Emission Comparison: Prius / HS250h / Insight / Civic Hybrid / Jetta (Gas+TDI) / WRX STI
Discussion in 'Gen 3 Prius Main Forum' started by usbseawolf2000, Jul 1, 2009.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Yes, sir! Volt's carbon monoxide can surely kill if the ICE runs in the garage. I hope the engine maintenance (every 6 weeks) or fuel maintenance (every year) does not run while the car is charging in the garage. It could be lethal.
    2 people like this.
  2. ualdriver
    ualdriver Member
    358
    64
    Midwest US
    How about a chart that has that has a "regular" car like a Ford Taurus or a Chevy Malibu or similar compared to these various hybrids? I'm curious if there is a big difference.
  3. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    In case you missed the first post, I included Jetta gas version, Civic gas version and WRX STi.
    I plan to do a comparison with the Chevy Cruze 1.4 liter turbo engine. It is the same engine as the Volt but without turbo.
  4. ualdriver
    ualdriver Member
    358
    64
    Midwest US
    I was just wondering if a "normal" mid-sized sedan (V6) was much worse than the smaller cars you had on your bar graphs.
    I'm also curious why the Volt's carbon monoxide grams/mile was so high compared to the others in post 21 (assuming engine is even running).
  5. bwilson4web
    16,193
    Would you have the CO standard handy?
    That is an exceptionally bad CO result and the others aren't too good either. It is as if someone in GM decided play a practical joke:
    "Ok, here is your d*mn EV but the engine exhaust will kill ya'."
    Seriously, this needs to be shared with the 'automotive press.'
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    CO Standard for SULEV is 1.0 g/mi. For ULEV, it is 2.1 g/mi. Volt produces 1.3 gram of carbon monoxide per mile.
  7. Much More Better
    Much More Better Active Member
    655
    163
    I love my Prius even more now.
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  9. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    Just another data point showing what a bad choice of engine gm made. I wonder what the pollution and fe would be if they shoe horned the 1.8L prius engine in there? In a serial hybrid which the volt is most of the time you would think you could pick a power range that polluted less than a normal car, yet they pump out more than the cruize and Malibu.
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    This is really a reminder that there is more to a green car than it's electric mile. The benefit of on-board generator comes into question. If it is not used enough, why have it? Since it is there, the MPG and emission it produces is an important part of the equation.
  11. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    to be fair, the WRX was designed with very little thought to emmisions, it's purely a boy-racer car. I'd be interested in seeing a comparison of a PZEV outback with other green cars, since it's being marketed as a better green alternative to hybrids. (you know, no evil batteries fouling the environment!)
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Good point. Here is a comparison of WRX STi and the Volt. NOx is probably too high for STi to qualify for ULEV.
    I think this chart puts the Volt's emission into perspective.
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    And just think, the central plant providing the EV miles is *worse*
    Your graphs are very entertaining, but can we have CO split off into its own box ? All the other emissions appear homogenized because of the high CO values, even though substantial differences exist between engines.
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  15. ualdriver
    ualdriver Member
    358
    64
    Midwest US
    Interesting......its says it is asking GM about the high CO as it might be related to a cold start issue.
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Every hybrid has to deal with cold start issue. Prius has the exhaust heat recovery system to speed it up. Honda hybrids, Malibu and Cruze don't have this but still managed to get low CO emission.
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    I used the CARB STD numbers for the Volt to color in the appropriate CARB *LEV box for each pollutant. The Volt is not that far away from dropping into diesel territory, aka federal BIN II tier 5 -- the lowest allowed in CA.
    Addendum: I changed the CO box from 120k to 50k miles. Incidentally, I do not understand how the HCHO of 0.011 g/mile result did not drop the Volt into LEV class.
  18. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Re: Emission Comparison: Prius / HS250h / Insight / Civic Hybrid / Jetta (Gas+TDI) / WRX STIH
    Gasoline is around 250x more volatile than diesel. So they may not even have bothered testing the TDI. But I would expect the evaporative emissions to be quite low for it.
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    Kudos to Dennis for navigating the CARB website. Uggh.
    However, I did find this tidbit that might interest some people here -- the Prius plug-in
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Wow, I must have missed it. Do you have a link to the PDF? I can put it in my spreadsheet and get the charts out.
