Does the Pulse & Glide technique work....
Discussion in 'Gen 3 Prius Fuel Economy' started by Michaelvickdog123, Sep 24, 2010.
  1. Former Member 68813
    3,524
    983
    US
    This exactly the point I tried to make in my post above. Prius makes it difficult to go into the "neutral" glide without using N as one has to keep pressing gas slightly while watching the display. Distracts me from watching traffic ahead. I would prefer if lifting of gas pedal would not produce coasting with regenerative braking.
  2. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Me too, friendly. But with practice you can find the glide by feel and confirm with a glance as you scan the instrument panel normally.
  3. jstraw20
    jstraw20 Member
    122
    Long Island NY
    ^^^ This. After a while you can glide by feel with only an occasional glance at the display to confirm that you're not using the battery.
  4. Tideland Prius
    16,548
    I agree :D
    Gliding would refer to the state where no arrows are showing at all. This is kinda like shifting to Neutral. It's really hard on the Gen 3 so don't feel too bad if you can't achieve it. Chances are, you are doing it right (esp. if you do it on a Gen 2 Prius, you'll see the glide state).
    When no arrows are showing. I asked Ken@Japan.... he said a little EV draw won't hurt it (i.e. you press the pedal just so that the arrows switch from regen to EV mode. He said that's close enough because you're drawing very little).
  5. Canard
    Canard Member
    223
    Ontario, Canada
    Am I doing it right?
    -Iain
  6. Tideland Prius
    16,548
    Well I don't know if there's traffic behind you but your glide could be extended. Around town where the speed limit is 50km/h, I usually P&G between 60km/h-40km/h then pulse to 60km/h again.I keep a 20km/h difference. It's easier around town b/c of the traffic lights and other cars that need to turn right and such that mask the glide part. Given that you were on a "country road", it might be harder to mask the glide.
    Also, feel free to pulse a little harder. You were about 1/2 up the ECO area. You can probably go up to 3/4 of that bar (just before the base starts curving up towards the PWR area). The glide part is ok WRT to the amount of green bar showing on the Hybrid ECO area.
    If that road has a 60km/h limit, you could try 65-45 or 70-50 but with 70-50, you'll lose a lot more speed from due to aerodynamics than from the friction of the tyres. The Gen 3 will allow glide up to 70km/h (the Gen 2 allowed speeds up to 65km/h).
  7. Canard
    Canard Member
    223
    Ontario, Canada
    Awesome! Thanks for the feedback :) It was a 60 km/h zone with no traffic behind me. I was doing between 35 and 40 mi/h because off the top of my head I seemed to recall that range being suggested somewhere. I imagine that the greater the breadth of that range, the greater the gain is lower consumption.
    My commute is 20 km and I've endured a batch of 5 l/100 km tanks with the cold. So I am motivated. :)
    -Iain
  8. Tideland Prius
    16,548
    then 65-45 is definitely in the realm of possible speed ranges (esp. if you're not in a hurry). It does take patience on the lower part cause you'll be decelerating at a slower rate once you're below 50km/h so that's where you can get the most out of gliding.
    Well your average isn't too far off from mine! I can't wait for summer to bring it back down again. We haven't had any -40s yet this year so my worst tank is 5.0L/100km showing on the MFD (so it's probably more like 5.3 or 5.4L/100km calc'd by hand). Last year's -40 dipped it to 6.4L/100km. Ugh.
    20km is also a lot longer than mine. Mine's only 9.8km. Not enough time to warm up in the winter.
  9. HanSolo
    HanSolo Junior Member
    23
    Bettendorf, IA
    After watching the video I may be gliding incorrectly. I usually glide with the the indicator invisible that is no chargeing and no electric propulsion. That is the indicator is gone. Should I have some electric propulsion during the glide?
  10. CTitanic
    CTitanic Member
    153
    22
    South Florida, FL, US
    It works for me.
  11. Tideland Prius
    16,548
    Not necessarily. If you can glide such that the Hybrid System Indicator is empty, that's fine. It's more difficult to glide in the 3rd Gen Prius so we allow a little leeway and say even if a little bit of the Hybrid ECO area is filled, that's ok since there's very little amps going to the wheels anyway.
  12. HanSolo
    23
    Bettendorf, IA
    Awesome. Thanks for the advice.
    I set the trip A when I start up each morning. I drive short trip moving kids around and myself. Trips are never longer than 11 miles. So that is tough. I'm really getting a solid understanding of how temperature affects indicated mpgs. If it is single digits 50 is not really a possibility. 10-20 degrees F I can get 50. 20 - 30 50 is doable. 30 and above it gets much easier. I had the block heater installed and it has helped. I can get the ICE to turn off in about .75 miles. I need to work on my P&G technique to maintain 35-40 mph. I always end up slower. Will P&G allow me 50 mpg in 15-20 degree F at average 35 mph? Now my average mph's are 22-25.
