Effect of Elevation on Outside Temperature in Abq, NM
Discussion in 'Environmental Discussion' started by SageBrush, Feb 19, 2014.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    The problem with Google SS is that they make it too easy to graph anything and everything ..
    So today I decided to test my impression that my home, about 1000 ft higher than the 'city,' runs some 3 degrees F cooler year-round. The very nifty website wunderground collates and tabulates personal weather stations around town in an open format, so it was easy to grab a snapshot of temperatures at noon and look at temperature Vs elevation for an area of perhaps 100 square miles around my home.
    Ignoring outliers, the slope is ~ 5F/1000 ft. Impressive! I'll grab other days throughout the year to see if the relationship varies in different seasons.
  2. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Where the weather stations are in the yard micro climate is going to have a big effect. As will diurnal airflow in the canyon's and valley. And lets not forget shading in the morning for those in the shadow of the Sandia Crest. Cloudy or clear are important factors too. Seems someone else also has to much free time. :cool:
  3. SageBrush
    11,627
    2,530
    Southwest Colorado
    Now where have I heard that before ?
  4. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    I see a weather station and a hot air balloon ride in your future or maybe some weather balloons tied to a lawn chair. Redbull space dive smace dive.
  5. SageBrush
    11,627
    2,530
    Southwest Colorado
    Did you see the Pixar movie 'UP' ?
    I've decided 'UP' and 'The Incredibles' are my favorites.
  6. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    Anything by Pixar is worth watching, but UP! was especially good.
    I had a conversation just the other day with someone who said they didn't understand why mountain tops weren't warmer than sea level, because they were closer to the sun. Being a kind and patient person, I did my best to explain it to her.
    SageBrush likes this.
  7. tochatihu
    tochatihu Senior Member
    8,995
    3,507
    Kunming Yunnan China
    2001 Prius
    Hyo, she was right about the stratosphere
  8. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    No I haven't seen those movies yet but I did watch this
    Stupid government shutdown cheated me out of some red or green last fall and Colorado chiles or so NYC.
    If she thought it got warmer the higher you went how does she explain mountain top snow?
    Tochatihu you ever been to Hopi? I lived out there in the early 90's.
  9. SageBrush
    11,627
    2,530
    Southwest Colorado
    Well, being as dumb as the next person I have to admit that I am not sure of the physics either ...
    A guess then:
    Your friend is right that the sun's radiation is stronger at higher elevations, but there must be competing processes.
    Namely, the ground for one;
    and denser air, for another.
    The ground absorbs the lion's share of the irradiation and heats up, then emits block body radiation.
    The denser air at lower altitudes acts as a heat sink.
    I'll also guess that the greenhouse effect is a gradient from high to low altitude.
    Addendum: I'll also guess that the denser air may be simply modeled as
    P*V = n*R*T
    One volume of air with more molecules has a higher temperature assuming that each molecule retains the same kinetic energy.
  10. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    JamesBurke likes this.
  11. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    I didn't use any physics or formulas. I said the sun was so far away that the little bumps on Earth's surface made no material difference to the relative warmth. Also, I explained that the Sun's rays warmed the ground first, and then the air. We chatted for a bit about how land and sea warmed and cooled at different rates, and how that drove our weather systems. It would hardly have qualified as a University lecture, but it was enough to impart some knowledge and curiosity.
  12. tochatihu
    8,995
    3,507
    2001 Prius
    Sage, take away your last line and the rest may stand. Gas temperature is a measure of the average kinetic energy of all the molecules. So if one increases, the other does as well.
