Engine Swap from 1st gen to 2nd gen
Discussion in 'Gen 2 Prius Technical Discussion' started by greasemonkey007, Apr 18, 2016.
  1. greasemonkey007
    greasemonkey007 Active Member
    286
    104
    South Central Arkansas
    Will the 1.5L engine in a 1st gen car work in a 2nd gen car? I know the a/c compressors are not the same, but can I change the long block out without any major problems?
  2. Patrick Wong
    18,200
    6,464
    The valve timing is different, so the Classic engine may not work very well when operated with the 2G engine ECU.
    2G used engines are so cheap, there is no great reason not to use the correct engine model if the engine really needs to be replaced.
  3. greasemonkey007
    286
    104
    Thanks Patrick. My 2nd gen parts car has a busted oil pan. I'll have to inspect it pretty closely and swap the oil pan if everything else looks OK. I just happened to have a couple of classics on hand.
  4. racerx944
    racerx944 Junior Member
    16
    LA, CA
    2002 Prius
    I
    I am considering such a swap myself. I have a gen 1 engine sitting in my driveway looking for a home and I am looking at buying a gen 2 with a rod knock. Do I need to switch the head? How is the timing different? I am not familiar with these engines and detailed advise would be welcomed.
  5. Patrick Wong
    18,200
    6,464
    I am not aware of anyone who had successfully implemented such a swap. If you want to do the necessary homework, subscribe to techinfo.toyota.com and look at the New Car Features Manual for the 2001 model year vs. 2004 model year. You can research the difference between Prius generations for the engine as well as other drivetrain elements.
  6. vaughnstark777
    180
    33
    Roy, WA
    2001 Prius
    I
    Did you ever try this successfully?
  7. vaughnstark777
    180
    33
    Roy, WA
    2001 Prius
    I
  8. Another
    Another Senior Member
    1,802
    510
    Naples, Florida
    Seemed odd to elect to change the engine rather than just replace a ‘busted oil pan’. How much could even a new one cost if not in the junkyard?
  9. alftoy
    alftoy Senior Member
    1,132
    507
    Saskatchewan, Canada
