Entunes Update Arrived, my findings....
Discussion in 'Gen 3 Prius Audio and Electronics' started by Muzzman1, Jul 6, 2012.
  1. Muzzman1
    Muzzman1 Member
    82
    42
    So Cal
    The install went without a hitch. Prior to install I made a backup of previous system through the menus I found an option to "copy to USB" I put a empty USB and made a backup (just in case)
    Here's my first impressions....
    1.) Is it just me or is the map resolution higher/better?
    2.)There's voice recognition everywhere I need it, such as to perform a Bing search, hit the button, tell it to "Find...." Good results every time.
    3.)Playing Pandora through the Apps is FINALLY the same quality as playing through bluetooth!
    4.) Iheartradio, Opentable movie..blah blah....I don't use those so I can't comment
    Over all, I am Stoked because all the things that bugged me about the system are fixed.
    Thanks Toyota!
  2. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    Muzzman, you said Entune update arrived. Did you mean a USB stick or over the air?
    Do you remember whereabouts, at least approximately, the copy to USB selection was?
  3. yueq
    yueq Junior Member
    MD
    I received the update on a 2GB USB stick.
  4. Muzzman1
    Muzzman1 Member
    82
    42
    So Cal
    ...I just checked: Car/General/(arrow down)System information/Copy to USB I might add after doing it, I looked at the files copied, and it looks like it is just saving personal settings, not the actual system ROM. The saved data was only around 17MB while the iso is around 300MB.
    The Entune update arrived via Snail Mail with a USB stick from Toyota.
    I uploaded the ISO here in case you don't feel like waiting. Simply put it on a FAT 32 formatted usb memory stick and plug it in while the car is on and not driving:
    https://www.rapidshare.com/files/469234457/swdl.iso
  5. Scott Hanselman
    Scott Hanselman New Member
    Portland, Oregon
  6. csciguy
    csciguy Junior Member
    38
    Southern California
    My findings so far besides those mentioned were
    1. New icons for the POIs or at least they are in color in the settings portion.
    2. Some of the fonts seems a little larger for the Music and Buttons and Audio Buttons updated too.
    3. My iPod/iPhone Music when it doesn't have Album Art it shows the Genre Name and a genric Art of that Type.
    4. The Navigation interface has a few cosmetic changes as far as mapping I need to check my common route.
    I'm sure there are more.
