Does the shark fin antenna work better??
Discussion in 'Gen 2 Prius Technical Discussion' started by WWJD08, Mar 23, 2009.
  1. WWJD08
    WWJD08 New Member
    70
    Frederick, Colorado
    :cool:Other than the look of the shark fin, does it get great reception or bad reception.:eek:.
  2. priusunlimited
    priusunlimited New Member
    I'd say I get equal reception in my Prius as I do in anything else... Dont know if this helped........... it doesnt suxk tho.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    In fringe areas the reception is worse with the shark fin.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    I'd say about the same. That's my experience anyway.
  5. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    I'd say slightly worse.
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    It all depends where you are in relation to the transmitting antenna and how much Effective Radiated Power they are putting. If you a city driver, listening to a station in the city, the shark fin should work fine. However, if you drive say 50, 75 miles outside of the city, you may get marginal results. There are at least 3 variables in play here.
    The basic rule of thumb, the more signal you want to get into the radio, the more metal you have to stick up. I.E. the Antenna!
    Ya Gets Whats yaz paysfor!!
  7. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I can honestly say that my Prius with the 'fin gets better AM reception than both of our Subarus with stock whip antennae. I can see no diff in FM, good or bad. All things considered, in the LA area where I live it works as good or better than the stock whip. There is a mountain pass where I live where I lose the signal on FM, but both the other cars do too. I bought it to have an easier time using a car cover, and because it looks cool, too. For me its all good, your reception may vary. To test it, temporarily install it with masking or duct tape, and take a drive. If you don't like it, return or Ebay it :).
  8. Doc Willie
    1,717
    144
    Out there, somewhere
    Definitely worse. If you are in an area with good reception it won't matter.
  9. patsparks
    10,664
    567
    I do a lot of open road driving and in Australia radio cover isn't complete but I find my shark fin as good as the stock antenna on the work Holden, a car designed from the ground up for Australia.
  10. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    Worse than the original.
    PA P
