Eco <=> Normal Mode - Can you switch too much?
Discussion in 'Gen 3 Prius Main Forum' started by BluetoothEdsel, May 8, 2014.
  1. BluetoothEdsel
    164
    25
    San Diego
    Prius owner of a couple months here. Most of my drives end up as stop-go traffic at either end, with freeway driving in the middle. I find that I like driving in Eco mode for the stop/go, then switch into normal mode for the freeway stretch - and back to Eco at the other end for stop/go again.
    So on a normal workday with round trip commute, I'd switch a total of four times.
    Aside from the Eco button, there's no wear item that I have to worry about, is there? I.e, is it correct that the car doesn't care how many times you switch it because it's just control over throttle behavior, as your foot is? Or is there any reason I should limit switching?
  2. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    After about the first month, I ignored those buttons. My foot learned to moderate the throttle in normal mode and I certainly didn't want reduced A/C output from ECO mode.
  3. GregP507
    GregP507 Senior Member
    3,002
    480
    Depends on my mood. When I want to squeeze the maximum economy out of my fuel, I trust the Eco mode to do a good job, even if it makes drivers behind me swear.
    If I have any stored plug-in charge, the car always defaults to EV mode on startup. Sometimes I switch it off to save the EV for later.
    Sometimes I love to feel the instant power response that only an electric drive can deliver, so I use Power mode.
    Most of the time I use no mode at all.
  4. vskid3
    vskid3 Active Member
    773
    228
    You're correct, nothing to wear but the button.
  5. jfschultz
    jfschultz Active Member
    635
    114
    Germantown, TN
    2013 Prius Plug-in
    Why? Just leave it in ECO and drive, other than the AC, the only difference is how much you press on the accelerator to speed up. Someone posted in an earlier thread that every mode ends up at the same power level when you floor it.
  6. GregP507
    3,002
    480
    This is true, but I generally don't floor my vehicles, it makes them last longer.
  7. BZzap!
    BZzap! Senior Member
    1,607
    877
    I find that about the only MPG benefit from using the ECO mode is when you are using the A/C. It simply defaults the A/C to the recirculate setting to minimize the electric compressor's run time thus managing the traction battery better. Other than that it just reduces throttle input. As stated ^, if you manage the throttle in any other modes you'll do just as well with the MPG's.
  8. phoenixgreg
    phoenixgreg Senior member
    1,157
    288
    66
    Phoenix
    +1 with car compulsive. Those buttons are to impress your friends or new buyers. I use EV to jockey my car in the driveway, but keep in mind EV only works if your ICE is already warmed up. ECO mode is a PIA if you need good AC and I rarely use PWR mode - only for a really short freeway on-ramp.
  9. kbeck
    kbeck Active Member
    420
    274
    Metuchen, NJ
    I do not know. I don't think I go crazy with changing modes, but:
    1. If you're in ECO, the car wanders up and down a bit more when the cruise control is on than when the car's in Norm. That, and the climate control works differently... More efficiently? It's also easier to feather the engine in slow-motion stop and go driving.
    2. Normal mode seems to handle freeway driving a bit better; I do that when I've got 100 miles to go and no slow-downs.
    3. Every day, going into work, I go up one steep hill or other for a half mile or so. It's not wide-open-throttle, but, in ECO, the pedal would be most of the way down and modulating speed means flipping it back and forth quite a bit. In Power, on a steep hill, the pedal's easier to modulate. The car's has no problems going up the hill in any case, it's just the connection between my brain, how fast I want to go, and which way my foot goes.
    One can switch back and forth between modes at will with nary a hiccup from the car. The only problem is that there's no tactile feel between one button and another, so, if one is switching modes, there's a strong temptation to look down, and I like to keep my eyes outside.
    So, switch or don't switch, it's up to you. There are people here who stay in Eco all the time, people who stay in Power all the time, and probably people who switch every 5 seconds. Do what you and your brain are comfortable with, and drive safe.
    KBeck
  10. GregP507
    3,002
    480
    I find the Eco mode makes it easier to drive in such a way that normally takes a bit of skill. It's easier off the mark, and utilizes the ICE in it's more fuel-efficient range of lower RPMs.
    BluetoothEdsel likes this.
  11. BZzap!
    1,607
    877
    I'm with Kbeck. While driving in traffic, switching from one mode to another, there is a tendancy to take your eyes off the road to search for those (nicely, molded into the console) buttons. I just leave mine in ECO mode most all the time. If I'm going to merge onto the freeway I'll preset the power mode beforehand and place my finger on the ECO button withou having to Braille it or look down.
  12. Okinawa
    Okinawa Senior Member
    1,333
    317
    I leave mine in ECO mode all the time, unless I am going up a steep grade and only then I go to PWR mode.
  13. BluetoothEdsel
    164
    25
    San Diego
    Thanks all. Actually, one thing I like about Eco mode is it's a quick way to control the A/C. I park outside at home, and the sun tends to be hot, despite sunshades. So when I first start up, the A/C blower is really loud. I want to be able to hear car horns, or the ubiquitous skateboarders about to fly into me. Eco mode is easier than twiddling with the A/C settings, and at the same time just makes the car easier to drive in stop/go traffic than metering out tiny little pedal presses. On the other hand, when I get on a freeway, I don't want to have to worry about pushing the "pedal to the metal" to get up to speed on an uphill onramp amongst impatient traffic. So I *could* always drive the car in one mode or the other, but I *like* using both modes. As long as the car doesn't mind my switching modes, I may as well!
  14. Okinawa
    1,333
    317
    I do exactly the same as you.
  15. A617
    A617 Member
    213
    95
    OKC, OK
    I use Eco mode during the winter and normal during the summer it kinda balances out the average between the two seasons and Eco mode interfere with the ac performance and living in the south where heat and humidity is present almost all the time makes the ac almost useless
  16. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    Winter benefit is significant. ECO lowers the heater threshold, allowing the engine to stay off longer.
  17. GregP507
    3,002
    480
    Great. Just what I need when it's -35. Actually, the PIP warms up fast compared to other vehicles. I'm starting to see warm air on the windshield after 3-4 minutes, compared to 12-15 on my other vehicles.
  18. Okinawa
    1,333
    317
    Greg, I would like to ask you a stupid question because I don't know. I have a 2011 Prius Two. Of course it has 3 driving modes, EV, ECO AND PWR. I know all about those modes but when NORMAL mode is discussed on Prius Chat I do not know what NORMAL mode is, how to access it or how it works. Could you please explain it to me?
  19. kbeck
    kbeck Active Member
    420
    274
    Metuchen, NJ
    Ha. It's a toggle. When in Eco, hit the Eco button again; the Eco light on the dash will clear. Same happens if in PWR; hit PWR again, and the PWR light clears. When no lights are lit, that's Normal.
    KBeck
  20. Okinawa
    1,333
    317
    I knew you could do that. Okay, so when no lights are lit and you are in Normal, does the ICE run all the time or does it still switch from ICE to electric motor?
