Door LED's
Discussion in 'Gen 2 Prius Accessories & Modifications' started by PhilWray, Apr 5, 2012.
  1. PhilWray
    PhilWray Member
    82
    28
    Malaysia
    Hi All,
    The LED's for the doors have arrived and been fitted. Took less than 10 minutes for both! Just the rear interior light to be done this weekend.
    Regards,
    Phil
      File size:
      23.4 KB
      1,676
      File size:
      51.9 KB
      1,596
      File size:
      33.3 KB
      1,581
      File size:
      26.8 KB
      1,567
    Daves09prius and dianeinreno like this.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Bright is nice isn't it! I replaced all the white interior lamps with 36 LED square plates. At night it's like the sun came out when they are all on! It looks great.
    Nice job on yours BTW, +1!
  3. PhilWray
    PhilWray Member
    82
    28
    Malaysia
    Yes the LED's are a great improvement over the stock bulbs :)
  4. RyC
    RyC Junior Member
    25
    San Luis Obispo
    Nice job, where did you get these?
  5. PhilWray
    PhilWray Member
    82
    28
    Malaysia
  6. RyC
    RyC Junior Member
    25
    San Luis Obispo
    Thanks for the link, do these led squares work with the dome lights as well?
  7. PhilWray
    PhilWray Member
    82
    28
    Malaysia
  8. dianeinreno
    dianeinreno Member
    104
    17
    Denver,CO
    I just did the same thing but instead of attaching the front LED face directly to the plastic I used a bead of silicone seal to glue (easily removed) the back side of the LED assembly to the metal rails .
    This keeps the face of the LEDs away from any contact with plastic parts. The LED array can get quite hot if left on for extended periods (leaving door open or something like that) and I was concerned about the clear plastic melting or making a fire hazard.
    I did something similar with my rear hatch and installed a 20 LED array into my front dome light and a 12 LED Festoon into my rear dome light.
    Everything works perfectly and the only drawback is that I have to wear shades when I enter my Prius at night. :D
    FOLLOWUP: On reflection the 20 LED array on the front dome light is maybe too bright at night. I might switch it out for a 12 or 16 LED array.
  9. macmaster05
    macmaster05 Senor Member
    4,050
    730
    You don't even have to unplug the whole module like he showed above. Just pop the clear plastic clip. Take the old bulb out of the socket and put in the new one.
  10. PhilWray
    PhilWray Member
    82
    28
    Malaysia
    Mmmm I hadn't thought of that. Anyone know how much of a risk that is? Should I be moving the LED's off the cover? I incorrectly assumed that the LED's would be cooler than the existing bulb.
    Phil
  11. softrider316
    softrider316 Junior Member
    Montclair, NJ
    Our 36 LED panel practically rest on the plastic cover. We just have it taped in with some double stick tape. It does get a little warm, but doesn't appear to be hot enough to warp the cover. Also noticed that the interior lights will go off after a period of time if door is open but the key is removed.
  12. fuzzy1
    10,690
    I obtained some LEDs from a vendor at an electronics flea market, Wiredco, and am happy so far in my 2012 (also fit the 2010 just before trade-in). These are similar to the brightness of the original lamps, not the extra bright stadium lighting that some folks desire. I want to save the 12V battery in case of user error, not get brighter light.
    I have not compared these to similar products from Ebay, Superbrightleds, or many other sources.
    For the door and vanity mirror lights in my 2010/12, this side plug model works: T10 Side Plug Wedge Base 6 LED Light 12V 5050 SMD White. Fit into the vanity light without any modification. Fit into the door light by removing the inner transparent bracket, which appears to be the same in my GenIII as in the OP's GenII photos. Non-polarized, draw 55-60 mA at 12.2V, compared to 320-370mA for the factory wedge bulbs.
    For the map lights, this works: T10 194 Wedge Base 8 Miniature LED Light 12V SMD Cool White. No modification. Polarized, 21-22 mA slightly less bright that the factory wedge bulbs (same type as came in the doors). The sample from the flea market table is bluer than the later mail order units.
    A 31mm Festoon bulb, most likely this (Festoon 31mm High Power LED SMT Bulb White Dome) is a poor fit to the dome lamp over the rear seat, as it is slightly too long to fit the contacts properly. I did force it in, and it otherwise works well. The side wings do fit the housing. Polarized, this draws 66 mA, compared to 530mA of the factory 8W bulb.
    The trunk lamp also uses a Festoon bulb, which appears to be shorter at 26mm long. A different festoon LED tacked on to a different order from SuperBrightLEDs is now functioning in that location, though with the same poor fit issue as the light above.
  13. Johnny C
    Johnny C Member
    162
    16
    Boston
  14. PhilWray
    PhilWray Member
    82
    28
    Malaysia
    Not sure sorry. The vanity lights are used so infrequently I didn't think it was worth changing them.
  15. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    HID High & low beam headlamp HID-D4R
    NON HID High & low beam headlamp 9003/HB2
    Parking Light Bulb Size: 2825
    Front Turn Signal Light Bulb Size: 992 (7440A)
    Rear Turn Signal Light Bulb Size: 992 (7440A)
    Tail Light Bulb Size: 2825
    Stop Light Bulb Size: 7440
    High Mount Stop Light Bulb Size: LED
    Fog/Driving Light Bulb Size: 9006
    License Plate Light Bulb Size: 168
    Back Up Light Bulb Size: 7440
    Front Side Marker Light Bulb Size: 2825
    Map Light Bulb Size: 168
    Dome Light Bulb Size: DE3175
    Step/Courtesy Light Bulb Size: 168
    Trunk/Cargo Area Light Bulb Size: DE3022
  16. Johnny C
    Johnny C Member
    162
    16
    Boston
    Many thanks
