regen.
    You can easily defeat any charging of the HV Battery by shifting to Neutral.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I can't speak to Gen 3, but on Gen 2, there is a bit of regen (no more than 19 amps or so, as I posted before at Best way to brake / decelerate? | Page 2 | PriusChat) if not using the brakes and going above say 35 mph. But yeah, there should be no regen if shifting to neutral.
  4. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    In my understanding, OP means change the target SOC (60%) to 30%.
    I think lower than 40% SOC is not good for the battery, but I have no idea to do that.
    Ken@Japan
  5. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    On Gen 2, via ScanGauge, even when climbing steep hills at highway speeds, I recall it's rare that SoC (as indicated by SG) drops below 40%.
  6. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Shifting to neutral while going uphill is probably a losing strategy. Trying to outguess the firmware generally results in lower mileage.
  7. macman408
    macman408 Electron Guidance Counselor
    1,179
    365
    About the only thing you can do is, if you're going uphill at 45 mph or less, coast briefly to let the engine shut off, then use a light touch on the gas pedal, keeping the HSI below the halfway point, to use some electric power with the engine off. If you're at 25 mph or less, you can use EV mode - in general, keep it out of the PWR range and it'll stay in EV. At normal highway speeds, you can't do anything.
    In either case, don't try it before you are within spitting distance of the top - otherwise, the car will work extra-hard to recharge the battery while you continue to drive uphill. Any time the engine is running, it'll generally work its way towards a 60% SoC, since that provides a good balance between having power available for EV and having capacity available for regen.
    Of course, doing this won't buy you much more economy, and it might cause some extra wear on your battery. But there's really no way to get what you want.
    Now with the plug-in, you can effectively do exactly this - drive uphill in EV or HV modes, draining electricity as you go. Eventually it'll stabilize with about as much remaining energy as the liftback has at 60% SoC (so maybe 1/15th or so the total capacity), since that's where the computer wants to be for HV mode. And then you can regen the whole way down the mountain, getting more EV range back.
  8. FrankTiger
    FrankTiger Member
    63
    118
    Madrid, Spain
    Hi macman408 [​IMG]
    This is just to confirm what you say.
    I made a graph with more than 19,000 ELM327 readings of of Hybrid Batt Amps Vs Batt SoC while the ICE is injecting fuel. They are taken on my actual driving, 50% of them are urban and 50% are slow highway. That is reason that the most common points are about 52% SoC.
    The red line of the graph (average curve) tells that the target SoC is 60% as you said. At 60% SoC, the average charging current of the battery while the ICE is injecting fuel is zero.
    Big hugs from Frank
  9. motoleon
    motoleon Junior Member
    48
    16
    spain
    there is no posibility of soc spoofing in prius 2010. in prius 2G, there is a Battery ecu, that sends to hv ecu the soc, and you can spoof thas message via canbus. But in prius 3G, there is no battery ecu, there is a smart battery ecu that sends temps and volts of hv battery to hv ecu (via serial data link, no canbus), and is the hv ecu that calculates soc. So in prius 2G there are posibility of change target soc, but not on 3G prius...
  10. Buy a PIP, then you can do this.
  11. djs
    djs Junior Member
    NW WASHINGTON
    Sorry for the misunderstanding, I missed typed using regen instead of recharge.
    What I'm looking for is someway to use the traction batteries along with the ice to go up hill and not using fuel to recharge batteries on the way up. By doing this I would be able to use less fuel going up because I would be using battery power with ice, and not using fuel to recharge the batteries. Then on the way back down I could use regen to recharge batteries from low to full charge.
  12. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I'd have thought the best you could do would be to keep it just in the power zone. The car may want to provide some assist from the battery so it should, if anything, lower the SoC.
    Also, make sure you're not in power mode since that causes the car to raise the target SoC.
  13. Former Member 68813
    3,524
    981
    US
    Yes, you would save some on gas, but increase wear and tear on the battery by forcing deep cycling.
    Incidentally, I personally get the best MPG when I use batteries the least.
  14. If its a small ascent, just use EV, that = 100 mpg + On the down hill portion go back to HV and recharge battery. Save the battery for these type of situations.
  15. fuzzy1
    10,048
    This won't work for OP. The long mountainous ascents in that area are on roads with minimum legal highway speeds greater than the non-PIP's maximum EV speed. And the climbs exceed not only the EV battery capacity, but even the PIP's capacity as well.
  16. Sorry, I have PIP on the brain.