    Thanks again for the comments.
  13. Tideland Prius
    16,548
    Oooh 11 miles is short (Heck, mine are even shorter than yours.. about 6 miles). Have you blocked the grille? It works well below freezing. Above freezing, you'll want to start pulling out the foam pipes (about 50% blocked up to 50°F and maybe just remove it all together above that temp).
    ECO mode helps as it reduces heater output and allows the engine to shut off earlier. Shutting off the climate control (if possible) at red lights can help once the engine is somewhat warm (Esp. if it's just been plugged in with the EBH).
  14. cbcdesign
    cbcdesign Junior Member
    30
    UK
    How does this pulse and glide work though? As I see it, it takes a certain amount of energy to propel the vehicle at a particular speed. If that energy is coming from the battery with the ICE off, when the battery is flat, the ICE kicks in and has to deliver the same amount of energy as the battery did to keep the vehicle moving AND recharge the battery at the same time, ie use a bit more energy on top. Since nothing is 100% efficient there will be losses when charging the cells too so the net result is surely more energy used than driving normaly as Toyota recommend.
    I cannot help wondering if just feathering the accelerator wouldn't be just as efficient if not ever so slightly more so that pulse and glide techniques.
    And what about the extra wear and tear with the extra starting and stopping of the ICE? What will that cost?
    Anybody care to tell me what I am missing?
  15. BrettS
    BrettS Active Member
    290
    136
    Orlando
    First, when you do the pulse and glide thing you're not actually propelling the car at a constant speed... You use the ICE to get up to speed, then you coast for a little while with the ICE off and your speed drops while you coast. Then you turn the ICE on again and speed up, then coast again with the ICE off... And repeat... You shouldn't be draining and recharging the battery if you're doing this right.
    The reason P&G works is that all engines are more efficient at certain RPM levels. Feathering the pedal and maintaining a set speed won't allow the engine to operate in it's most efficient range. Instead, you try to run the engine in the efficient range during the pulse and shut it off for the glide. When done right this works and will definitely save gas.
    The prius, with it's electric motor makes things a bit more confusing as you do lose energy during the conversions. However, it can still be more efficient overall to run in electric mode at slower speeds where the ICE would be less efficient and allow it to recharge later when it's running in it's efficient range. You also get some energy from the regenerative breaking that otherwise would have been lost.
  16. cbcdesign
    30
    UK
    Ok, I will give it a go when My Prius arrives.
  17. ksstathead
    1,244
    245
    Kansas
    cbc, welcome! You'll love your Prius.
    When your speed/terrain makes efficient use of the ICE output, then steady state is fine. But otherwise, as stated by Brett, P&G **avoids** the conversion losses you accurately point out. Glide is not EV power, but inertia power. Feels as if you put it in neutral (no drag).
    Remember that gliding requires slight throttle input to cancel the regen toyota put in at 0 throttle. Foot off the gas (0 throttle) is best referred to as coasting (useful if you need to shed speed for stoplight timing), and is not part of P&G.
  18. M Kamran Asif
    M Kamran Asif Junior Member
    while gliding, a small amount of battery still gets consumed i.e. a/c, audio equipment and headlights usage.. i.e. after 2 cycles of gliding, one bar of battery gets dropped and consequently on 7-8 cycles of pulse and glide, battery gets to 3 bars and then i intentionally try not to p&g but to keep running ICE with very little pressure on the pedal to consume less gas.. and one the batter gets back to almost full state, i pulse and glide again .. the loop continues.. and i hope its not bad for the battery :S
  19. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    IMO, everything is normal. If you will try to limit your usage of the electricity in the traction battery by turning off some of the accessories, you might find that the traction battery will hold the SOC a while longer.
    The Gen II was worse about what you describe than the Gen III Prius. However I have found I can P&G all day long if I keep the A/C off and very rarely have to use the ICE to recharge the traction battery. But if I turn the A/C on, all bets are off at that point.
    Have a great day. Interesting string too!
    Ron (dorunron)
    Regular Customer likes this.
  20. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    To the OP.
    Do not make yourself crazy driving this car. DO NOT practice P&G, when you first get it, in traffic. I found out how good the ABS brakes work by trying this a few times. I easily get low 50's in the city and mid 50's on the highway when I use cruise control. With P&G you will, realistically, pick up a few mpg's while driving with the alertness of everyone around you like your were intoxicated or texting while driving.
    You will find this all out when you get your first insurance premium statement. My wife, my 22 yr old son and I haven't had an accident or citations in years but my auto insurance went up almost $100.00 per month when I told my agent what I bought (I'm pretty AAA had something to do with that in a scathing report on hypermile driving techniques).
    Drive it like a car and not a helicopter with unlimited airspace. There are others on the road as well.
