Dreaded dead battery
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kurbmaster, Jul 27, 2015.
  1. kurbmaster
    kurbmaster Junior Member
    46
    24
    Went to start the 2012 plugin I had and got nothing no dash lights etc. Then put it on a trickle charger and got some indication that it was taking a charge. Dome light would light but definitely weak. Tried pushing power button after three to four hours and a little flickering of the orange triangle then nothing.
    Can I assume my 12 v battery went dead. What would be the cause didn't see any lights on or think I left it running. Is it going to come back in the morning being charged. Purchased in dec 2012.
    48,996
    it should get charged while plugged in, do you plug in?
  3. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
  4. kurbmaster
    46
    24
    Thanks for that information. I plug in all the time. Don't know how it went dead. Any ideas.
  5. bisco
    48,996
    sure, dome light, door/hatch not closed tight, fob too close to car when parked, any aftermarket electronics?
  6. kurbmaster
    46
    24
    Went out gave me some dash indications for 4 seconds then went to a check engine light will leave it charging all night. Nothing is on back latch closed
    Jump started it and took it to dealer. He says it is still under warranty. I'll let you know what they find
    Took into dealer battery needed replacement covered under warranty
  7. bisco
    48,996
    sweet! can you tell us more about the battery warranty? i thought it was pro rated.
  8. kurbmaster
    46
    24
    Cost me nothing I think receipt for warranty work was 159.Now I have to reset date and time and for info I had my kW use on since beginning and fuel saved on that one display. Lost all that any way to get that back or is it gone forever ? Had about a 36% ev for live of car from what I remember. Trip from ny brought it down a bunch this year used to be about 45 ev before trip.
    Love the car. I averaged 47 mpg trip to Florida with cruise set at 75 for most of trip. 77 mpg avg on all miles have 27000 miles on it so far.
  9. bisco
    48,996
    gone. it's still in the 'black box', but that requires toyota's supercomputer.Merged back to back posts, again, bisco.what state are you in? and can you tell us the name of the dealer, that was a very nice service they gave you. not only that, but if $159. is what they charge for a new battery, it's way below any price i've heard before.
  10. kurbmaster
    46
    24
    North way Toyota in Latham ny. It could have been 259. I'm starting to lose it. I'll have to get data from them when I take it in for 30000 service.
  11. drash
    drash Senior Member
    2,457
    1,235
    Upstate NY
    Heat. Best killer of any battery. AGM batteries are prone to positive material expansion that leads to shedding when contracting and the separator has not been compressed enough against the positive material. The hotter it is the more expansion takes place. They also suffer from dendritic growths.
  12. bisco
    48,996
    yikes, glad mine is garaged most of the time when i'm not using it.
  13. kurbmaster
    46
    24
    Mine was in garage when it died plus every time out in sum I have entire car windows with sun shade over them
  14. hill
    8,071
    Our garage is like a microwave in the summer. Sun beating down on it ... then you throw a warm car in there? That's why I park under our pigmy palms most of the time.
  15. bisco
    48,996
    ours is probably 10-15 degrees cooler than outside. there's a room above, and i think a little a/c leaks through the two connected walls. at least the sun isn't beating on the car.
  16. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    I have a question about this battery too. I purchased the Solar BA5 tester to test our 12V accessory battery. What type of battery do we have? is it a conventional SLI flooded battery or a Traditionally shaped AGM battery? I have a 2012 plug in. When testing with the BA5 tester it read 466 CCA (The battery itself says it only has 325 cca) So I am thinking it is a AGM battery.
    Also Interstate batteries said they would not sell me this battery and I had to go through the dealer to purchase the optima brand.
