Enginer PHEV Technical Information
Discussion in 'Prius PHEV Plug-In Modifications' started by krousdb, Aug 13, 2009.
  1. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I'm forming a little theory on why the early CalCars and similar
    efforts had so much trouble. First of all, 12 amps is an entirely
    reasonable to "mismatch" from what the HSD motors are doing --
    consider the case of running the A/C hard and recharging a very
    low 12V battery at the same time. High A/C will pull a couple
    of kilowatts of compressor power to try and cool our sweaty butts
    down, accounting for as much as 10 amps from the hybrid battery.
    When I was recharging deep-cycles after a night of running small
    inverters to light an event this spring, using my Anderson connector
    in the back, I was seeing drains of 7 amps at the start which
    settled down to about 4 for the bulk of the recharge and finally
    tapered off -- discounting the one or two the car itself draws,
    let's say that's another 5 amps steady-state.
    So there you have 15 amps of draw that has nothing to do with making
    the car go, and since the HV controller has no sensing into those
    current paths for the A/C driver or the 12V DC/DC converter, it just
    has to put up with it. I guess this implies that if 15 amps of
    discharge is okay, then 15 amps of charge is also okay. All well
    under the usual CCL/CDL as reported by the battery ECU.
    To make things more interesting, the Hymotion people tell me that
    their connection is at the stock Prius pack relay connections, implying
    that they're on the correct side of the current donut -- i.e. the one
    that lets the car see what's going on. And they claim that they can
    push 40 amps into the system with no problem at all.
    So if Hymo is correct, here's my embryonic theory: The calcars people
    were trying to use their stupid, blundering contactor-based approach
    on the "outside" of the donut at first, and guess what happened? Click,
    and immediate HUGE, uncontrolled current spikes between the two packs
    that the car could see and go "holy sh*t!" and fire off immediate
    error codes. So they worked around it by landing on the other side of
    the donut, and then since the car couldn't see what was going on and
    thus couldn't coulomb-count the additional "magic current from the sky"
    coming in, they had to play all kinds of overly complex games on
    the CAN bus.
    Since the Hymo kit is also a current-regulated type, it is probably much
    nicer to the car's electrical system and probably ramps up the feed in
    a way that it can tolerate and doesn't exceed any outer limits such as
    100A that the stock pack is supposed to be good for in either direction.
    Since they play well on the bus, they probably pay attention to CCL and
    SOC and don't push things too hard. All this completely confirms my very
    early thinking that all such efforts should have taken a current-regulated
    approach, and that the whole contactor thing was doomed to failure from
    the very outset. I'm really surprised that a bunch of old EV guys who
    should know better actually ever thought that this would work reliably.
    Well, maybe you can do it across PbA packs and get away with it for a
    while, but NOT HERE and especially not with MIXED CHEMISTRIES.
    So hats off to Enginer for trying to do it the right way; now all they
    gotta do is get that QC up to snuff. That shipping damage is just ...
    unbelievably lame.
    _H*
    3 people like this.
  2. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Not a bad theory Hobbit. It makes a good deal of sense, but I'm not sure it fits all the facts. The two discrepancies I can think of are:
    1. Rudman's PiPrius, he used a nice PFC dc:dc converter and I believe had the same issues with DTCs and had to go inside the donut.
    2. I didn't think the DTCs in the contactor based systems usually happened right away, they seemed to occur after driving EV for a while.
    Both are mentioned in this link, but pretty short on details:
    Prius PHEV Schematics - EAA-PHEV
    On the other hand all this happened a few years before I started following it closely, its always possible that by then certain things had become accepted truths that were not necessarily so. It will be very interesting to what will happen when folks try 2 or 3 of these converters.
    Hobbit, you might be able to answer a question I had. If the pack is left on all the time, and if the voltage is high enough to pull the OEM battery SOC to an unsafe level, can the Prius dump charge while stationary or in park?
    Your comment about Hymotion is very intriguing....
    Rob
  3. miscrms
    2,076
    523
    Phoenix, AZ
    Hobbit you may be right about Hymotion. From this pic:
    http://i399.photobucket.com/albums/pp73/HymoPrius/033L5HVwiringattached.jpg
    from this thread:
    http://priuschat.com/forums/prius-p...ons/53794-yet-another-hymotion-install-3.html
    it certainly looks to me like Hymotion is entirely on the outside terminals.
    Compared to this pic:
    Image:100 1442.JPG - EAA-PHEV
    of a 2006 vintage Cal-Cars where you can clearly see the cable coming inside the Hall Effect sensor.
    Of course we do have to bear in mind that Hymotion also has a very sophisticated two port CAN controller that sits between the battery controller and the HV controller. This allows it to modify and/or spoof CAN messages between the two, which could certainly allow it to avoid the situations that cause the DTCs. Still very interesting.
    Rob
  4. miscrms
    2,076
    523
    Phoenix, AZ
    What you say is certainly true and I'll freely admit I don't know these batteries that well, but bear in mind a pack is only as good as its weakest cell in terms of capacity. Also my understanding is that as a pack ages it is generally not feasible to swap out individual cells. The discharge curves of cells change as they age (another inaccuracy in trying to use voltage to determine SOC), and are dependent on what they've all been through in terms of their charge/discharge and operating temperature history. A pack can usually be kept pretty well balanced over time because all the batteries have been through exactly the same things. If you try to put a brand new cell in an aged pack, its often pretty much impossible to keep the pack in balance.
