Driver side HID keep on going off
Discussion in 'Gen 3 Prius Accessories and Modifications' started by prizzy, Sep 2, 2014.
  1. prizzy
    prizzy New Member
    17
    dallas, tx
    I just installed DDM tuning HID 35watt without relay harness, my driver side keep on turning off when I turn it on even when the car is running. Anyone faces this issue?
  2. xliderider
    xliderider Senior Member
    7,901
    3,130
    Honolulu, HI
    Swap the bulbs from one side to the other. If the driver's side exhibits the same problem after the bulbs are swapped, suspect a problem with the ballast. If the passenger side starts going out after the swap, replace the bulb.
    SCH-I535
  3. xliderider
    7,901
    3,130
    Honolulu, HI
    Make sure all the connections, and ground connections are tight/solid as well before doing the bulb swap.
    SCH-I535
  4. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    This is why I installed 55 watt. The canbus is expecting a 55 W light and thinks there is nothing there so it switches the power off. You have to install a relay or there are devices available to plug in line and it fools the canbus into thinking there is a 55 W draw.
  5. IAintNoThug
    IAintNoThug Junior Member
    San Gabriel, CA
    Hi prizzy, is this still an issue? Let us know what steps you took.
    Thanks!
  6. prizzy
    prizzy New Member
    17
    dallas, tx
    I don't have the issue anymore. One day it just started to work by itself, but there are time that i have to turn on and off a few time to get it work. I will get a new set of HID once I get Katzkin leather install on my car.
  7. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    The can bus corrects for any error message you may receive. The 35 watt is just fine.
