Do you hear rattling noises?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CivicQc, Oct 25, 2009.
  1. Yes, and they bother me
    225 vote(s)
    72.3%
  2. Yes, but they don't bother me
    26 vote(s)
    8.4%
  3. No
    60 vote(s)
    19.3%
  1. nymjk
    nymjk
    Expand Collapse
    Junior Member
    37
    Melville, New York
    It does. Thanks for the tip. Gonna' try it tomorrow.
  2. pmppk
    pmppk
    Expand Collapse
    New Member
    San Jose
    I hear a rattle from the sun roof… but only when it is open to a particular position. The one it stops at while being closed from the fully open position.
    Bothers me enough that I won't use that position, but that's not a big inconvenience.
  3. pixelmixer
    pixelmixer
    Expand Collapse
    New Member
    102
    Seal Beach CA
    Oh yeah. Plenty. 1400 miles on my 2010 V, and I must say that the squeaks & rattles in this car are more prolific than any car I have owned. Actually, more than many other Toyotas I have experience with.
    Disappointing.
    Until time has passed and the dealers and factory have have had lots of practice on other people's cars, I'm afraid we'll have to live with them.
    I'm smelling a 1990's GM "snap together" assembly technique.
  4. rrolff
    rrolff
    Expand Collapse
    Prius Surgeon
    1,609
    232
    So Cal
    I hear dead people.
  5. pixelmixer
    pixelmixer
    Expand Collapse
    New Member
    102
    Seal Beach CA
    Gen 3 "Bridge" rattle fix.
    While driving down a rough section of freeway recently, I stuck my parking pass in the gap where the "bridge" and center console meet. (Just forward of where you open the center console lid.) It eliminated 85% of the rattles I hear daily. I took it out, and the rattles returned. I tried this over about 10 miles of rough freeway. The parking pass is about the size of a credit card, but about twice as thick. Now I'm on a search for some dark-grey or black material that is not cheesy-looking; preferably a high-density foam, rubber sheet or plastic shim that can be carefully trimmed and inserted into this gap. The "bridge" on these cars apparently spent too little time in the flex/rattle/noise testing department. If you firmly place a finger in the previously mentioned gap, you can feel it change as you drive over rough surfaces. I have also determined that something is rattling around inside the bulge below the drive select lever/shifter. Tap on it from below and you'll hear what may be wiring or something loose inside there.
    By the Time Toyota gets around to a solution to these vexing rattles, Prius Chat folks will have figured most of them out.
  6. telmo744
    telmo744
    Expand Collapse
    HSD fanatic
    1,574
    288
    Portugal
    Besides the mainly referred dash rattles, I also hear squeeks coming from the 5th door, maybe the plastic panel...
    It would be nice to keep this thread fixed (sticky), since it now contains many DIY simple repair descriptions.
  7. hsiaolc
    hsiaolc
    Expand Collapse
    New Member
    617
    44
    UK
    They won't make it sticky. Bad reputation or image for Toyota.
  8. telmo744
    telmo744
    Expand Collapse
    HSD fanatic
    1,574
    288
    Portugal
    They? Oops
    Didn't know it was administrated so close to Toyota MC. Prius-pt forum is independent...
  9. seasalsa
    seasalsa
    Expand Collapse
    Active Member
    1,278
    Kent, WA
    I guess Toyota must have heard all of you with a rattle problem. My car was made in April 2010 and I have no rattles yet.
    I learned to live with the dash rattles in the 04, they seemed to come and go. They went for good when I traded it for the GenIII.
  10. jungsuk
    jungsuk
    Expand Collapse
    Prius with Leather
    17
    Ottawa, ON
    I think the hot weather here in Ontario makes the rattles worse. Same here -- I hear it at the passenger side -- I think it's somewhere near the glovebox.
  11. tumbleweed
    tumbleweed
    Expand Collapse
    Senior Member
    4,067
    650
    Eastern Oregon
    It may depend on what's rattling? It's hot here also and mine are mostly gone, I expect them back next fall though. Temperature above 60 or 70 degrees F. and they are mostly gone, colder than that and they start to come back. Colder it gets the more it rattles.
    My most annoying rattle is on the passenger side somewhere near the glovebox also. I still have it in hot weather too, if you find it be sure to let us know what it was.
  12. jungsuk
    jungsuk
    Expand Collapse
    Prius with Leather
    17
    Ottawa, ON
    Can you let us know how to remove the lower glove box??
  13. tumbleweed
    tumbleweed
    Expand Collapse
    Senior Member
    4,067
    650
    Eastern Oregon
  14. jungsuk
    jungsuk
    Expand Collapse
    Prius with Leather
    17
    Ottawa, ON
    Wow, now I'm terrified to even attempt to remove the lower glove box....
  15. tumbleweed
    tumbleweed
    Expand Collapse
    Senior Member
    4,067
    650
    Eastern Oregon
    Have no fear, just be careful putting it back in. You have to use a little bit of force but no to much. I've had mine in and out about a dozen times and it's still in one piece.
  16. jungsuk
    jungsuk
    Expand Collapse
    Prius with Leather
    17
    Ottawa, ON
    *sigh* now I am hearing rattling on the driver's side window...
  17. Aelrise
    Aelrise
    Expand Collapse
    New Member
    Anaheim Hills, CA
    I just bought my, 2010 silver prius, and it's full of body panel’s noises, interior rattling noises, it's crazy. I called today about how the outside panels make sounds as I wax the car and they said no one else has complained about it, right Toyota. In the armrest I put felt tabs between the sliding top and it stopped the noise in the armrest console.
  18. Kermit262
    Kermit262
    Expand Collapse
    Member
    112
    44
    Central Ohio
    Have had my Priis III for 5 days and have heard a rattle on the passenger side dash.
  19. GatorGal21
    GatorGal21
    Expand Collapse
    New Member
    florida
    Have owned an 08 Prius for only 2 months. Rattle in center of dashboard started last month and gets louder every day. I live where it's very hot out. It appears to be coming from the CENTER, behind the radio/ac screen but impossible to determine without ripping out the entire dash which I DON'T want to do. Does not appear to be off to side by airbag or glovebox; rather, dead center.
    Any fix for this?
  20. xs650
    xs650
    Expand Collapse
    Senior Member
    4,524
    1,388
    Northern California
    1,800 miles on mine and no rattles yet.