  5. krousdb
    krousdb NX-74205
    580
    498
    47
    Raleigh, NC
    Will do.
  6. atfsi
    atfsi New Member
    91
    96
    47
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
  8. krousdb
    krousdb NX-74205
    580
    498
    47
    Raleigh, NC
    Number 3 is on it's way.
  9. Preacher
    Preacher New Member
    MA, USA
    WOW, 3! :eek: That is very cool! Are you staying at 8kwh of batteries or making the jump to 10 or 12 with the third converter?
  10. krousdb
    krousdb NX-74205
    580
    498
    47
    Raleigh, NC
    Prospects are looking good that I will be able to plug into work. The third converter will enable me to use the full 8kWh @ 80% DoD on each leg of the commute. No need for more batteries will be needed if I can plug in at work.:D
  11. krousdb
    krousdb NX-74205
    580
    498
    47
    Raleigh, NC
    I finally had a chance to measure converter efficiency, although I might revisit it once I get my hands on better equipment. The main problem is that my DC clamp on meter only goes up to 30A. One converter usually draws 40-60A. Due to the way that my packs are wired together, I had to take current measurements are three places to capture all of the current flow in small enough increments so that the meter would handle it. So here goes...
    Input
    51.3V x (21.1A + 10.7A + 9.7A) = 2129W
    Output
    221V x 8.75A = 1934W
    Efficiency
    1934/2129 = 90.8%
    The two cooling fans were not running at the time. According to Jack, they use about 50W. So when they are running, the efficiency drops to 88.8%. I plan on measuring this again once I get better equipment. I'm hoping that the number goes up. I have updated the first post with this info.
    Jack also told me that the higher voltage converters (Prius 1 for example at 320V) will be slightly more efficient. The lower voltage converters (170V for the Insight) will be slightly less.
  12. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    Guess I don't quite get it. 3 converters and four 2kW strings. I can see how you could hook one 2kW string to each converter, but that still leaves you with an extra 2kW pack.
    Is your plan to run basically two 2kW kits and on 4kW kit. When all three are running you get ~25-30A, then you finish off your commute on what's left of the 4kW pack?
  13. krousdb
    krousdb NX-74205
    580
    498
    47
    Raleigh, NC
    Dan,
    Take a close look at this picture:
    There are 4 strings (left to right) The positive and negative terminal at the end of each string are connected to one another. The four strings are in parallel. You can see on red and one black cable go around to the box cover where they are attached to a positive and negative terminal. Also connected to those two terminals are the charger and converters. All power goes through those two terminals. The third converter and second charger will also connect there.
  14. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    OHhhhh!!!!
    So they are paralleled at the 52V side!.
    11011011
  15. krousdb
    krousdb NX-74205
    580
    498
    47
    Raleigh, NC
    Yes! And on the 240V side as well.
  16. krousdb
    krousdb NX-74205
    580
    498
    47
    Raleigh, NC
    Updated the first post with battery and battery capacity info
    Batteries
    There are two different batteries supplied with this kit. Originally both the 2kWh and 4kWh kits were supplied with the Thunder Sky TS-LFP40 with a 40Ah capacity. Recently the height of the battery carrier box was reduced so that the rear deck cover would fit back on. That reduction in height would not allow 4kWh of the Thundersky TS-LFP40 to fit in the battery carrier. So the 39Ah Mott Cell batteries are now provided when a 4kWh kit is ordered.
    Battery Capacity (Rated vs. Actual)
    - TS-LFP40, rated at 40Ah @ 100% DoD
    - Charge started with a pack voltage of 48.0 (assume this is 0% SoC)
    - Kill-a-watt meter indicated 10.24kWh to charge to 54.0V (assume this is 100% SoC)
    - Charger efficiency is 86.7%
    - Charge added to the pack = 10.24*.867 = 8.878kWh
    - TS-LFP40 actual capacity = 8878Wh/51.2V/4 = 43.35Ah
  17. chenyj
    chenyj Member
    96
    115
    Troy, Michigan
    Here are pictures of the latest 4KWH System.
    Improvements:
    * Ventilation fan for charging and discharging
    * Charger exhaust to outside directly
    * Extra holes for smart key antenna block
    * Quick Disconnect from mounting brackets
    * Better cooling in DC/DC converter
    * Less frequent beeps from the balancers
    * Better component layout for installation and service
    * Compact Mottcell batteries
    7 people like this.
  18. TheForce
    3,461
    537
    Wheelersburg, Ohio
    WOW! Pretty! Looks very professional.
  19. kiettyyyy
    kiettyyyy Plug-In Supply Engineer
    205
    167
    West Covina, CA
    Now that... is a work of engineering.. Very professional and asthetically pleasing ;)
  20. Fibb222
    Fibb222 New Member
    1,499
    99
    Wow that does look impressive.
    But does it have two balancers still? Why are their four black boxes?
