Does Gas Engine ever directly drive wheels
Discussion in 'Gen 3 Prius Technical Discussion' started by EdIris, Jul 10, 2011.
  1. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    If its running it is charging your battery.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Play with the flash simulator and it will answer many questions. You will see with the sliders when each thing happens and the rpm of each along with total speed. Quite ingenious.
  3. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    When you are stopped and the engine is running it's for one of three reasons:
    1. The battery is too low and it's being charged.
    2. It's cold, and either the cat or the car interior needs to be warmed up.
    3. It will -eventually- stop, it's just waiting for a fixed time period to "see" if you need it. I still want my "anticipation switch" to stop it!
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The Prius does not have a clutch, assuming you don't count the torque damper which includes an emergency clutch to prevent damage under extreme loads. Therefore, yes, without an operable clutch.
    Tom
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That's what I said.
  6. qbee42
    18,058
    3,076
    Northern Michigan
    Ah, gotcha. Yes, that would be exciting to drive.
    Tom
  7. econo-one
    econo-one Junior Member
    Lake Tahoe, Nevada
    David, your explanation is one of the best on this thread. Clear and easy to understand. So perhaps you can tell me what the engine rpm is when driving at a highway speed, say 60 mph, when all motive power is coming from the ICE.
  8. ChapmanF
    17,186
    In case David doesn't see this right away: in a transmission with fixed gear ratios, you can answer a question like "how many revs does the engine turn at 60 mph in x gear?"
    With a continuously-variable transmission (any CVT, not just the weird hybrid kind in a Prius), your question has much less of a definite answer. The car can be moving 60 mph, and the engine can be turning any rpm where it produces enough power to maintain the car's speed under the current conditions. The CVT does the magic to match the two speeds.
    The Prius power management computer knows the engine's torque and power curves. When it calculates how much power is needed to move the car in the current driving conditions, it will try to send the engine right to the rpm range most efficient for producing that amount of power, and adjust the transaxle ratio to match that to the car speed.
    If you watch your rpms on a ScanGauge, the Torque app, or the like, at 60 mph you might be seeing anywhere from under 2000 (downgrade, tailwind, etc.) to 4000 or higher (steep upgrade, stiff headwind, etc.) or anywhere in between.
    -Chap
    CR94 likes this.
  9. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Well, you still can not say that all motive power will come from the ICE. There are two electric motors: MG1 and MG2. MG2 speed is proportional with engine speed, MG1 is totally independent. So we can answere the question "what will engine rpm be when MG1 is not spinning", but then still MG2 can deliver power to propel the car. But ok, this is the closest you'll get and you could short MG2 to make sure it does not deliver power and for ICE rpm this does not matter because when MG1 speed is constant, ICE rpm is proportional to your speed.
    Under that condition, ICE rpm is about 5/18 * 143/145 * 120 * speed in mph
  10. ChapmanF
    17,186
    There seem to be some misconceptions in post #29. MG2 speed is proportional to wheel speed, not to engine speed. MG1 is not totally independent, it's related to both engine speed and MG2/wheel speed by a fixed nomograph that's been posted and discussed widely on PriusChat. Shorting MG2 would not "make sure it does not deliver power", it would strongly resist the car's motion and create serious heating in MG2 (indeed, when that happens on its own through deterioration of the winding insulation, it's one of the known transaxle failure modes).
    There are a lot of threads already on PriusChat that accurately describe how the hybrid system works....
    -Chap
    Raytheeagle likes this.
  11. David Beale
    5,963
    1,987
    Edmonton Alberta
    The question asked by eco-one was mostly answered by chapman.
    The MGs can spin without actually -pulling- the car. They can actually absorb momentum energy (regenerate mode) or just spin, using minimal power, in "coast mode". And yes, they can help power the car or even contribute all the power to move the car. And in reverse, MG2 is the -only- source of motive power for the car (there is no "reverse" gear so the engine can't drive the car in reverse), though I suppose it's possible MG1 could contribute some power as well, but I don't think that is done in the HSD.
    If you try to reverse up a very steep hill you can see this lower power (about 40 HP) in reverse. Once I had to reverse up a very steep hill, and Pearl struggled mightily, but did move, with full throttle. You get quite a surprise when this happens. ;)
  12. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Here is another perspective: If you do not provide electrical power to M/G2 and M/G1, the engine has nothing to push against and can run all day and you won't go anywhere. This is N on the stick shift.
    Once you do provide resistance for the engine to push against by using at least one motor as a Generator (usually the other is a Motor) then 71 % of the torque goes to M/G2 and usually drives the wheels via gearing and 29% goes to M/G1 and make electricity, perhaps also driving M/G2 indirectly.
    There is a mode where M/G2 is acting as a generator, cutting into the power supplied by the engine, while M/G1 is acting as a motor, using electricity from M/G2 to slow the engine. This seems very odd, but doing so acts like an overdrive, allowing full throttle at low RPMs. If you are doing 1600 RPM at 60 MPH, this is the mode.
    No gears shift, no clutches grab, no physical change in the transaxle, just software controlling the M/Gs.
  13. econo-one
    Lake Tahoe, Nevada
    Thank you, Chap. Good explanation. I had read that the CVT transmission was like a single speed transmission, but I recently saw a chart that shows how MG2 often revolves to change the effective ratio of the ICE to the wheels.
    MikeDee likes this.
  14. econo-one
    Lake Tahoe, Nevada
    I should have written MG1, not MG2.
  15. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Or, using very elementary algebra and the relevant gear ratios in the transmission, you can easily calculate MG2 (or car) speed, MG1 speed, or engine speed, if the other two of those three variables are known. I made a spreadsheet which does that.
